You have installed an experimental development repository.
If you don’t want those updates, you can either de-activate that repository; or if unhappy with the current status, reinstall from Download - OSMC.
I’ll reinstall and report.
I’m having the exact same issue, won’t play any 4K file properly.
please provide debug enabled logs if you want this to be investigated
I have reinstalled. Seemed ok. But after settings backup restore, it is messy again.
I will try to reinstall and rebuild from scratch hoping for this to solve this issue.
In the meantime, my lastest logs : https://paste.osmc.tv/odenizihab
Still the same problem even with a clean reinstall and no settings restore
I noticed something during playback with debug infos: while vq is > 60% all the time when everything is fine, when display does not work normally it is at 0%.
I don’t know what this means but maybe it can help you.
I have done other tests:
Please try run these commands:
wget https://collab.osmc.tv/s/hjdncbUBc93IJG2/download -O secureos.deb
sudo dpkg -i secureos.deb
shutdown -h now
Now remove power from the device and plug it back in after seeing a red light on the front of your device.
Linux osmc 4.9.113-55-osmc #1 SMP PREEMPT Fri Nov 19 14:03:43 UTC 2021 aarch64
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Sun Dec 5 11:03:25 2021 from
osmc@osmc:~$ wget https://collab.osmc.tv/s/hjdncbUBc93IJG2/download -O secureos.deb
–2021-12-06 08:53:07-- https://collab.osmc.tv/s/hjdncbUBc93IJG2/download
Resolving collab.osmc.tv (collab.osmc.tv)… 77.68.92.173, 2a00:da00:1800:9a::1
Connecting to collab.osmc.tv (collab.osmc.tv)|77.68.92.173|:443… connected.
HTTP request sent, awaiting response… 200 OK
Length: 271338 (265K) [application/x-deb]
Saving to: ‘secureos.deb’secureos.deb 100%[===================>] 264.98K 665KB/s in 0.4s
2021-12-06 08:53:08 (665 KB/s) - ‘secureos.deb’ saved [271338/271338]
osmc@osmc:~$ sudo dpkg -i secureos.deb
(Reading database … 35524 files and directories currently installed.)
Preparing to unpack secureos.deb …
Unpacking vero3-secureosmc-osmc (1.4.0-1) over (1.4.0-1) …
Setting up vero3-secureosmc-osmc (1.4.0-1) …
osmc@osmc:~$ shutdown -h now
Does not work better.
Here are the logs: https://paste.osmc.tv/yesabefuli
Thanks. I’m still having some issues reproducing the issue here.
It seems hit and miss.
Could you try this:
sudo wget "https://github.com/osmc/osmc/raw/6bbc2abb868fc2a1790c2412824b0813c2e637fd/package/vero3-userland-osmc/files/lib/firmware/osmc/video/video_ucode.bin" -O /lib/firmware/osmc/video/video_ucode.bin
sudo shutdown -h now
and see if this helps?
This isn’t meant to be a permanent fix – or even a guaranteed fix. I’m just trying to narrow down a couple of things.
Many thanks,
permitted by applicable law.osmc@osmc:~$ sudo cp /lib/firmware/osmc/video/video_ucode.bin /lib/firmware/osmc /video/video_ucode.bin.old
osmc@osmc:~$ sudo wget “https://github.com/osmc/osmc/raw/6bbc2abb868fc2a1790c241 2824b0813c2e637fd/package/vero3-userland-osmc/files/lib/firmware/osmc/video/vide o_ucode.bin” -O /lib/firmware/osmc/video/video_ucode.bin
–2021-12-08 08:41:40-- https://github.com/osmc/osmc/raw/6bbc2abb868fc2a1790c24 12824b0813c2e637fd/package/vero3-userland-osmc/files/lib/firmware/osmc/video/vid eo_ucode.bin
Resolving github.com (github.com)… 140.82.121.3
Connecting to github.com (github.com)|140.82.121.3|:443… connected.
HTTP request sent, awaiting response… 302 Found
Location: https://raw.githubusercontent.com/osmc/osmc/6bbc2abb868fc2a1790c241282 4b0813c2e637fd/package/vero3-userland-osmc/files/lib/firmware/osmc/video/video_u code.bin [following]
–2021-12-08 08:41:40-- https://raw.githubusercontent.com/osmc/osmc/6bbc2abb868 fc2a1790c2412824b0813c2e637fd/package/vero3-userland-osmc/files/lib/firmware/osm c/video/video_ucode.bin
Resolving raw.githubusercontent.com (raw.githubusercontent.com)… 185.199.111.1 33, 185.199.110.133, 185.199.108.133, …
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|185.199.111. 133|:443… connected.
Length: 1698816 (1.6M) [application/octet-stream]
Saving to: ‘/lib/firmware/osmc/video/video_ucode.bin’/lib/firmware/osmc/ 100%[===================>] 1.62M 601KB/s in 2.8s
2021-12-08 08:41:44 (601 KB/s) - ‘/lib/firmware/osmc/video/video_ucode.bin’ save d [1698816/1698816]
osmc@osmc:~$ sudo shutdown -h now
After a full cold reboot, HEVC is fine. I have to test a bit more with cold and warm reboots.
Logs here : https://paste.osmc.tv/igiyecisig
After some tests (warm and cold reboots), it seems fine
Please keep testing
Will do this evening
After a dozen of reboots (cold, warm, through command line and through Kodi interface), my problem seems to have disappeared
HEVC and x264 are ok, whatever the bitrate.
I don’t know if it is a permanent fix but it sure is a step in the right direction.
I will make a more permanent solution later tonight.
Does this mean you’ll let us know when the fix is coming?
Haven’t installed the update myself just yet… I’ll try and update my Vero4K ASAP. If I come across anything of a bug I’ll provide logs and follow some of the troubleshooting posted here.
Hopefully the issue is now fixed.
echo 'deb http://apt.osmc.tv buster-devel main' | sudo tee /etc/apt/sources.list.d/osmc-devel.listsudo apt-get update && sudo apt-get dist-upgrade && rebootPlease see if the issue is resolved.
I also recommend you remove /etc/apt/sources.list.d/osmc-devel.list after updating.
I’d also recommend you deactivate the staging repository. You can do so with the following command:
sudo rm /etc/apt/sources.list.d/osmc-devel.list.
I applied the patch and so far so good. With two warm reboots.
More tests this evening.
See command line output below:
osmc@osmc-Ulysses:~$ echo 'deb http://apt.osmc.tv buster-devel main' | sudo tee /etc/apt/sources.list.d/osmc-devel.list
osmc@osmc-Ulysses:~$ sudo apt-get update && sudo apt-get dist-upgrade && reboot
Get:1 http://security.debian.org buster/updates InRelease [65.4 kB]
Get:2 http://ftp.debian.org/debian buster InRelease [122 kB]
Get:3 http://ftp.debian.org/debian buster-updates InRelease [51.9 kB]
Hit:4 http://ftp.fau.de/osmc/osmc/apt buster InRelease
Hit:5 http://ftp.fau.de/osmc/osmc/apt buster-devel InRelease
Reading package lists... Done
E: Repository 'http://security.debian.org buster/updates InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
N: Repository 'http://ftp.debian.org/debian buster InRelease' changed its 'Version' value from '10.10' to '10.11'
E: Repository 'http://ftp.debian.org/debian buster InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
E: Repository 'http://ftp.debian.org/debian buster-updates InRelease' changed its 'Suite' value from 'stable-updates' to 'oldstable-updates'
This can be fixed by adding the below option:
sudo apt-get update --allow-releaseinfo-change && sudo apt-get dist-upgrade && reboot
