Hi, Upgraded OSMC to Krypton, cant find Wifi or Blutooth settings, do these exist?
thanks,
Tony
thanks,
Tony
They are still in MyOSMC. Depending on your skin MyOSMC might be in the programs section if not on main menu
OK, thanks fzinken, i will take a look next time i boot her up, although i am sure i had a good look in there to no avail before i posted, thanks anyway. regards, Tony
