Hi All, im atempting to install my Pis UPS for my Car Pi install
Instructions here http://www.pimodules.com/_pdf/Simple_Setting_Guide_for_the_UPS_PIco.pdf
but OSMC doesnt have the raspberry pi config program is there a work around?
Edit
Ok fixed that by following this
however now the python-rpi.gpio doesnt seem to be found by apt in there some standard Raspbian repos i need to add?
Thanks in advance guys!
installing GPIO python via pip and i get this ideas?
Command /usr/bin/python -c “import setuptools, tokenize;file=‘/tmp/pip-build-wCDDOG/RPi.GPIO/setup.py’;exec(compile(getattr(tokenize, ‘open’, open)(file).read().replace(‘\r\n’, ‘\n’), file, ‘exec’))” install --record /tmp/pip-eOuJLh-record/install-record.txt --single-version-externally-managed --compile failed with error code 1 in /tmp/pip-build-wCDDOG/RPi.GPIO
Storing debug log for failure in /root/.pip/pip.log
Tried Following this
now i get
source/py_gpio.c:23:20: fatal error: Python.h: No such file or directory
#include “Python.h”
compilation terminated.
error: command ‘arm-linux-gnueabihf-gcc’ failed with exit status 1
Cleaning up…
Command /usr/bin/python -c “import setuptools, tokenize;file=‘/tmp/pip-build-CYtOPY/RPi.GPIO/setup.py’;exec(compile(getattr(tokenize, ‘open’, open)(file).read().replace(‘\r\n’, ‘\n’), file, ‘exec’))” install --record /tmp/pip-_RGR_O-record/install-record.txt --single-version-externally-managed --compile failed with error code 1 in /tmp/pip-build-CYtOPY/RPi.GPIO
osmc@osmc:~$
Edit 2:
got it by then installing sudo apt-get install python-dev
Will Write this up proper when im done… google is my friend haha
do you we have the write up on how to install this UPS HAT for OSMC?
