Thanks @sam_nazarko !
(I hope it was not this issue which broke the update for all the other users. Didn’t want to rush things…)
thanky you sam!
It works like a charm now! Thank you very much!
Another thank you here. Great turnaround, appreciate the concern.
Working now. Thanks for that
Although, as far as I can tell the fix rolled out seems in part to have been to simply revert to the original overlay file names including the -overlay extension.
Can we possibly chalk this one up to “If it ain’t broke…”?
Thanks again
Jez
But it was broken. In the previous update people reported stuttering, now that’s resolved
You are free to turn updates off on your device
Sorry, I was unaware of the stuttering problem. I had no troubles here with a Pi3 / Hifiberry DigI+ setup feeding a Cambridge DacMagic Plus via Toslink.
Still not sure why audio stuttering would require renaming all the overlay files, though. But then, my understanding of Linux programming falls into the category of diddly-squat.
All the best… Jez
We changed how we compile overlays, so that we can support more hardware automatically, as the upstream kernel introduces it, instead of having to implicitly declare each overlay to be compiled. The changes made to overlay compilation did not specifically concern HifiBerry.
“I refer the honourable gentleman to the answer I gave some moments ago.”
Linux knowledge… diddly-squat.
Upstream kernel?
Don’t answer that. You’d be here till… forever.
thanks for ready solve the problem of june update. Bye
i’m on a rbp1 B and this does not work for me. hifiberry dac+ still not working.
so i decided to reinstall 4.4.13-1 and hifiberry still not working.
if i have dtoverlay=iqaudio-dacplus in config.txt dmesg shows:
snd-rpi-iqaudio-dac soc:sound: ASoC: CPU DAI (null) not registered
snd-rpi-iqaudio-dac soc:sound: snd_soc_register_card() failed: -517
snd-rpi-iqaudio-dac soc:sound: ASoC: CODEC DAI pcm512x-hifi not registered
if i have dtoverlay=iqaudio-dacplus-overlay in config.txt dmesg shows absolut nothing about ASoC
what else can i do?
4.4.13-1 is a kernel with this problem, why did you think reinstalling it would help ? 4.4.13-5 is the latest kernel where this problem has been fixed.
So please update to 4.4.13-5 and put your dtoverlay line back to what it originally was and it should work. If not please provide a debug log taken from the latest kernel - the results from an old known bad kernel are no use to us.
some posts back sam mentioned to revert, or am i wrong?
so here are the logs with current kernel (4.4-13-5)
http://paste.osmc.io/duzeherude
fixed it.
i checked config.txt again and there was a wrong entry for dtoverlay
changed
to
dtoverlay=hifiberry-dacplus-overlay
and it works again
i dont know where it came from.
Never mind, in the setting somehow the digi was only selected for mp3 audio while for movies hdmi was selected.
Thanks for putting a fix out so quickly!
Hello everyone,
I’m new here and have the same problem here (I have been looking at this topic for quite some time already).
I had the whole thing working since january (with the change to config.txt like everybody)
I made a clean install yesterday for reasons and I cannot make it work again
here is what I did on the last version of osmc :
$ sudo apt-get -y update && sudo apt-get -y upgrade
$ sudo apt-get install -y curl wget binutils alsa-utils
$ sudo reboot
$ sudo bash
cat >/etc/modules <<EOT
snd_soc_hifiberry_dacplus
EOT
reboot
add the following to config.txt
dtdebug=1
dtparam=audio=off (this line only after it didn’t work without it)
I did try to create the asound.conf in /etc/ don’t know if it’s useful or not
pcm.!default {
type hw card 0
ctl.!default {
type hw card 0
I get this line when I enter aplay -l
card 0: sndrpihifiberry [snd_rpi_hifiberry_dacplus], device 0: HiFiBerry DAC+ HiFi pcm512x-hifi-0
I can select the alsa hifiberry audio output in osmc and the green led is on when I launch a file, but no sound at all.
Here is what I get with dmesg
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.13-5-osmc (root@vero2a) (gcc version 4.9.2 (Debian 4.9.2-10) ) #1 SMP PREEMPT Mon Jun 20 16:34:27 UTC 2016
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
[ 0.000000] cma: Reserved 8 MiB at 0x2e400000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 192512
[ 0.000000] free_area_init_node: node 0, pgdat 80bd0140, node_mem_map add64000
[ 0.000000] Normal zone: 1692 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 192512 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (9660->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 13 pages/cpu @aefaa000 s23552 r8192 d21504 u53248
[ 0.000000] pcpu-alloc: s23552 r8192 d21504 u53248 alloc=13*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 190820
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1280 bcm2708_fb.fbheight=800 bcm2709.boardrev=0xa01041 bcm2709.serial=0x5b0eb2f4 smsc95xx.macaddr=B8:27:EB:0E:B2:F4 bcm2708_fb.fbswap=1 bcm2709.uart_clock=3000000 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait quiet osmcdev=rbp2
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 741072K/770048K available (8006K kernel code, 439K rwdata, 1864K rodata, 1792K init, 764K bss, 20784K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xaf800000 - 0xff800000 (1280 MB)
lowmem : 0x80000000 - 0xaf000000 ( 752 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x809abb24 (9871 kB)
.init : 0x809ac000 - 0x80b6c000 (1792 kB)
.data : 0x80b6c000 - 0x80bd9e4c ( 440 kB)
.bss : 0x80bdc000 - 0x80c9b36c ( 765 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000011] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000032] Switching to timer-based delay loop, resolution 52ns
[ 0.000330] Console: colour dummy device 80x30
[ 0.000548] console [tty0] enabled
[ 0.000577] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000606] pid_max: default: 32768 minimum: 301
[ 0.000957] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000979] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002212] Disabling cpuset control group subsystem
[ 0.002261] Initializing cgroup subsys io
[ 0.002299] Initializing cgroup subsys memory
[ 0.002350] Initializing cgroup subsys devices
[ 0.002377] Initializing cgroup subsys freezer
[ 0.002400] Initializing cgroup subsys net_cls
[ 0.002477] CPU: Testing write buffer coherency: ok
[ 0.002563] ftrace: allocating 19426 entries in 57 pages
[ 0.049856] CPU0: update cpu_capacity 1024
[ 0.049897] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.049913] [bcm2709_smp_prepare_cpus] enter
[ 0.050055] Setting up static identity map for 0x8240 - 0x8298
[ 0.129420] [bcm2709_boot_secondary] cpu:1 started (0) 18
[ 0.129776] [bcm2709_secondary_init] enter cpu:1
[ 0.129835] CPU1: update cpu_capacity 1024
[ 0.129843] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.159450] [bcm2709_boot_secondary] cpu:2 started (0) 18
[ 0.159737] [bcm2709_secondary_init] enter cpu:2
[ 0.159770] CPU2: update cpu_capacity 1024
[ 0.159778] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.189529] [bcm2709_boot_secondary] cpu:3 started (0) 17
[ 0.189781] [bcm2709_secondary_init] enter cpu:3
[ 0.189812] CPU3: update cpu_capacity 1024
[ 0.189820] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.189912] Brought up 4 CPUs
[ 0.189942] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.189952] CPU: All CPU(s) started in HYP mode.
[ 0.189961] CPU: Virtualization extensions available.
[ 0.190895] devtmpfs: initialized
[ 0.202668] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.203177] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.204278] pinctrl core: initialized pinctrl subsystem
[ 0.205109] NET: Registered protocol family 16
[ 0.210588] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.239677] cpuidle: using governor ladder
[ 0.269707] cpuidle: using governor menu
[ 0.277755] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.277778] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.277969] Serial: AMBA PL011 UART driver
[ 0.278287] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 0.278998] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.353258] bcm2835-dma 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x1
[ 0.353869] SCSI subsystem initialized
[ 0.354101] usbcore: registered new interface driver usbfs
[ 0.354216] usbcore: registered new interface driver hub
[ 0.354372] usbcore: registered new device driver usb
[ 0.359951] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-06-13 13:25
[ 0.387038] clocksource: Switched to clocksource arch_sys_counter
[ 0.439376] FS-Cache: Loaded
[ 0.439773] CacheFiles: Loaded
[ 0.456199] NET: Registered protocol family 2
[ 0.457502] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.457649] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.457843] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.457970] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.458037] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.458387] NET: Registered protocol family 1
[ 0.458911] RPC: Registered named UNIX socket transport module.
[ 0.458928] RPC: Registered udp transport module.
[ 0.458939] RPC: Registered tcp transport module.
[ 0.458950] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.571161] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.573581] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.573754] audit: initializing netlink subsys (disabled)
[ 0.573828] audit: type=2000 audit(0.539:1): initialized
[ 0.589597] VFS: Disk quotas dquot_6.6.0
[ 0.589997] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.592582] FS-Cache: Netfs 'nfs' registered for caching
[ 0.593835] NFS: Registering the id_resolver key type
[ 0.593914] Key type id_resolver registered
[ 0.593928] Key type id_legacy registered
[ 0.597378] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.597593] io scheduler noop registered
[ 0.598197] io scheduler bfq registered (default)
[ 0.598211] BFQ I/O-scheduler version: v7r7
[ 0.601133] BCM2708FB: allocated DMA memory ee800000
[ 0.601183] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 0.618871] Console: switching to colour frame buffer device 160x50
[ 1.608415] bcm2835-rng 3f104000.rng: hwrng registered
[ 1.608571] vc-cma: Videocore CMA driver
[ 1.608586] vc-cma: vc_cma_base = 0x00000000
[ 1.608598] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.608609] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.608940] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 1.629760] brd: module loaded
[ 1.641048] loop: module loaded
[ 1.642181] vchiq: vchiq_init_state: slot_zero = 0xae880000, is_master = 0
[ 1.643987] Loading iSCSI transport class v2.0-870.
[ 1.645038] usbcore: registered new interface driver smsc95xx
[ 1.645109] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.845481] Core Release: 2.80a
[ 1.845504] Setting default values for core params
[ 1.845533] Finished setting default values for core params
[ 2.045962] Using Buffer DMA mode
[ 2.045978] Periodic Transfer Interrupt Enhancement - disabled
[ 2.045988] Multiprocessor Interrupt Enhancement - disabled
[ 2.046000] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.046017] Dedicated Tx FIFOs mode
[ 2.046457] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xae814000 dma = 0xee814000 len=9024
[ 2.046498] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 2.046529] dwc_otg: Microframe scheduler enabled
[ 2.046600] WARN::hcd_init_fiq:413: FIQ on core 1 at 0x8057bd48
[ 2.046620] WARN::hcd_init_fiq:414: FIQ ASM at 0x8057c0b8 length 36
[ 2.046640] WARN::hcd_init_fiq:439: MPHI regs_base at 0xaf87e000
[ 2.046732] dwc_otg 3f980000.usb: DWC OTG Controller
[ 2.046786] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 2.046840] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 2.046896] Init: Port Power? op_state=1
[ 2.046908] Init: Power Port (0)
[ 2.047266] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.047288] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.047305] usb usb1: Product: DWC OTG Controller
[ 2.047323] usb usb1: Manufacturer: Linux 4.4.13-5-osmc dwc_otg_hcd
[ 2.047339] usb usb1: SerialNumber: 3f980000.usb
[ 2.048510] hub 1-0:1.0: USB hub found
[ 2.048582] hub 1-0:1.0: 1 port detected
[ 2.049390] dwc_otg: FIQ enabled
[ 2.049406] dwc_otg: NAK holdoff enabled
[ 2.049417] dwc_otg: FIQ split-transaction FSM enabled
[ 2.049455] Module dwc_common_port init
[ 2.049818] usbcore: registered new interface driver usb-storage
[ 2.050185] mousedev: PS/2 mouse device common for all mice
[ 2.050807] usbcore: registered new interface driver usbtouchscreen
[ 2.051113] bcm2835-cpufreq: min=600000 max=900000
[ 2.053584] sdhci: Secure Digital Host Controller Interface driver
[ 2.053594] sdhci: Copyright(c) Pierre Ossman
[ 2.053899] sdhost: log_buf @ ae813000 (ee813000)
[ 2.127096] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 2.147480] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.147955] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.148121] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.148278] usbcore: registered new interface driver usbhid
[ 2.148286] usbhid: USB HID core driver
[ 2.148766] Initializing XFRM netlink socket
[ 2.148799] NET: Registered protocol family 17
[ 2.148999] Key type dns_resolver registered
[ 2.149140] Registering SWP/SWPB emulation handler
[ 2.149959] registered taskstats version 1
[ 2.150153] vc-sm: Videocore shared memory driver
[ 2.150169] [vc_sm_connected_init]: start
[ 2.150703] [vc_sm_connected_init]: end - returning 0
[ 2.150978] of_cfs_init
[ 2.151075] of_cfs_init: OK
[ 2.153760] Freeing unused kernel memory: 1792K (809ac000 - 80b6c000)
[ 2.213984] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.216516] mmc0: new high speed SDHC card at address aaaa
[ 2.217422] mmcblk0: mmc0:aaaa SE32G 29.7 GiB
[ 2.229289] mmcblk0: p1 p2
[ 2.247203] Indeed it is in host mode hprt0 = 00021501
[ 2.364658] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.375229] fsck: E2fsck run: /bin/e2fsck -p -C 0 /dev/mmcblk0p2
[ 2.375464] fsck: Filesystem UUID: e21ad997-1293-4da1-8dea-1d34a3fff5ba
[ 2.375714] fsck: /dev/mmcblk0p2: clean, 28272/1933312 files, 349827/7728896 blocks
[ 2.437095] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.437256] Indeed it is in host mode hprt0 = 00001101
[ 2.637409] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.637430] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.638304] hub 1-1:1.0: USB hub found
[ 2.638494] hub 1-1:1.0: 5 ports detected
[ 2.917166] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.017477] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.017502] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.020463] smsc95xx v1.0.4
[ 3.080569] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:0e:b2:f4
[ 3.157168] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[ 3.258721] usb 1-1.2: New USB device found, idVendor=7392, idProduct=7811
[ 3.258745] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.258758] usb 1-1.2: Product: 802.11n WLAN Adapter
[ 3.258769] usb 1-1.2: Manufacturer: Realtek
[ 3.258780] usb 1-1.2: SerialNumber: 00e04c000001
[ 3.497110] usb 1-1.4: new full-speed USB device number 5 using dwc_otg
[ 3.569760] random: systemd urandom read with 67 bits of entropy available
[ 3.605799] usb 1-1.4: New USB device found, idVendor=1997, idProduct=2433
[ 3.605824] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.605836] usb 1-1.4: Product: Mini Keyboard
[ 3.605848] usb 1-1.4: Manufacturer:
[ 3.613395] input: Mini Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:1997:2433.0001/input/input0
[ 3.616615] NET: Registered protocol family 10
[ 3.668015] hid-generic 0003:1997:2433.0001: input,hidraw0: USB HID v1.01 Keyboard [ Mini Keyboard] on usb-3f980000.usb-1.4/input0
[ 3.676256] input: Mini Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:1997:2433.0002/input/input1
[ 3.727660] hid-generic 0003:1997:2433.0002: input,hidraw1: USB HID v1.01 Mouse [ Mini Keyboard] on usb-3f980000.usb-1.4/input1
[ 3.914268] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 3.914504] systemd[1]: Found ordering cycle on basic.target/start
[ 3.914526] systemd[1]: Found dependency on sysinit.target/start
[ 3.914545] systemd[1]: Found dependency on kbd.service/start
[ 3.914563] systemd[1]: Found dependency on remote-fs.target/start
[ 3.914580] systemd[1]: Found dependency on remote-fs-pre.target/start
[ 3.914597] systemd[1]: Found dependency on connman.service/start
[ 3.914614] systemd[1]: Found dependency on dbus.service/start
[ 3.914630] systemd[1]: Found dependency on basic.target/start
[ 3.914647] systemd[1]: Breaking ordering cycle by deleting job kbd.service/start
[ 3.914668] systemd[1]: Job kbd.service/start deleted to break ordering cycle starting with basic.target/start
[ 3.915008] systemd[1]: Found ordering cycle on basic.target/start
[ 3.915032] systemd[1]: Found dependency on sysinit.target/start
[ 3.915050] systemd[1]: Found dependency on rpcbind.service/start
[ 3.915069] systemd[1]: Found dependency on network-online.target/start
[ 3.915087] systemd[1]: Found dependency on network.target/start
[ 3.915103] systemd[1]: Found dependency on connman.service/start
[ 3.915119] systemd[1]: Found dependency on dbus.service/start
[ 3.915135] systemd[1]: Found dependency on basic.target/start
[ 3.915152] systemd[1]: Breaking ordering cycle by deleting job rpcbind.service/start
[ 3.915173] systemd[1]: Job rpcbind.service/start deleted to break ordering cycle starting with basic.target/start
[ 3.967282] usb 1-1.3: new high-speed USB device number 6 using dwc_otg
[ 4.037007] fuse init (API version 7.23)
[ 4.049429] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 4.158474] usb 1-1.3: New USB device found, idVendor=174c, idProduct=55aa
[ 4.158501] usb 1-1.3: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 4.158513] usb 1-1.3: Product: AS2105
[ 4.158524] usb 1-1.3: Manufacturer: ASMedia
[ 4.158535] usb 1-1.3: SerialNumber: 0123456789ABCDEF
[ 4.159423] usb-storage 1-1.3:1.0: USB Mass Storage device detected
[ 4.159735] usb-storage 1-1.3:1.0: Quirks match for vid 174c pid 55aa: 400000
[ 4.159837] scsi host0: usb-storage 1-1.3:1.0
[ 4.190276] snd-rpi-hifiberry-dacplus soc:sound: ASoC: CPU DAI (null) not registered
[ 4.190304] snd-rpi-hifiberry-dacplus soc:sound: snd_soc_register_card() failed: -517
[ 4.362768] systemd-udevd[189]: starting version 215
[ 4.529243] lirc_dev: IR Remote Control driver registered, major 244
[ 4.540818] snd-rpi-hifiberry-dacplus soc:sound: ASoC: CPU DAI (null) not registered
[ 4.540851] snd-rpi-hifiberry-dacplus soc:sound: snd_soc_register_card() failed: -517
[ 4.543270] lirc_rpi: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.545382] snd-rpi-hifiberry-dacplus soc:sound: ASoC: CPU DAI (null) not registered
[ 4.545411] snd-rpi-hifiberry-dacplus soc:sound: snd_soc_register_card() failed: -517
[ 4.563271] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 4.563512] snd-rpi-hifiberry-dacplus soc:sound: ASoC: CPU DAI (null) not registered
[ 4.563530] snd-rpi-hifiberry-dacplus soc:sound: snd_soc_register_card() failed: -517
[ 4.566128] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 4.566360] snd-rpi-hifiberry-dacplus soc:sound: ASoC: CPU DAI (null) not registered
[ 4.566381] snd-rpi-hifiberry-dacplus soc:sound: snd_soc_register_card() failed: -517
[ 4.568659] bcm2708_i2c 3f804000.i2c: BSC1 Controller at 0x3f804000 (irq 83) (baudrate 100000)
[ 4.568889] snd-rpi-hifiberry-dacplus soc:sound: ASoC: CPU DAI (null) not registered
[ 4.568911] snd-rpi-hifiberry-dacplus soc:sound: snd_soc_register_card() failed: -517
[ 4.579442] pinctrl-bcm2835 3f200000.gpio: pin gpio18 already requested by lirc_rpi; cannot claim for 3f203000.i2s
[ 4.579480] pinctrl-bcm2835 3f200000.gpio: pin-18 (3f203000.i2s) status -22
[ 4.579496] pinctrl-bcm2835 3f200000.gpio: could not request pin 18 (gpio18) from group gpio18 on device pinctrl-bcm2835
[ 4.579510] bcm2835-i2s 3f203000.i2s: Error applying setting, reverse things back
[ 4.580184] snd-rpi-hifiberry-dacplus soc:sound: ASoC: CODEC DAI pcm512x-hifi not registered
[ 4.580212] snd-rpi-hifiberry-dacplus soc:sound: snd_soc_register_card() failed: -517
[ 4.621339] snd-rpi-hifiberry-dacplus soc:sound: ASoC: CODEC DAI pcm512x-hifi not registered
[ 4.621368] snd-rpi-hifiberry-dacplus soc:sound: snd_soc_register_card() failed: -517
[ 4.727158] usbcore: registered new interface driver uas
[ 4.799438] rtl8192cu driver version=v4.0.2_9000.20130911
[ 4.799590]
usb_endpoint_descriptor(0):
[ 4.799604] bLength=7
[ 4.799611] bDescriptorType=5
[ 4.799618] bEndpointAddress=81
[ 4.799624] wMaxPacketSize=200
[ 4.799632] bInterval=0
[ 4.799639] RT_usb_endpoint_is_bulk_in = 1
[ 4.799646]
usb_endpoint_descriptor(1):
[ 4.799658] bLength=7
[ 4.799665] bDescriptorType=5
[ 4.799671] bEndpointAddress=2
[ 4.799677] wMaxPacketSize=200
[ 4.799684] bInterval=0
[ 4.799690] RT_usb_endpoint_is_bulk_out = 2
[ 4.799697]
usb_endpoint_descriptor(2):
[ 4.799706] bLength=7
[ 4.799712] bDescriptorType=5
[ 4.799728] bEndpointAddress=3
[ 4.799738] wMaxPacketSize=200
[ 4.799745] bInterval=0
[ 4.799751] RT_usb_endpoint_is_bulk_out = 3
[ 4.799760]
usb_endpoint_descriptor(3):
[ 4.799769] bLength=7
[ 4.799775] bDescriptorType=5
[ 4.799781] bEndpointAddress=84
[ 4.799787] wMaxPacketSize=40
[ 4.799793] bInterval=1
[ 4.799801] RT_usb_endpoint_is_int_in = 4, Interval = 1
[ 4.799809] nr_endpoint=4, in_num=2, out_num=2
[ 4.799817] USB_SPEED_HIGH
[ 4.799869] CHIP TYPE: RTL8188C_8192C
[ 4.799907] register rtw_netdev_ops to netdev_ops
[ 4.800141] Chip Version ID: VERSION_NORMAL_TSMC_CHIP_88C.
[ 4.800154] RF_Type is 3!!
[ 4.800435] EEPROM type is E-FUSE
[ 4.800446] ====> ReadAdapterInfo8192C
[ 4.800536] Boot from EFUSE, Autoload OK !
[ 4.843527] snd-rpi-hifiberry-dacplus soc:sound: pcm512x-hifi <-> 3f203000.i2s mapping ok
[ 4.895247] random: nonblocking pool is initialized
[ 4.925308] EEPROMVID = 0x7392
[ 4.925334] EEPROMPID = 0x7811
[ 4.925351] EEPROMCustomerID : 0x00
[ 4.925362] EEPROMSubCustomerID: 0x00
[ 4.925369] RT_CustomerID: 0x00
[ 4.925382] _ReadMACAddress MAC Address from EFUSE = 80:1f:02:c4:f3:b6
[ 4.925393] EEPROMRegulatory = 0x0
[ 4.925402] _ReadBoardType(0)
[ 4.925411] BT Coexistance = disable
[ 4.925418] mlmepriv.ChannelPlan = 0x02
[ 4.925429] _ReadPSSetting...bHWPwrPindetect(0)-bHWPowerdown(0) ,bSupportRemoteWakeup(0)
[ 4.925438] ### PS params=> power_mgnt(0),usbss_enable(0) ###
[ 4.925445] ### AntDivCfg(0)
[ 4.925452] readAdapterInfo_8192CU(): REPLACEMENT = 1
[ 4.925462] <==== ReadAdapterInfo8192C in 120 ms
[ 4.929392] rtw_macaddr_cfg MAC Address = 80:1f:02:c4:f3:b6
[ 4.929424] bDriverStopped:1, bSurpriseRemoved:0, bup:0, hw_init_completed:0
[ 4.930846] _rtw_drv_register_netdev, MAC Address (if1) = 80:1f:02:c4:f3:b6
[ 4.931020] usbcore: registered new interface driver rtl8192cu
[ 5.027828] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 5.169327] scsi 0:0:0:0: Direct-Access ST350063 0AS 3.AA PQ: 0 ANSI: 5
[ 5.170800] sd 0:0:0:0: [sda] 976771055 512-byte logical blocks: (500 GB/466 GiB)
[ 5.171374] sd 0:0:0:0: [sda] Write Protect is off
[ 5.171401] sd 0:0:0:0: [sda] Mode Sense: 23 00 00 00
[ 5.171899] sd 0:0:0:0: [sda] No Caching mode page found
[ 5.171925] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 5.191672] sda: sda1
[ 5.195267] sd 0:0:0:0: [sda] Attached SCSI disk
[ 5.222026] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 5.497188] lirc_rpi: auto-detected active high receiver on GPIO pin 18
[ 5.497628] lirc_rpi lirc_rpi: lirc_dev: driver lirc_rpi registered at minor = 0
[ 5.497647] lirc_rpi: driver registered!
[ 5.741749] systemd-journald[160]: Received request to flush runtime journal from PID 1
[ 5.796130] input: lircd as /devices/virtual/input/input2
[ 6.400176] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 6.400900] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.621565] +871x_drv - drv_open, bup=0
[ 6.625704] ===> FirmwareDownload91C() fw:Rtl819XFwImageArray_TSMC
[ 6.625742] FirmwareDownload92C accquire FW from embedded image
[ 6.625756] fw_ver=v88, fw_subver=2, sig=0x88c0
[ 6.647471] fw download ok!
[ 6.647494] Set RF Chip ID to RF_6052 and RF type to 1T1R.
[ 7.001767] IQK:Start!!!
[ 7.009408] Path A Rx IQK fail!!
[ 7.013537] Path A Rx IQK fail!!
[ 7.013561] Path A IQK Only Tx Success!!
[ 7.018935] Path A Rx IQK fail!!
[ 7.020863] Path A Rx IQK fail!!
[ 7.020881] Path A IQK Only Tx Success!!
[ 7.023288] IQK: final_candidate is 0
[ 7.023303] IQK: RegE94=101 RegE9C=f RegEA4=0 RegEAC=0 RegEB4=0 RegEBC=0 RegEC4=0 RegECC=0
Path A IQ Calibration Success !
[ 7.024052] _PHY_PathAFillIQKMatrix only Tx OK
[ 7.129855] pdmpriv->TxPowerTrackControl = 1
[ 7.132711] rtl8192cu_hal_init in 510ms
[ 7.150167] MAC Address = 80:1f:02:c4:f3:b6
[ 7.150420] -871x_drv - drv_open, bup=1
[ 7.150581] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 7.235678] [rtw_wx_set_pmkid] IW_PMKSA_FLUSH!
[ 7.235717] set_mode = IW_MODE_INFRA
[ 7.235980] =>rtw_wx_set_essid
[ 7.235995] ssid=g\xffffffc6isQ\xffffffffJ\xffffffec)\xffffffcd\xffffffba\xffffffab\xfffffff2\xfffffffb\xffffffe3F|\xffffffc2T\xfffffff8xffffffe8\xffffffe7\xffffff8dvZ.c3\xffffff9f\xffffffc9\xffffff9a, len=32
[ 7.236011] Set SSID under fw_state=0x00000008
[ 7.236038] <=rtw_wx_set_essid, ret 0
[ 7.236825] hw_var_set_opmode()-4236 mode = 2
[ 7.287550] [rtw_wx_set_pmkid] IW_PMKSA_FLUSH!
[ 7.762663] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 8.542648] survey done event(2e) band:0 for wlan0
[ 8.542685] rtw_select_and_join_from_scanned_queue: return _FAIL(candidate == NULL)
[ 8.542695] try_to_join, but select scanning queue fail, to_roaming:0
[ 9.162175] wpa_set_auth_algs, AUTH_ALG_OPEN_SYSTEM
[ 9.162210] set_mode = IW_MODE_INFRA
[ 9.162370]
wpa_ie(length:22):
[ 9.162389] 0x30 0x14 0x01 0x00 0x00 0x0f 0xac 0x02
[ 9.162400] 0x01 0x00 0x00 0x0f 0xac 0x04 0x01 0x00
[ 9.162410] 0x00 0x0f 0xac 0x02 0x00 0x00 0x00 0x00
[ 9.163076] hw_var_set_opmode()-4236 mode = 2
[ 9.163447] SetHwReg8192CU, 5132, RCR= 700060ca
[ 9.163576] =>rtw_wx_set_essid
[ 9.163588] ssid=Bbox-4E31A6, len=11
[ 9.163607] Set SSID under fw_state=0x00000008
[ 9.163627] [by_bssid:0][assoc_ssid:Bbox-4E31A6][to_roaming:0] new candidate: Bbox-4E31A6(00:1f:9f:c2:3a:33, ch6) rssi:-48
[ 9.163642] rtw_select_and_join_from_scanned_queue: candidate: Bbox-4E31A6(00:1f:9f:c2:3a:33, ch:6)
[ 9.163668] link to Broadcom AP
[ 9.163682] <=rtw_wx_set_essid, ret 0
[ 9.163805] Set BSSID under fw_state=0x00000088
[ 9.163848] start_join_set_ch_bw: ch=6, bwmode=0, ch_offset=0
[ 9.211188] link to Broadcom AP
[ 9.213809] OnAuthClient
[ 9.213834] network.SupportedRates[0]=82
[ 9.213842] network.SupportedRates[1]=84
[ 9.213850] network.SupportedRates[2]=8B
[ 9.213857] network.SupportedRates[3]=96
[ 9.213864] network.SupportedRates[4]=24
[ 9.213871] network.SupportedRates[5]=30
[ 9.213877] network.SupportedRates[6]=48
[ 9.213884] network.SupportedRates[7]=6C
[ 9.213891] network.SupportedRates[8]=0C
[ 9.213898] network.SupportedRates[9]=12
[ 9.213905] network.SupportedRates[10]=18
[ 9.213912] network.SupportedRates[11]=60
[ 9.213921] bssrate_len = 12
[ 9.216383] OnAssocRsp
[ 9.216409] report_join_res(6)
[ 9.216421] rtw_joinbss_update_network
[ 9.216447] rtw_joinbss_update_stainfo
[ 9.216548] HW_VAR_BASIC_RATE: BrateCfg(0x15d)
[ 9.216767] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 9.227683] WMM(0): 0, a42b
[ 9.227828] WMM(1): 0, a44f
[ 9.227951] WMM(2): 0, 5e4322
[ 9.228077] WMM(3): 0, 2f3222
[ 9.228087] HTOnAssocRsp
[ 9.232417] update raid entry, mask=0x40000fff, arg=0x80
[ 9.233774] rtl8192c_set_FwJoinBssReport_cmd mstatus(1)
[ 9.234640] SetFwRsvdPagePkt
[ 9.234682] Set RSVD page location to Fw.
[ 9.235685] =>mlmeext_joinbss_event_callback
[ 9.254951]
~~~~stastakey:unicastkey
[ 9.255481] ~~~~set sta key:groupkey
[ 9.255497] ==> rtw_set_key algorithm(2),keyid(1),key_mask(0)
[ 9.258842] SetHwReg8192CU, 5128, RCR= 700060ce
[ 9.493936] pcm512x 1-004d: No SCLK, using BCLK: -2
[ 9.511330] pcm512x 1-004d: No SCLK, using BCLK: -2
[ 9.516880] pcm512x 1-004d: No SCLK, using BCLK: -2
[ 9.522926] pcm512x 1-004d: No SCLK, using BCLK: -2
[ 9.528288] pcm512x 1-004d: No SCLK, using BCLK: -2
[ 9.875899] pcm512x 1-004d: No SCLK, using BCLK: -2
[ 10.664276] Console: switching to colour dummy device 80x30
[ 11.152827] rtl8192c_dm_RF_Saving(): RF_Save
[ 309.260027] IW_SCAN_THIS_ESSID, ssid=Bbox-4E31A6, len=11
[ 309.743756] Drop duplicate management frame with seq_num = 2513.
[ 309.942724] Drop duplicate management frame with seq_num = 2527.
[ 310.650088] survey done event(2d) band:0 for wlan0
[ 493.177777] pcm512x 1-004d: No SCLK, using BCLK: -2
[ 610.662428] IW_SCAN_THIS_ESSID, ssid=Bbox-4E31A6, len=11
[ 611.146318] Drop duplicate management frame with seq_num = 1189.
[ 611.453835] Drop duplicate management frame with seq_num = 1208.
[ 611.457616] Drop duplicate management frame with seq_num = 1209.
[ 612.061294] survey done event(2c) band:0 for wlan0
[ 767.612379] pcm512x 1-004d: No SCLK, using BCLK: -2
[ 912.072246] IW_SCAN_THIS_ESSID, ssid=Bbox-4E31A6, len=11
[ 912.563651] Drop duplicate management frame with seq_num = 29.
[ 912.861803] Drop duplicate management frame with seq_num = 45.
[ 913.482348] survey done event(2e) band:0 for wlan0
[ 1213.494595] IW_SCAN_THIS_ESSID, ssid=Bbox-4E31A6, len=11
[ 1214.275351] Drop duplicate management frame with seq_num = 2999.
[ 1214.884358] survey done event(29) band:0 for wlan0
[ 1340.764106] pcm512x 1-004d: No SCLK, using BCLK: -2
[ 1514.895917] IW_SCAN_THIS_ESSID, ssid=Bbox-4E31A6, len=11
[ 1515.280269] Drop duplicate management frame with seq_num = 2149.
[ 1515.676863] Drop duplicate management frame with seq_num = 2172.
[ 1516.286011] survey done event(31) band:0 for wlan0
[ 1816.300736] IW_SCAN_THIS_ESSID, ssid=Bbox-4E31A6, len=11
[ 1816.682882] Drop duplicate management frame with seq_num = 1047.
[ 1817.078774] Drop duplicate management frame with seq_num = 1075.
[ 1817.687247] survey done event(34) band:0 for wlan0
[ 2117.698559] IW_SCAN_THIS_ESSID, ssid=Bbox-4E31A6, len=11
[ 2118.076621] Drop duplicate management frame with seq_num = 4058.
[ 2118.481666] Drop duplicate management frame with seq_num = 4081.
[ 2118.483578] Drop duplicate management frame with seq_num = 4081.
[ 2118.487349] Drop duplicate management frame with seq_num = 4082.
[ 2118.489230] Drop duplicate management frame with seq_num = 4082.
[ 2118.491127] Drop duplicate management frame with seq_num = 4082.
[ 2119.088627] survey done event(24) band:0 for wlan0
I see there might be something wrong here :
and this from “sudo vcdbg log msg”
001289.943: HDMI:EDID version 1.3, 1 extensions, unknown aspect ratio
001290.008: HDMI:EDID features - videodef 0x80 standby !suspend !active off; colour encoding:RGB444|YCbCr422; sRGB is not default colourspace; preferred format is native; does not support GTF
001290.090: HDMI:EDID found preferred DMT detail timing format: 1280x800p @ 60 Hz (28)
001290.130: HDMI:EDID found DMT format: code 4, 640x480p @ 60 Hz in established timing I/II
001290.167: HDMI:EDID found DMT format: code 5, 640x480p @ 72 Hz in established timing I/II
001290.205: HDMI:EDID found DMT format: code 6, 640x480p @ 75 Hz in established timing I/II
001290.241: HDMI:EDID found DMT format: code 8, 800x600p @ 56 Hz in established timing I/II
001290.280: HDMI:EDID found DMT format: code 9, 800x600p @ 60 Hz in established timing I/II
001290.317: HDMI:EDID found DMT format: code 10, 800x600p @ 72 Hz in established timing I/II
001290.356: HDMI:EDID found DMT format: code 11, 800x600p @ 75 Hz in established timing I/II
001290.396: HDMI:EDID found DMT format: code 16, 1024x768p @ 60 Hz in established timing I/II
001290.435: HDMI:EDID found DMT format: code 17, 1024x768p @ 70 Hz in established timing I/II
001290.472: HDMI:EDID found DMT format: code 18, 1024x768p @ 75 Hz in established timing I/II
001290.514: HDMI:EDID found DMT format: code 36, 1280x1024p @ 75 Hz in established timing I/II
001290.598: HDMI:EDID standard timings block x 8: 0x317C 457C 617C 81C0 8180 8100 9500 A940
001290.647: HDMI:EDID unknown standard timing 640x480 @ 120 Hz aspect ratio (4:3)
001290.695: HDMI:EDID found DMT format: code 13, 800x600p @ 120 Hz (4:3) in standard timing 1
001290.744: HDMI:EDID found DMT format: code 20, 1024x768p @ 120 Hz (4:3) in standard timing 2
001290.796: HDMI:EDID found DMT format: code 85, 1280x720p @ 60 Hz (16:9) in standard timing 3
001290.846: HDMI:EDID found DMT format: code 35, 1280x1024p @ 60 Hz (5:4) in standard timing 4
001290.895: HDMI:EDID found DMT format: code 28, 1280x800p @ 60 Hz (16:10) in standard timing 5
001290.945: HDMI:EDID found DMT format: code 47, 1440x900p @ 60 Hz (16:10) in standard timing 6
001290.997: HDMI:EDID found DMT format: code 51, 1600x1200p @ 60 Hz (4:3) in standard timing 7
001304.008: HDMI:EDID parsing v3 CEA extension 0
001304.046: HDMI:EDID monitor support - underscan IT formats:yes, basic audio:yes, yuv444:yes, yuv422:yes, #native DTD:1
001304.087: HDMI:EDID found CEA detail timing format: 720x480p @ 60 Hz (2)
001304.131: HDMI:EDID found CEA detail timing format: 1280x720p @ 50 Hz (19)
001304.174: HDMI:EDID found CEA detail timing format: 1920x1080i @ 50 Hz (20)
001304.216: HDMI:EDID found CEA detail timing format: 720x576p @ 50 Hz (17)
001304.261: HDMI:EDID found CEA detail timing format: 720x576p @ 50 Hz (17)
001304.293: HDMI:EDID found CEA format: code 1, 640x480p @ 60Hz
001304.326: HDMI:EDID found CEA format: code 2, 720x480p @ 60Hz
001304.358: HDMI:EDID found CEA format: code 3, 720x480p @ 60Hz
001304.393: HDMI:EDID found CEA format: code 4, 1280x720p @ 60Hz (native)
001304.426: HDMI:EDID found CEA format: code 5, 1920x1080i @ 60Hz
001304.457: HDMI:EDID found CEA format: code 7, 1440x480i @ 60Hz
001304.490: HDMI:EDID found CEA format: code 16, 1920x1080p @ 60Hz
001304.523: HDMI:EDID found CEA format: code 17, 720x576p @ 50Hz
001304.556: HDMI:EDID found CEA format: code 19, 1280x720p @ 50Hz
001304.589: HDMI:EDID found CEA format: code 20, 1920x1080i @ 50Hz
001304.623: HDMI:EDID found CEA format: code 21, 1440x576i @ 50Hz
001304.655: HDMI:EDID found CEA format: code 31, 1920x1080p @ 50Hz
001304.688: HDMI:EDID found CEA format: code 32, 1920x1080p @ 24Hz
001304.742: HDMI:EDID found audio format 2 channels PCM, sample rate: 32|44|48 kHz, sample size: 16|20|24 bits
001304.759: HDMI:EDID found HDMI VSDB length 5
001304.784: HDMI:EDID HDMI VSDB has physical address 1.0.0.0
001304.799: HDMI:EDID HDMI VSDB has no extension fields
001304.841: HDMI:EDID filtering formats with pixel clock > 162 MHz or h. blanking > 1023
001305.038: HDMI:EDID preferred mode remained as DMT (28) 1280x800p @ 60 Hz with pixel clock 83 MHz
001315.725: HDMI:Setting property pixel encoding to Default
001315.746: HDMI:Setting property pixel clock type to PAL
001315.765: HDMI:Setting property content type flag to No data
001315.784: HDMI:Setting property fuzzy format match to enabled
001512.874: hdmi: HDMI:>>>>>>>>>>>>>Rx sensed, reading EDID<<<<<<<<<<<<<
001525.006: hdmi: HDMI:EDID version 1.3, 1 extensions, unknown aspect ratio
001525.077: hdmi: HDMI:EDID features - videodef 0x80 standby !suspend !active off; colour encoding:RGB444|YCbCr422; sRGB is not default colourspace; preferred format is native; does not support GTF
001525.161: hdmi: HDMI:EDID found preferred DMT detail timing format: 1280x800p @ 60 Hz (28)
001525.207: hdmi: HDMI:EDID found DMT format: code 4, 640x480p @ 60 Hz in established timing I/II
001525.249: hdmi: HDMI:EDID found DMT format: code 5, 640x480p @ 72 Hz in established timing I/II
001525.288: hdmi: HDMI:EDID found DMT format: code 6, 640x480p @ 75 Hz in established timing I/II
001525.331: hdmi: HDMI:EDID found DMT format: code 8, 800x600p @ 56 Hz in established timing I/II
001525.371: hdmi: HDMI:EDID found DMT format: code 9, 800x600p @ 60 Hz in established timing I/II
001525.414: hdmi: HDMI:EDID found DMT format: code 10, 800x600p @ 72 Hz in established timing I/II
001525.453: hdmi: HDMI:EDID found DMT format: code 11, 800x600p @ 75 Hz in established timing I/II
001525.495: hdmi: HDMI:EDID found DMT format: code 16, 1024x768p @ 60 Hz in established timing I/II
001525.536: hdmi: HDMI:EDID found DMT format: code 17, 1024x768p @ 70 Hz in established timing I/II
001525.579: hdmi: HDMI:EDID found DMT format: code 18, 1024x768p @ 75 Hz in established timing I/II
001525.623: hdmi: HDMI:EDID found DMT format: code 36, 1280x1024p @ 75 Hz in established timing I/II
001525.713: hdmi: HDMI:EDID standard timings block x 8: 0x317C 457C 617C 81C0 8180 8100 9500 A940
001525.768: hdmi: HDMI:EDID unknown standard timing 640x480 @ 120 Hz aspect ratio (4:3)
001525.821: hdmi: HDMI:EDID found DMT format: code 13, 800x600p @ 120 Hz (4:3) in standard timing 1
001525.873: hdmi: HDMI:EDID found DMT format: code 20, 1024x768p @ 120 Hz (4:3) in standard timing 2
001525.931: hdmi: HDMI:EDID found DMT format: code 85, 1280x720p @ 60 Hz (16:9) in standard timing 3
001525.986: hdmi: HDMI:EDID found DMT format: code 35, 1280x1024p @ 60 Hz (5:4) in standard timing 4
001526.041: hdmi: HDMI:EDID found DMT format: code 28, 1280x800p @ 60 Hz (16:10) in standard timing 5
001526.096: hdmi: HDMI:EDID found DMT format: code 47, 1440x900p @ 60 Hz (16:10) in standard timing 6
001526.150: hdmi: HDMI:EDID found DMT format: code 51, 1600x1200p @ 60 Hz (4:3) in standard timing 7
001539.168: hdmi: HDMI:EDID parsing v3 CEA extension 0
001539.211: hdmi: HDMI:EDID monitor support - underscan IT formats:yes, basic audio:yes, yuv444:yes, yuv422:yes, #native DTD:1
001539.258: hdmi: HDMI:EDID found CEA detail timing format: 720x480p @ 60 Hz (2)
001539.307: hdmi: HDMI:EDID found CEA detail timing format: 1280x720p @ 50 Hz (19)
001539.356: hdmi: HDMI:EDID found CEA detail timing format: 1920x1080i @ 50 Hz (20)
001539.404: hdmi: HDMI:EDID found CEA detail timing format: 720x576p @ 50 Hz (17)
001539.449: hdmi: HDMI:EDID found CEA detail timing format: 720x576p @ 50 Hz (17)
001539.487: hdmi: HDMI:EDID found CEA format: code 1, 640x480p @ 60Hz
001539.523: hdmi: HDMI:EDID found CEA format: code 2, 720x480p @ 60Hz
001539.557: hdmi: HDMI:EDID found CEA format: code 3, 720x480p @ 60Hz
001539.594: hdmi: HDMI:EDID found CEA format: code 4, 1280x720p @ 60Hz (native)
001539.629: hdmi: HDMI:EDID found CEA format: code 5, 1920x1080i @ 60Hz
001539.666: hdmi: HDMI:EDID found CEA format: code 7, 1440x480i @ 60Hz
001539.704: hdmi: HDMI:EDID found CEA format: code 16, 1920x1080p @ 60Hz
001539.739: hdmi: HDMI:EDID found CEA format: code 17, 720x576p @ 50Hz
001539.776: hdmi: HDMI:EDID found CEA format: code 19, 1280x720p @ 50Hz
001539.813: hdmi: HDMI:EDID found CEA format: code 20, 1920x1080i @ 50Hz
001539.849: hdmi: HDMI:EDID found CEA format: code 21, 1440x576i @ 50Hz
001539.887: hdmi: HDMI:EDID found CEA format: code 31, 1920x1080p @ 50Hz
001539.924: hdmi: HDMI:EDID found CEA format: code 32, 1920x1080p @ 24Hz
001539.979: hdmi: HDMI:EDID found audio format 2 channels PCM, sample rate: 32|44|48 kHz, sample size: 16|20|24 bits
001540.002: hdmi: HDMI:EDID found HDMI VSDB length 5
001540.032: hdmi: HDMI:EDID HDMI VSDB has physical address 1.0.0.0
001540.052: hdmi: HDMI:EDID HDMI VSDB has no extension fields
001540.101: hdmi: HDMI:EDID filtering formats with pixel clock > 162 MHz or h. blanking > 1023
001540.301: hdmi: HDMI:EDID preferred mode remained as DMT (28) 1280x800p @ 60 Hz with pixel clock 83 MHz
001540.325: hdmi: HDMI: hotplug attached with HDMI support
001540.393: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
001542.858: hdmi: HDMI: power_on to DMT mode 1280x800@60
001546.030: hdmi: HDMI: Action callback added to queue to happen at frame 0
001562.756: *** Restart logging
001563.915: Read command line from file 'cmdline.txt'
002069.786: Loading 'kernel.img' to 0x8000 size 0x70d818
002083.831: No kernel trailer (run mkknlimg to fix) - assuming DT-capable
002086.436: Loading 'bcm2709-rpi-2-b.dtb' to 0x715818 size 0x38e3
002096.667: dtdebug: delete_node(/__local_fixups__)
002102.522: dtdebug: /aliases:i2c_vc=i2c0
002107.649: dtdebug: /__symbols__:i2c_vc=i2c0
002111.897: dtdebug: /__overrides__:i2c_vc=i2c0
002120.041: dtdebug: /__overrides__:i2c_vc_baudrate=i2c0_baudrate
002122.968: dtdebug: /aliases:i2c=i2c1
002128.256: dtdebug: /__symbols__:i2c=i2c1
002132.610: dtdebug: /__overrides__:i2c=i2c1
002135.582: dtdebug: /aliases:i2c_arm=i2c1
002140.912: dtdebug: /__symbols__:i2c_arm=i2c1
002145.292: dtdebug: /__overrides__:i2c_arm=i2c1
002153.607: dtdebug: /__overrides__:i2c_baudrate=i2c1_baudrate
002161.963: dtdebug: /__overrides__:i2c_arm_baudrate=i2c1_baudrate
002161.981: dtparam: pwr_led_gpio=35
002164.860: dtdebug: Found override pwr_led_gpio
002164.905: dtdebug: override pwr_led_gpio: cell target gpios @ offset 4 (size 4)
002170.859: dtparam: uart0_clkrate=3000000
002173.560: dtdebug: Found override uart0_clkrate
002173.609: dtdebug: override uart0_clkrate: cell target clock-frequency @ offset 0 (size 4)
002181.890: dterror: not a valid FDT - err -9
002181.901: Failed to load HAT overlay
002187.846: dtdebug: Failed to open overlay file 'overlays/lirc-rpi.dtbo'
002190.641: dtdebug: Opened overlay file 'overlays/lirc-rpi-overlay.dtb'
002198.751: Loaded overlay 'lirc-rpi'
002198.769: dtparam: gpio_out_pin=17
002198.913: dtdebug: Found override gpio_out_pin
002198.959: dtdebug: override gpio_out_pin: cell target brcm,pins @ offset 0 (size 4)
002199.332: dtparam: gpio_in_pin=18
002199.480: dtdebug: Found override gpio_in_pin
002199.525: dtdebug: override gpio_in_pin: cell target brcm,pins @ offset 4 (size 4)
002199.934: dtdebug: Found fragment 0 (offset 36)
002200.026: dtdebug: merge_fragment(/,/fragment@0/__overlay__)
002207.934: dtdebug: merge_fragment(/lirc_rpi,/fragment@0/__overlay__/lirc_rpi)
002207.960: dtdebug: +prop(compatible)
002209.722: dtdebug: +prop(pinctrl-names)
002211.623: dtdebug: +prop(pinctrl-0)
002213.543: dtdebug: +prop(status)
002215.450: dtdebug: +prop(rpi,sense)
002217.646: dtdebug: +prop(rpi,softcarrier)
002219.857: dtdebug: +prop(rpi,invert)
002222.088: dtdebug: +prop(rpi,debug)
002224.337: dtdebug: +prop(phandle)
002226.273: dtdebug: merge_fragment() end
002226.309: dtdebug: merge_fragment() end
002226.392: dtdebug: Found fragment 1 (offset 276)
002229.248: dtdebug: merge_fragment(/soc/gpio@7e200000,/fragment@1/__overlay__)
002232.143: dtdebug: merge_fragment(/soc/gpio@7e200000/lirc_pins,/fragment@1/__overlay__/lirc_pins)
002232.171: dtdebug: +prop(brcm,pins)
002233.766: dtdebug: +prop(brcm,function)
002235.388: dtdebug: +prop(brcm,pull)
002237.307: dtdebug: +prop(phandle)
002238.907: dtdebug: merge_fragment() end
002238.936: dtdebug: merge_fragment() end
002244.922: dtdebug: Failed to open overlay file 'overlays/hifiberry-dacplus.dtbo'
002249.997: dtdebug: Opened overlay file 'overlays/hifiberry-dacplus-overlay.dtb'
002264.560: Loaded overlay 'hifiberry-dacplus'
002264.600: dtparam: audio=off
002264.830: dtdebug: /__overrides__ has no audio property
002267.806: dtdebug: Found override audio
002267.839: dtdebug: override audio: string target 'status'
002275.106: dtdebug: Found fragment 0 (offset 36)
002280.779: dtdebug: merge_fragment(/clocks,/fragment@0/__overlay__)
002285.457: dtdebug: merge_fragment(/clocks/dacpro_osc,/fragment@0/__overlay__/dacpro_osc)
002285.484: dtdebug: +prop(compatible)
002286.247: dtdebug: +prop(#clock-cells)
002287.107: dtdebug: +prop(phandle)
002287.956: dtdebug: merge_fragment() end
002287.983: dtdebug: merge_fragment() end
002288.057: dtdebug: Found fragment 1 (offset 184)
002292.374: dtdebug: merge_fragment(/soc/i2s@7e203000,/fragment@1/__overlay__)
002292.399: dtdebug: +prop(status)
002293.823: dtdebug: merge_fragment() end
002293.880: dtdebug: Found fragment 2 (offset 260)
002301.259: dtdebug: merge_fragment(/soc/i2c@7e804000,/fragment@2/__overlay__)
002301.287: dtdebug: +prop(#address-cells)
002302.396: dtdebug: +prop(#size-cells)
002303.512: dtdebug: +prop(status)
002308.254: dtdebug: merge_fragment(/soc/i2c@7e804000/pcm5122@4d,/fragment@2/__overlay__/pcm5122@4d)
002308.279: dtdebug: +prop(#sound-dai-cells)
002309.484: dtdebug: +prop(compatible)
002310.569: dtdebug: +prop(reg)
002311.715: dtdebug: +prop(clocks)
002312.868: dtdebug: +prop(status)
002314.095: dtdebug: merge_fragment() end
002314.127: dtdebug: merge_fragment() end
002314.209: dtdebug: Found fragment 3 (offset 480)
002324.148: dtdebug: merge_fragment(/soc/sound,/fragment@3/__overlay__)
002324.176: dtdebug: +prop(compatible)
002325.033: dtdebug: +prop(i2s-controller)
002326.307: dtdebug: +prop(status)
002327.164: dtdebug: merge_fragment() end
002331.450: dtdebug: /aliases:serial0=uart0
002334.603: dtdebug: /aliases:serial1=uart1
002384.699: dtparam: arm_freq=900000000
002387.659: dtdebug: Found override arm_freq
002387.707: dtdebug: override arm_freq: cell target clock-frequency @ offset 0 (size 4)
002397.267: dtdebug: override arm_freq: cell target clock-frequency @ offset 0 (size 4)
002406.958: dtdebug: override arm_freq: cell target clock-frequency @ offset 0 (size 4)
002416.749: dtdebug: override arm_freq: cell target clock-frequency @ offset 0 (size 4)
002426.616: dtparam: core_freq=250000000
002429.716: dtdebug: Found override core_freq
002429.762: dtdebug: override core_freq: cell target clock-frequency @ offset 0 (size 4)
002437.734: dtparam: cache_line_size=64
002440.683: dtdebug: Found override cache_line_size
002440.730: dtdebug: override cache_line_size: cell target cache-line-size @ offset 0 (size 4)
002447.577: dtdebug: delete_node(/hat)
002475.220: Device tree loaded to 0x2efebf00 (size 0x40ac)
002478.393: gpioman: gpioman_get_pin_num: pin SDCARD_CONTROL_POWER not defined
004387.303: vchiq_core: vchiq_init_state: slot_zero = 0xee880000, is_master = 1
004391.473: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
004396.353: TV service:host side not connected, dropping notification 0x00000002, 0x00000002, 0x0000001c
013449.335: hdmi: HDMI:Setting property pixel clock type to PAL
013449.471: hdmi: HDMI: power_on to DMT mode 1280x800@60
013449.523: hdmi: HDMI: Action detach added to queue to happen at frame 702
013449.545: hdmi: HDMI: Action change_mode added to queue to happen at frame 702
013449.569: hdmi: HDMI: Action attach added to queue to happen at frame 702
013449.593: hdmi: HDMI: Action start_mode added to queue to happen at frame 702
013449.617: hdmi: HDMI: Action callback added to queue to happen at frame 704
013449.641: hdmi: HDMI: Action stop_3d_mode added to queue to happen at frame 704
013449.664: hdmi: HDMI: Action unmute added to queue to happen at frame 705
1313617.801: hdmi: HDMI: hotplug deassert
1313617.816: hdmi: HDMI: HDMI is currently on
1313617.831: hdmi: HDMI: changing mode to unplugged
1313717.816: hdmi: HDMI:>>>>>>>>>>>>>Rx sensed, reading EDID<<<<<<<<<<<<<
1313729.878: hdmi: HDMI:EDID version 1.3, 1 extensions, unknown aspect ratio
1313729.948: hdmi: HDMI:EDID features - videodef 0x80 standby !suspend !active off; colour encoding:RGB444|YCbCr422; sRGB is not default colourspace; preferred format is native; does not support GTF
1313730.035: hdmi: HDMI:EDID found preferred DMT detail timing format: 1280x800p @ 60 Hz (28)
1313730.078: hdmi: HDMI:EDID found DMT format: code 4, 640x480p @ 60 Hz in established timing I/II
1313730.117: hdmi: HDMI:EDID found DMT format: code 5, 640x480p @ 72 Hz in established timing I/II
1313730.159: hdmi: HDMI:EDID found DMT format: code 6, 640x480p @ 75 Hz in established timing I/II
1313730.200: hdmi: HDMI:EDID found DMT format: code 8, 800x600p @ 56 Hz in established timing I/II
1313730.242: hdmi: HDMI:EDID found DMT format: code 9, 800x600p @ 60 Hz in established timing I/II
1313730.281: hdmi: HDMI:EDID found DMT format: code 10, 800x600p @ 72 Hz in established timing I/II
1313730.325: hdmi: HDMI:EDID found DMT format: code 11, 800x600p @ 75 Hz in established timing I/II
1313730.385: hdmi: HDMI:EDID found DMT format: code 16, 1024x768p @ 60 Hz in established timing I/II
1313730.431: hdmi: HDMI:EDID found DMT format: code 17, 1024x768p @ 70 Hz in established timing I/II
1313730.471: hdmi: HDMI:EDID found DMT format: code 18, 1024x768p @ 75 Hz in established timing I/II
1313730.517: hdmi: HDMI:EDID found DMT format: code 36, 1280x1024p @ 75 Hz in established timing I/II
1313730.604: hdmi: HDMI:EDID standard timings block x 8: 0x317C 457C 617C 81C0 8180 8100 9500 A940
1313730.658: hdmi: HDMI:EDID unknown standard timing 640x480 @ 120 Hz aspect ratio (4:3)
1313730.709: hdmi: HDMI:EDID found DMT format: code 13, 800x600p @ 120 Hz (4:3) in standard timing 1
1313730.764: hdmi: HDMI:EDID found DMT format: code 20, 1024x768p @ 120 Hz (4:3) in standard timing 2
1313730.821: hdmi: HDMI:EDID found DMT format: code 85, 1280x720p @ 60 Hz (16:9) in standard timing 3
1313730.874: hdmi: HDMI:EDID found DMT format: code 35, 1280x1024p @ 60 Hz (5:4) in standard timing 4
1313730.927: hdmi: HDMI:EDID found DMT format: code 28, 1280x800p @ 60 Hz (16:10) in standard timing 5
1313730.983: hdmi: HDMI:EDID found DMT format: code 47, 1440x900p @ 60 Hz (16:10) in standard timing 6
1313731.039: hdmi: HDMI:EDID found DMT format: code 51, 1600x1200p @ 60 Hz (4:3) in standard timing 7
1313744.054: hdmi: HDMI:EDID parsing v3 CEA extension 0
1313744.096: hdmi: HDMI:EDID monitor support - underscan IT formats:yes, basic audio:yes, yuv444:yes, yuv422:yes, #native DTD:1
1313744.141: hdmi: HDMI:EDID found CEA detail timing format: 720x480p @ 60 Hz (2)
1313744.187: hdmi: HDMI:EDID found CEA detail timing format: 1280x720p @ 50 Hz (19)
1313744.236: hdmi: HDMI:EDID found CEA detail timing format: 1920x1080i @ 50 Hz (20)
1313744.282: hdmi: HDMI:EDID found CEA detail timing format: 720x576p @ 50 Hz (17)
1313744.330: hdmi: HDMI:EDID found CEA detail timing format: 720x576p @ 50 Hz (17)
1313744.368: hdmi: HDMI:EDID found CEA format: code 1, 640x480p @ 60Hz
1313744.406: hdmi: HDMI:EDID found CEA format: code 2, 720x480p @ 60Hz
1313744.444: hdmi: HDMI:EDID found CEA format: code 3, 720x480p @ 60Hz
1313744.482: hdmi: HDMI:EDID found CEA format: code 4, 1280x720p @ 60Hz (native)
1313744.520: hdmi: HDMI:EDID found CEA format: code 5, 1920x1080i @ 60Hz
1313744.555: hdmi: HDMI:EDID found CEA format: code 7, 1440x480i @ 60Hz
1313744.590: hdmi: HDMI:EDID found CEA format: code 16, 1920x1080p @ 60Hz
1313744.628: hdmi: HDMI:EDID found CEA format: code 17, 720x576p @ 50Hz
1313744.663: hdmi: HDMI:EDID found CEA format: code 19, 1280x720p @ 50Hz
1313744.701: hdmi: HDMI:EDID found CEA format: code 20, 1920x1080i @ 50Hz
1313744.738: hdmi: HDMI:EDID found CEA format: code 21, 1440x576i @ 50Hz
1313744.774: hdmi: HDMI:EDID found CEA format: code 31, 1920x1080p @ 50Hz
1313744.811: hdmi: HDMI:EDID found CEA format: code 32, 1920x1080p @ 24Hz
1313744.869: hdmi: HDMI:EDID found audio format 2 channels PCM, sample rate: 32|44|48 kHz, sample size: 16|20|24 bits
1313744.892: hdmi: HDMI:EDID found HDMI VSDB length 5
1313744.922: hdmi: HDMI:EDID HDMI VSDB has physical address 1.0.0.0
1313744.941: hdmi: HDMI:EDID HDMI VSDB has no extension fields
1313744.988: hdmi: HDMI:EDID filtering formats with pixel clock > 162 MHz or h. blanking > 1023
1313745.191: hdmi: HDMI:EDID preferred mode remained as DMT (28) 1280x800p @ 60 Hz with pixel clock 83 MHz
1313745.217: hdmi: HDMI: hotplug attached with HDMI support
Well, I’m not familiar with linux and I don’t know what more to do.
I hope someone will show me the light
EDIT :
I’ve been all night awake trying to find the solution and of course I find it 1 hour after posting on the forum…
Well I had to “Disable GPIO LIRC remote support” in Pi confing and now it’s working.
I don’t know what steps I did where useful or not (modules, asound.conf)
I hope it can help others, maybe a step by step for new install could be useful ?
Using upgrade will eventually cause problems. ALWAYS use dist-upgrade.
Good to know, thanks !
I think that you have possibly followed a couple of strange guides that are either outdated or intended for other Pi distributions.
If you enable the DAC via My OSMC → Pi Config, the GPIO LIRC remote support will be disabled for you automatically and this won’t be an issue. But it seems you set this up manually by editing config.txt.
This is not necessary. By editing config.txt and adding a dtoverlay=, you are getting the Raspberry Pi to load a Device Tree, which will handle module loading for you.
Your system is hosed if you ran this. You need to perform a reinstall. It may seem fine for now but there is now no guarantee future updates will work properly. We will try and make this more clear in the future as it seems this bad piece of advice is spreading.
