Please advise on how to fix
Do you have an SD card attached?
Nope
This might suggest a hardware fault (issues with eMMC).
You could try reinstalling from Download - OSMC to rule out a software issue.
That’s what I was afraid of. I tried reinstalling and it said it could not install. hardware issue. Can the eMMC be replaced?
Do you have more Vero 4k+ in stock?
The eMMC is soldered to the motherboard and isn’t user serviceable unfortunately.
I’ve sent you an image and some instructions via PM which you can try.
Yes.
