Does OSMC support the Hifiberry Beocreate amp?
How to configure?
Thanks for support!
How to configure?
Thanks for support!
Did you follow their instructions?
https://www.hifiberry.com/beocreate/beocreate-doc/beocreate-use-the-board-with-3rd-party-software/
While I would suggest to add dtoverlay=hifiberry-dac to /boot/config-user.txt so it survives the next update.
After a reboot you should see it in Settings - System - Audio
The Raspbian instructions most likely will also work but watch out for possible Port overlap.
https://www.hifiberry.com/beocreate/beocreate-doc/beocreate-installing-the-sigmatcpserver/
Thanks for the hints!
I use also the Beocreate SW - so the DSP is loaded with a program.
I reinstalled OSMC just to be sureā¦
The trick was the dtoverlay=. OSMC uses the outdated dtoverlay=hifiberry-dac_overlay. I removed the _overlay" part and it started working.
Issue solved - thank you very much!
Yes, will be corrected in next version
