When I try to watch tv on the TV tab or the HDhomerun App it will play for a few min then get the frowny face. this is happening on all my pi PI OSMC boxes. here is the log Thanks For the help.
https://paste.osmc.tv/ umasodobug
Nov 13 19:19:43 LivingRoom kernel: modprobe invoked oom-killer: gfp_mask=0x14080c0(GFP_KERNEL|__GFP_ZERO), nodemask=(null), order=0, oom_score_adj=0
You seems to run out of memory. Maybe try to reduce your buffer settings.
I changed it to 104857600 and it worked a little longer. I will play with it some more. Thank you!
