Hi OSMC,
I have been trying to start mylar comics at boot but haven’t been able to.
$ sudo service mylar status
mylar.service - Mylar
Loaded: loaded (/etc/systemd/system/mylar.service; enabled; vendor preset: enabled)
Active: failed (Result: timeout) since Sun 2018-01-14 03:09:23 -03; 3s ago
Process: 378 ExecStart=/home/osmc/.pyenv/versions/2.7.11/bin/python /opt/Mylar/Mylar.py --daemon --datadir=/opt/Mylar/ --config=/opt/Mylar/config.ini --q
Jan 15 03:07:39 osmc systemd[1]: Starting Mylar…
Jan 15 03:09:23 osmc systemd[1]: mylar.service: Start operation timed out. Terminating.
Jan 15 03:09:23 osmc systemd[1]: Failed to start Mylar.
Jan 15 03:09:23 osmc systemd[1]: mylar.service: Unit entered failed state.
Jan 15 03:09:23 osmc systemd[1]: mylar.service: Failed with result ‘timeout’.
I can successfully start the daemon running sudo systemctl restart mylar
Here’s my config file:
[Unit]
Description=Mylar
After=network.target
[Service]
ExecStart=/home/osmc/.pyenv/versions/2.7.11/bin/python /opt/Mylar/Mylar.py --daemon --datadir=/opt/Mylar/ --config=/opt/Mylar/config.ini --quiet --nolaunch
GuessMainPID=no
GuessMainPID=no
Type=forking
User=osmc
Group=osmc
[Install]
WantedBy=multi-user.target
If someone here that understands systemd could provide me some help, please chime in.
