Try October version 2018.10 as this pre-dates some HDMI changes we made.
And try on another display.
How much power are you providing by USB?
don’t know
I just test with a docking station with that have a usb cable
Ok I’ve done several test without success. I guess some power stuff must be broken. I just ordered a new vero 4k
I will benefit from the gigabit etherne…
do you want I 'm sending you the broken one
Thanks to all for your help
If there is a warranty active then we can repair it for you — ping support@osmc.tv. When you get the new device I would try the PSU that comes with it on the old Vero.
I received my new Vero 4k + Thanks
I’ve done a try with the new PSU and … it works
Would it be possible to obtain a new PSU. This way I will be able to use both Vero’s …
Yes – we can send you a new PSU.
