Help with PI 3b
My vero stopped working and I have an old PI 3b that’s been sitting for a long time and I’m planning on installing osmc on it. Is there any firmware update or anything I should download before I install osmc or can I install osmc and then do firmware updates if needed? Thanks
The Pi 3 firmware is shipped with OSMC.
Ok so after I install osmc there is no updates I need to do for PI3? It’s been sitting for about 4 or 5 years.
Fresh install from files given by osmc,
Then once on net try update, then install apps as per required
The “My OSMC” add-on contains an updater. This will run system updates on its own according it its default schedule, or you can go in there and manually run them whenever you want.
