See above post again
This will give you some significant problems later down the road. You should rename it back and try as directed above.
Actually, I just tried setting dtparam=audio=off and dtoverlay=hifiberry-digi (without the -overlay) and it makes it working and also remains working after another reboot.
I didnât want to try the apt-get install, as i see rbp2 and I have a Raspberry Pi 3.
EDIT: I guess the problem might be, that the Pi Config interface in My OSMC is setting it incorrectly. I edited mine directly in a text editor over ssh.
Yes â there should be no â-overlayâ in config.txt anymore. It looks like changes in the Raspberry Pi kernel have caused this.
There is no ârbp3â equivalent. The Pi 2 binaries are used on Pi 3 at the time of writing. So this would work fine.
Unfortunately without a HifiBerry and no one willing to reinstall the kernel, I canât verify my suspicions
Reinstalling does not resolve the issue with me.
Changing the overlay file name to hifiberry-dac-overlay.dtbo works.
Please add
dtdebug=1
to /boot/config.txt
and run
sudo vcdbg log msg after a reboot.
I have a fix, but I want to verify that it will work when I push it shortly.
If it still helps, here is a debug-log of the problem: http://paste.osmc.io/lorogojiwe
I have a Pi2 with hifiberry dac+
I can try the dtdebug-thing. What do you need afterwards? Just an info if the problem is fixed, or another debug-log?
I need the output of sudo vcdbg log msg.
This wonât fix the issue, but it will give me a clue and verify whether my fix (which will be ready in an hour or so) will work.
I manually edit the file config.txt and change dtoverlay=hifiberry-digi (without the -overlay).
Now everything works.
Thank you.
Sorry for the long post, this is the output from âsudo vcdbg log msgâ:
001134.379: HDMI:EDID version 1.3, 1 extensions, screen size 16x9 cm
001134.444: HDMI:EDID features - videodef 0x80 !standby !suspend !active off; colour encoding:RGB444|YCbCr422; sRGB is not default colourspace; preferred format is native; does not support GTF
001134.499: HDMI:EDID found preferred CEA detail timing format: 1920x1080p @ 60 Hz (16)
001134.567: HDMI:EDID found DMT detail timing format: 1360x768p @ 60 Hz (39)
001134.609: HDMI:EDID found DMT format: code 4, 640x480p @ 60 Hz in established timing I/II
001134.647: HDMI:EDID found DMT format: code 5, 640x480p @ 72 Hz in established timing I/II
001134.684: HDMI:EDID found DMT format: code 6, 640x480p @ 75 Hz in established timing I/II
001134.722: HDMI:EDID found DMT format: code 9, 800x600p @ 60 Hz in established timing I/II
001134.759: HDMI:EDID found DMT format: code 10, 800x600p @ 72 Hz in established timing I/II
001134.797: HDMI:EDID found DMT format: code 11, 800x600p @ 75 Hz in established timing I/II
001134.837: HDMI:EDID found DMT format: code 16, 1024x768p @ 60 Hz in established timing I/II
001134.876: HDMI:EDID found DMT format: code 17, 1024x768p @ 70 Hz in established timing I/II
001134.912: HDMI:EDID found DMT format: code 18, 1024x768p @ 75 Hz in established timing I/II
001134.954: HDMI:EDID found DMT format: code 36, 1280x1024p @ 75 Hz in established timing I/II
001135.041: HDMI:EDID standard timings block x 8: 0x714F 8100 8140 8180 9500 950F B300 0101
001135.089: HDMI:EDID found DMT format: code 21, 1152x864p @ 75 Hz (4:3) in standard timing 0
001135.137: HDMI:EDID found DMT format: code 28, 1280x800p @ 60 Hz (16:10) in standard timing 1
001135.188: HDMI:EDID found DMT format: code 32, 1280x960p @ 60 Hz (4:3) in standard timing 2
001135.237: HDMI:EDID found DMT format: code 35, 1280x1024p @ 60 Hz (5:4) in standard timing 3
001135.290: HDMI:EDID found DMT format: code 47, 1440x900p @ 60 Hz (16:10) in standard timing 4
001135.342: HDMI:EDID found DMT format: code 48, 1440x900p @ 75 Hz (16:10) in standard timing 5
001135.394: HDMI:EDID found DMT format: code 58, 1680x1050p @ 60 Hz (16:10) in standard timing 6
001148.408: HDMI:EDID parsing v3 CEA extension 0
001148.447: HDMI:EDID monitor support - underscan IT formats:yes, basic audio:yes, yuv444:yes, yuv422:yes, #native DTD:1
001148.490: HDMI:EDID found CEA detail timing format: 1280x720p @ 60 Hz (4)
001148.535: HDMI:EDID found CEA detail timing format: 1280x720p @ 50 Hz (19)
001148.576: HDMI:EDID found CEA detail timing format: 1920x1080i @ 60 Hz (5)
001148.618: HDMI:EDID found CEA detail timing format: 1920x1080i @ 50 Hz (20)
001148.653: HDMI:EDID found CEA format: code 16, 1920x1080p @ 60Hz (native)
001148.687: HDMI:EDID found CEA format: code 31, 1920x1080p @ 50Hz
001148.718: HDMI:EDID found CEA format: code 4, 1280x720p @ 60Hz
001148.752: HDMI:EDID found CEA format: code 19, 1280x720p @ 50Hz
001148.783: HDMI:EDID found CEA format: code 5, 1920x1080i @ 60Hz
001148.816: HDMI:EDID found CEA format: code 20, 1920x1080i @ 50Hz
001148.847: HDMI:EDID found CEA format: code 3, 720x480p @ 60Hz
001148.881: HDMI:EDID found CEA format: code 18, 720x576p @ 50Hz
001148.915: HDMI:EDID found CEA format: code 32, 1920x1080p @ 24Hz
001148.947: HDMI:EDID found CEA format: code 33, 1920x1080p @ 25Hz
001148.981: HDMI:EDID found CEA format: code 34, 1920x1080p @ 30Hz
001149.034: HDMI:EDID found audio format 2 channels PCM, sample rate: 32|44|48 kHz, sample size: 16|20|24 bits
001149.054: HDMI:EDID found Video Capability DB length 2
001149.081: HDMI:EDID video capability: CE:3 IT:3 PT:0 QS:0
001149.108: HDMI:EDID extended data block tag 0x05 length 3 not supported
001149.125: HDMI:EDID found HDMI VSDB length 7
001149.152: HDMI:EDID HDMI VSDB has physical address 1.0.0.0
001149.174: HDMI:EDID HDMI VSDB supports AI:yes, dual link DVI:no
001149.205: HDMI:EDID HDMI VSDB deep colour support - 48-bit:no 36-bit:yes 30-bit:yes DC_yuv444:yes
001149.224: HDMI:EDID HDMI VSDB max TMDS clock 225 MHz
001149.241: HDMI:EDID HDMI VSDB has no latency information
001149.286: HDMI:EDID filtering formats with pixel clock > 162 MHz or h. blanking > 1023
001149.484: HDMI:EDID preferred mode remained as CEA (16) 1920x1080p @ 60 Hz with pixel clock 148 MHz
001160.274: HDMI:Setting property pixel encoding to Default
001160.295: HDMI:Setting property pixel clock type to PAL
001160.314: HDMI:Setting property content type flag to No data
001160.334: HDMI:Setting property fuzzy format match to enabled
001357.506: hdmi: HDMI:>>>>>>>>>>>>>Rx sensed, reading EDID<<<<<<<<<<<<<
001369.643: hdmi: HDMI:EDID version 1.3, 1 extensions, screen size 16x9 cm
001369.713: hdmi: HDMI:EDID features - videodef 0x80 !standby !suspend !active off; colour encoding:RGB444|YCbCr422; sRGB is not default colourspace; preferred format is native; does not support GTF
001369.777: hdmi: HDMI:EDID found preferred CEA detail timing format: 1920x1080p @ 60 Hz (16)
001369.852: hdmi: HDMI:EDID found DMT detail timing format: 1360x768p @ 60 Hz (39)
001369.894: hdmi: HDMI:EDID found DMT format: code 4, 640x480p @ 60 Hz in established timing I/II
001369.935: hdmi: HDMI:EDID found DMT format: code 5, 640x480p @ 72 Hz in established timing I/II
001369.978: hdmi: HDMI:EDID found DMT format: code 6, 640x480p @ 75 Hz in established timing I/II
001370.017: hdmi: HDMI:EDID found DMT format: code 9, 800x600p @ 60 Hz in established timing I/II
001370.059: hdmi: HDMI:EDID found DMT format: code 10, 800x600p @ 72 Hz in established timing I/II
001370.100: hdmi: HDMI:EDID found DMT format: code 11, 800x600p @ 75 Hz in established timing I/II
001370.141: hdmi: HDMI:EDID found DMT format: code 16, 1024x768p @ 60 Hz in established timing I/II
001370.183: hdmi: HDMI:EDID found DMT format: code 17, 1024x768p @ 70 Hz in established timing I/II
001370.225: hdmi: HDMI:EDID found DMT format: code 18, 1024x768p @ 75 Hz in established timing I/II
001370.268: hdmi: HDMI:EDID found DMT format: code 36, 1280x1024p @ 75 Hz in established timing I/II
001370.359: hdmi: HDMI:EDID standard timings block x 8: 0x714F 8100 8140 8180 9500 950F B300 0101
001370.414: hdmi: HDMI:EDID found DMT format: code 21, 1152x864p @ 75 Hz (4:3) in standard timing 0
001370.469: hdmi: HDMI:EDID found DMT format: code 28, 1280x800p @ 60 Hz (16:10) in standard timing 1
001370.520: hdmi: HDMI:EDID found DMT format: code 32, 1280x960p @ 60 Hz (4:3) in standard timing 2
001370.575: hdmi: HDMI:EDID found DMT format: code 35, 1280x1024p @ 60 Hz (5:4) in standard timing 3
001370.629: hdmi: HDMI:EDID found DMT format: code 47, 1440x900p @ 60 Hz (16:10) in standard timing 4
001370.682: hdmi: HDMI:EDID found DMT format: code 48, 1440x900p @ 75 Hz (16:10) in standard timing 5
001370.740: hdmi: HDMI:EDID found DMT format: code 58, 1680x1050p @ 60 Hz (16:10) in standard timing 6
001383.756: hdmi: HDMI:EDID parsing v3 CEA extension 0
001383.797: hdmi: HDMI:EDID monitor support - underscan IT formats:yes, basic audio:yes, yuv444:yes, yuv422:yes, #native DTD:1
001383.842: hdmi: HDMI:EDID found CEA detail timing format: 1280x720p @ 60 Hz (4)
001383.889: hdmi: HDMI:EDID found CEA detail timing format: 1280x720p @ 50 Hz (19)
001383.936: hdmi: HDMI:EDID found CEA detail timing format: 1920x1080i @ 60 Hz (5)
001383.985: hdmi: HDMI:EDID found CEA detail timing format: 1920x1080i @ 50 Hz (20)
001384.026: hdmi: HDMI:EDID found CEA format: code 16, 1920x1080p @ 60Hz (native)
001384.061: hdmi: HDMI:EDID found CEA format: code 31, 1920x1080p @ 50Hz
001384.098: hdmi: HDMI:EDID found CEA format: code 4, 1280x720p @ 60Hz
001384.134: hdmi: HDMI:EDID found CEA format: code 19, 1280x720p @ 50Hz
001384.171: hdmi: HDMI:EDID found CEA format: code 5, 1920x1080i @ 60Hz
001384.208: hdmi: HDMI:EDID found CEA format: code 20, 1920x1080i @ 50Hz
001384.245: hdmi: HDMI:EDID found CEA format: code 3, 720x480p @ 60Hz
001384.280: hdmi: HDMI:EDID found CEA format: code 18, 720x576p @ 50Hz
001384.316: hdmi: HDMI:EDID found CEA format: code 32, 1920x1080p @ 24Hz
001384.353: hdmi: HDMI:EDID found CEA format: code 33, 1920x1080p @ 25Hz
001384.388: hdmi: HDMI:EDID found CEA format: code 34, 1920x1080p @ 30Hz
001384.446: hdmi: HDMI:EDID found audio format 2 channels PCM, sample rate: 32|44|48 kHz, sample size: 16|20|24 bits
001384.468: hdmi: HDMI:EDID found Video Capability DB length 2
001384.498: hdmi: HDMI:EDID video capability: CE:3 IT:3 PT:0 QS:0
001384.527: hdmi: HDMI:EDID extended data block tag 0x05 length 3 not supported
001384.549: hdmi: HDMI:EDID found HDMI VSDB length 7
001384.577: hdmi: HDMI:EDID HDMI VSDB has physical address 1.0.0.0
001384.600: hdmi: HDMI:EDID HDMI VSDB supports AI:yes, dual link DVI:no
001384.634: hdmi: HDMI:EDID HDMI VSDB deep colour support - 48-bit:no 36-bit:yes 30-bit:yes DC_yuv444:yes
001384.658: hdmi: HDMI:EDID HDMI VSDB max TMDS clock 225 MHz
001384.677: hdmi: HDMI:EDID HDMI VSDB has no latency information
001384.725: hdmi: HDMI:EDID filtering formats with pixel clock > 162 MHz or h. blanking > 1023
001384.927: hdmi: HDMI:EDID preferred mode remained as CEA (16) 1920x1080p @ 60 Hz with pixel clock 148 MHz
001384.950: hdmi: HDMI: hotplug attached with HDMI support
001385.018: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
001387.484: hdmi: HDMI: power_on to CEA mode 1080p60
001390.655: hdmi: HDMI: Action callback added to queue to happen at frame 2
001390.677: hdmi: HDMI: Action stop_3d_mode added to queue to happen at frame 2
001390.700: hdmi: HDMI: Action unmute added to queue to happen at frame 3
001440.753: *** Restart logging
001442.027: Read command line from file âcmdline.txtâ
root=/dev/mmcblk0p2 rootfstype=ext4 rootwait quiet osmcdev=rbp2
001933.566: Loading âkernel.imgâ to 0x8000 size 0x70d8e0
001947.612: No kernel trailer (run mkknlimg to fix) - assuming DT-capable
001950.196: Loading âbcm2709-rpi-2-b.dtbâ to 0x7158e0 size 0x38e3
001960.513: dtdebug: delete_node(/local_fixups)
001966.354: dtdebug: /aliases:i2c_vc=i2c0
001971.464: dtdebug: /symbols:i2c_vc=i2c0
001975.735: dtdebug: /overrides:i2c_vc=i2c0
001983.875: dtdebug: /overrides:i2c_vc_baudrate=i2c0_baudrate
001986.804: dtdebug: /aliases:i2c=i2c1
001992.114: dtdebug: /symbols:i2c=i2c1
001996.469: dtdebug: /overrides:i2c=i2c1
001999.431: dtdebug: /aliases:i2c_arm=i2c1
002004.773: dtdebug: /symbols:i2c_arm=i2c1
002009.177: dtdebug: /overrides:i2c_arm=i2c1
002017.488: dtdebug: /overrides:i2c_baudrate=i2c1_baudrate
002025.820: dtdebug: /overrides:i2c_arm_baudrate=i2c1_baudrate
002025.838: dtparam: pwr_led_gpio=35
002028.709: dtdebug: Found override pwr_led_gpio
002028.754: dtdebug: override pwr_led_gpio: cell target gpios @ offset 4 (size 4)
002034.762: dtparam: uart0_clkrate=3000000
002037.470: dtdebug: Found override uart0_clkrate
002037.519: dtdebug: override uart0_clkrate: cell target clock-frequency @ offset 0 (size 4)
002045.415: dterror: not a valid FDT - err -9
002045.426: Failed to load HAT overlay
002049.581: dtdebug: Failed to open overlay file âoverlays/hifiberry-dacplus-overlay.dtboâ
002053.534: dtdebug: Failed to open overlay file âoverlays/hifiberry-dacplus-overlay-overlay.dtbâ
002057.496: dtdebug: Failed to open overlay file âoverlays/hifiberry-dacplus-overlay.dtbâ
002057.510: Failed to load overlay âhifiberry-dacplus-overlayâ
002057.561: dtparam: audio=off
002060.462: dtdebug: Found override audio
002060.497: dtdebug: override audio: string target âstatusâ
002071.473: dtdebug: /aliases:serial0=uart0
002074.516: dtdebug: /aliases:serial1=uart1
002122.606: dtparam: arm_freq=900000000
002125.453: dtdebug: Found override arm_freq
002125.502: dtdebug: override arm_freq: cell target clock-frequency @ offset 0 (size 4)
002134.771: dtdebug: override arm_freq: cell target clock-frequency @ offset 0 (size 4)
002144.099: dtdebug: override arm_freq: cell target clock-frequency @ offset 0 (size 4)
002153.553: dtdebug: override arm_freq: cell target clock-frequency @ offset 0 (size 4)
002163.098: dtparam: core_freq=250000000
002166.052: dtdebug: Found override core_freq
002166.098: dtdebug: override core_freq: cell target clock-frequency @ offset 0 (size 4)
002173.759: dtparam: cache_line_size=64
002176.595: dtdebug: Found override cache_line_size
002176.642: dtdebug: override cache_line_size: cell target cache-line-size @ offset 0 (size 4)
002183.264: dtdebug: delete_node(/hat)
002209.833: Device tree loaded to 0x2efec100 (size 0x3e5c)
002213.006: gpioman: gpioman_get_pin_num: pin SDCARD_CONTROL_POWER not defined
004218.812: vchiq_core: vchiq_init_state: slot_zero = 0xee880000, is_master = 1
004223.121: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
004228.150: TV service:host side not connected, dropping notification 0x00000002, 0x00000001, 0x00000010
013591.604: hdmi: HDMI:Setting property pixel clock type to PAL
013591.726: hdmi: HDMI: power_on to CEA mode 1080p60
013591.774: hdmi: HDMI: Action detach added to queue to happen at frame 725
013591.796: hdmi: HDMI: Action change_mode added to queue to happen at frame 725
013591.820: hdmi: HDMI: Action attach added to queue to happen at frame 725
013591.844: hdmi: HDMI: Action start_mode added to queue to happen at frame 725
013591.867: hdmi: HDMI: Action callback added to queue to happen at frame 727
013591.892: hdmi: HDMI: Action stop_3d_mode added to queue to happen at frame 727
013591.915: hdmi: HDMI: Action unmute added to queue to happen at frame 728
osmc@osmc:~$
Here you go:
osmc@osmc:~$ sudo vcdbg log msg
001188.055: HDMI:EDID version 1.3, 1 extensions, screen size 160x90 cm
001188.120: HDMI:EDID features - videodef 0x80 !standby !suspend !active off; colour encoding:RGB444|YCbCr422; sRGB is not default colourspace; preferred format is native; does not support GTF
001188.202: HDMI:EDID found preferred DMT detail timing format: 1360x768p @ 60 Hz (39)
001188.244: HDMI:EDID found CEA detail timing format: 1280x720p @ 60 Hz (4)
001188.283: HDMI:EDID found DMT format: code 4, 640x480p @ 60 Hz in established timing I/II
001188.323: HDMI:EDID found DMT format: code 9, 800x600p @ 60 Hz in established timing I/II
001188.361: HDMI:EDID found DMT format: code 16, 1024x768p @ 60 Hz in established timing I/II
001188.456: HDMI:EDID standard timings block x 8: 0x0101 0101 0101 0101 0101 0101 0101 0101
001201.469: HDMI:EDID parsing v3 CEA extension 0
001201.507: HDMI:EDID monitor support - underscan IT formats:no, basic audio:yes, yuv444:yes, yuv422:yes, #native DTD:0
001201.551: HDMI:EDID found CEA detail timing format: 1920x1080i @ 50 Hz (20)
001201.594: HDMI:EDID found CEA detail timing format: 1920x1080i @ 60 Hz (5)
001201.638: HDMI:EDID found CEA detail timing format: 1280x720p @ 50 Hz (19)
001201.679: HDMI:EDID found CEA detail timing format: 1280x720p @ 60 Hz (4)
001201.722: HDMI:EDID found CEA detail timing format: 720x576p @ 50 Hz (17)
001201.758: HDMI:EDID found CEA format: code 20, 1920x1080i @ 50Hz
001201.790: HDMI:EDID found CEA format: code 19, 1280x720p @ 50Hz
001201.823: HDMI:EDID found CEA format: code 18, 720x576p @ 50Hz
001201.856: HDMI:EDID found CEA format: code 17, 720x576p @ 50Hz
001201.889: HDMI:EDID found CEA format: code 22, 1440x576i @ 50Hz
001201.922: HDMI:EDID found CEA format: code 21, 1440x576i @ 50Hz
001201.956: HDMI:EDID found CEA format: code 5, 1920x1080i @ 60Hz
001201.989: HDMI:EDID found CEA format: code 4, 1280x720p @ 60Hz
001202.022: HDMI:EDID found CEA format: code 3, 720x480p @ 60Hz
001202.053: HDMI:EDID found CEA format: code 2, 720x480p @ 60Hz
001202.085: HDMI:EDID found CEA format: code 7, 1440x480i @ 60Hz
001202.117: HDMI:EDID found CEA format: code 6, 1440x480i @ 60Hz
001202.150: HDMI:EDID found CEA format: code 1, 640x480p @ 60Hz
001202.202: HDMI:EDID found audio format 2 channels PCM, sample rate: 32|44|48 kHz, sample size: 16|20|24 bits
001202.219: HDMI:EDID found HDMI VSDB length 6
001202.244: HDMI:EDID HDMI VSDB has physical address 3.0.0.0
001202.264: HDMI:EDID HDMI VSDB supports AI:yes, dual link DVI:no
001202.292: HDMI:EDID HDMI VSDB deep colour support - 48-bit:no 36-bit:no 30-bit:no DC_yuv444:no
001202.310: HDMI:EDID HDMI VSDB has no latency information
001202.354: HDMI:EDID filtering formats with pixel clock > 162 MHz or h. blanking > 1023
001202.496: HDMI:EDID preferred mode remained as DMT (39) 1360x768p @ 60 Hz with pixel clock 85 MHz
001215.949: HDMI:Setting property pixel encoding to Default
001215.970: HDMI:Setting property pixel clock type to PAL
001215.989: HDMI:Setting property content type flag to No data
001216.008: HDMI:Setting property fuzzy format match to enabled
001404.097: hdmi: HDMI:>>>>>>>>>>>>>Rx sensed, reading EDID<<<<<<<<<<<<<
001416.237: hdmi: HDMI:EDID version 1.3, 1 extensions, screen size 160x90 cm
001416.308: hdmi: HDMI:EDID features - videodef 0x80 !standby !suspend !active off; colour encoding:RGB444|YCbCr422; sRGB is not default colourspace; preferred format is native; does not support GTF
001416.397: hdmi: HDMI:EDID found preferred DMT detail timing format: 1360x768p @ 60 Hz (39)
001416.444: hdmi: HDMI:EDID found CEA detail timing format: 1280x720p @ 60 Hz (4)
001416.489: hdmi: HDMI:EDID found DMT format: code 4, 640x480p @ 60 Hz in established timing I/II
001416.531: hdmi: HDMI:EDID found DMT format: code 9, 800x600p @ 60 Hz in established timing I/II
001416.575: hdmi: HDMI:EDID found DMT format: code 16, 1024x768p @ 60 Hz in established timing I/II
001416.670: hdmi: HDMI:EDID standard timings block x 8: 0x0101 0101 0101 0101 0101 0101 0101 0101
001429.689: hdmi: HDMI:EDID parsing v3 CEA extension 0
001429.732: hdmi: HDMI:EDID monitor support - underscan IT formats:no, basic audio:yes, yuv444:yes, yuv422:yes, #native DTD:0
001429.783: hdmi: HDMI:EDID found CEA detail timing format: 1920x1080i @ 50 Hz (20)
001429.827: hdmi: HDMI:EDID found CEA detail timing format: 1920x1080i @ 60 Hz (5)
001429.876: hdmi: HDMI:EDID found CEA detail timing format: 1280x720p @ 50 Hz (19)
001429.922: hdmi: HDMI:EDID found CEA detail timing format: 1280x720p @ 60 Hz (4)
001429.970: hdmi: HDMI:EDID found CEA detail timing format: 720x576p @ 50 Hz (17)
001430.007: hdmi: HDMI:EDID found CEA format: code 20, 1920x1080i @ 50Hz
001430.044: hdmi: HDMI:EDID found CEA format: code 19, 1280x720p @ 50Hz
001430.080: hdmi: HDMI:EDID found CEA format: code 18, 720x576p @ 50Hz
001430.116: hdmi: HDMI:EDID found CEA format: code 17, 720x576p @ 50Hz
001430.153: hdmi: HDMI:EDID found CEA format: code 22, 1440x576i @ 50Hz
001430.188: hdmi: HDMI:EDID found CEA format: code 21, 1440x576i @ 50Hz
001430.223: hdmi: HDMI:EDID found CEA format: code 5, 1920x1080i @ 60Hz
001430.257: hdmi: HDMI:EDID found CEA format: code 4, 1280x720p @ 60Hz
001430.292: hdmi: HDMI:EDID found CEA format: code 3, 720x480p @ 60Hz
001430.328: hdmi: HDMI:EDID found CEA format: code 2, 720x480p @ 60Hz
001430.365: hdmi: HDMI:EDID found CEA format: code 7, 1440x480i @ 60Hz
001430.401: hdmi: HDMI:EDID found CEA format: code 6, 1440x480i @ 60Hz
001430.437: hdmi: HDMI:EDID found CEA format: code 1, 640x480p @ 60Hz
001430.495: hdmi: HDMI:EDID found audio format 2 channels PCM, sample rate: 32|44|48 kHz, sample size: 16|20|24 bits
001430.518: hdmi: HDMI:EDID found HDMI VSDB length 6
001430.548: hdmi: HDMI:EDID HDMI VSDB has physical address 3.0.0.0
001430.573: hdmi: HDMI:EDID HDMI VSDB supports AI:yes, dual link DVI:no
001430.607: hdmi: HDMI:EDID HDMI VSDB deep colour support - 48-bit:no 36-bit:no 30-bit:no DC_yuv444:no
001430.626: hdmi: HDMI:EDID HDMI VSDB has no latency information
001430.672: hdmi: HDMI:EDID filtering formats with pixel clock > 162 MHz or h. blanking > 1023
001430.818: hdmi: HDMI:EDID preferred mode remained as DMT (39) 1360x768p @ 60 Hz with pixel clock 85 MHz
001430.840: hdmi: HDMI: hotplug attached with HDMI support
001430.907: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
001433.375: hdmi: HDMI: power_on to DMT mode 1360x768@60
001436.547: hdmi: HDMI: Action callback added to queue to happen at frame 0
001453.635: *** Restart logging
001455.135: Read command line from file 'cmdline.txt'
001976.667: Loading 'kernel.img' to 0x8000 size 0x70d8e0
001990.808: No kernel trailer (run mkknlimg to fix) - assuming DT-capable
001993.362: Loading 'bcm2710-rpi-3-b.dtb' to 0x7158e0 size 0x3b81
002004.134: dtdebug: delete_node(/__local_fixups__)
002010.271: dtdebug: /aliases:i2c_vc=i2c0
002015.715: dtdebug: /__symbols__:i2c_vc=i2c0
002020.120: dtdebug: /__overrides__:i2c_vc=i2c0
002028.573: dtdebug: /__overrides__:i2c_vc_baudrate=i2c0_baudrate
002031.617: dtdebug: /aliases:i2c=i2c1
002037.238: dtdebug: /__symbols__:i2c=i2c1
002041.725: dtdebug: /__overrides__:i2c=i2c1
002044.798: dtdebug: /aliases:i2c_arm=i2c1
002050.449: dtdebug: /__symbols__:i2c_arm=i2c1
002054.970: dtdebug: /__overrides__:i2c_arm=i2c1
002063.588: dtdebug: /__overrides__:i2c_baudrate=i2c1_baudrate
002072.274: dtdebug: /__overrides__:i2c_arm_baudrate=i2c1_baudrate
002072.301: dtparam: uart0_clkrate=48000000
002075.169: dtdebug: Found override uart0_clkrate
002075.219: dtdebug: override uart0_clkrate: cell target clock-frequency @ offset 0 (size 4)
002089.805: dtdebug: Opened overlay file 'overlays/hifiberry-digi.dtbo'
002101.616: Loaded overlay 'hifiberry-digi'
002101.648: dtparam: audio=off
002101.802: dtdebug: /__overrides__ node not found
002104.843: dtdebug: Found override audio
002104.876: dtdebug: override audio: string target 'status'
002112.547: dtdebug: Found fragment 0 (offset 36)
002117.103: dtdebug: merge_fragment(/soc/i2s@7e203000,/fragment@0/__overlay__)
002117.130: dtdebug: +prop(status)
002118.592: dtdebug: merge_fragment() end
002118.650: dtdebug: Found fragment 1 (offset 112)
002126.342: dtdebug: merge_fragment(/soc/i2c@7e804000,/fragment@1/__overlay__)
002126.368: dtdebug: +prop(#address-cells)
002127.496: dtdebug: +prop(#size-cells)
002128.631: dtdebug: +prop(status)
002133.444: dtdebug: merge_fragment(/soc/i2c@7e804000/wm8804@3b,/fragment@1/__overlay__/wm8804@3b)
002133.472: dtdebug: +prop(#sound-dai-cells)
002134.701: dtdebug: +prop(compatible)
002135.809: dtdebug: +prop(reg)
002136.985: dtdebug: +prop(status)
002138.206: dtdebug: merge_fragment() end
002138.234: dtdebug: merge_fragment() end
002138.315: dtdebug: Found fragment 2 (offset 316)
002148.480: dtdebug: merge_fragment(/soc/sound,/fragment@2/__overlay__)
002148.506: dtdebug: +prop(compatible)
002149.391: dtdebug: +prop(i2s-controller)
002150.684: dtdebug: +prop(status)
002151.560: dtdebug: merge_fragment() end
002155.657: dtdebug: /aliases:serial0=uart1
002158.766: dtdebug: /aliases:serial1=uart0
002158.870: dtparam: uart1=off
002161.823: dtdebug: Found override uart1
002161.857: dtdebug: override uart1: string target 'status'
002219.477: dtparam: arm_freq=1200000000
002222.499: dtdebug: Found override arm_freq
002222.549: dtdebug: override arm_freq: cell target clock-frequency @ offset 0 (size 4)
002232.310: dtdebug: override arm_freq: cell target clock-frequency @ offset 0 (size 4)
002242.205: dtdebug: override arm_freq: cell target clock-frequency @ offset 0 (size 4)
002252.140: dtdebug: override arm_freq: cell target clock-frequency @ offset 0 (size 4)
002262.251: dtparam: core_freq=500000000
002265.407: dtdebug: Found override core_freq
002265.454: dtdebug: override core_freq: cell target clock-frequency @ offset 0 (size 4)
002273.744: dtparam: cache_line_size=64
002276.771: dtdebug: Found override cache_line_size
002276.818: dtdebug: override cache_line_size: cell target cache-line-size @ offset 0 (size 4)
002283.938: dtdebug: delete_node(/hat)
002291.654: Device tree loaded to 0x2efebf00 (size 0x4092)
002293.921: gpioman: gpioman_get_pin_num: pin SDCARD_CONTROL_POWER not defined
003970.108: vchiq_core: vchiq_init_state: slot_zero = 0xee880000, is_master = 1
003974.251: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
003979.142: TV service:host side not connected, dropping notification 0x00000002, 0x00000002, 0x00000027
023540.374: hdmi: HDMI:Setting property pixel clock type to PAL
023540.444: hdmi: HDMI: power_on to DMT mode 1360x768@60
023540.472: hdmi: HDMI: Action detach added to queue to happen at frame 1317
023540.484: hdmi: HDMI: Action change_mode added to queue to happen at frame 1317
023540.497: hdmi: HDMI: Action attach added to queue to happen at frame 1317
023540.510: hdmi: HDMI: Action start_mode added to queue to happen at frame 1317
023540.524: hdmi: HDMI: Action callback added to queue to happen at frame 1319
023540.538: hdmi: HDMI: Action stop_3d_mode added to queue to happen at frame 1319
023540.551: hdmi: HDMI: Action unmute added to queue to happen at frame 1320
001169.548: HDMI:EDID version 1.3, 1 extensions, unknown aspect ratio
001169.613: HDMI:EDID features - videodef 0x80 !standby !suspend !active off; colour encoding:RGB444|YCbCr422; sRGB is not default colourspace; preferred format is native; does not support GTF
001169.674: HDMI:EDID found preferred CEA detail timing format: 1280x720p @ 50 Hz (19)
001169.717: HDMI:EDID found CEA detail timing format: 1280x720p @ 60 Hz (4)
001169.817: HDMI:EDID standard timings block x 8: 0x0101 0101 0101 0101 0101 0101 0101 0101
001182.829: HDMI:EDID parsing v3 CEA extension 0
001182.867: HDMI:EDID monitor support - underscan IT formats:no, basic audio:yes, yuv444:yes, yuv422:yes, #native DTD:2
001182.915: HDMI:EDID found CEA detail timing format: 1920x1080p @ 50 Hz (31)
001182.960: HDMI:EDID found CEA detail timing format: 1920x1080p @ 60 Hz (16)
001183.005: HDMI:EDID found CEA detail timing format: 1920x1080i @ 50 Hz (20)
001183.047: HDMI:EDID found CEA detail timing format: 1920x1080i @ 60 Hz (5)
001183.082: HDMI:EDID found CEA format: code 19, 1280x720p @ 50Hz (native)
001183.114: HDMI:EDID found CEA format: code 4, 1280x720p @ 60Hz (native)
001183.147: HDMI:EDID found CEA format: code 31, 1920x1080p @ 50Hz
001183.181: HDMI:EDID found CEA format: code 16, 1920x1080p @ 60Hz
001183.215: HDMI:EDID found CEA format: code 20, 1920x1080i @ 50Hz
001183.248: HDMI:EDID found CEA format: code 5, 1920x1080i @ 60Hz
001183.281: HDMI:EDID found CEA format: code 32, 1920x1080p @ 24Hz
001183.313: HDMI:EDID found CEA format: code 18, 720x576p @ 50Hz
001183.346: HDMI:EDID found CEA format: code 3, 720x480p @ 60Hz
001183.378: HDMI:EDID found CEA format: code 17, 720x576p @ 50Hz
001183.409: HDMI:EDID found CEA format: code 2, 720x480p @ 60Hz
001183.443: HDMI:EDID found CEA format: code 22, 1440x576i @ 50Hz
001183.476: HDMI:EDID found CEA format: code 7, 1440x480i @ 60Hz
001183.510: HDMI:EDID found CEA format: code 21, 1440x576i @ 50Hz
001183.542: HDMI:EDID found CEA format: code 6, 1440x480i @ 60Hz
001183.573: HDMI:EDID found CEA format: code 1, 640x480p @ 60Hz
001183.624: HDMI:EDID found audio format 2 channels PCM, sample rate: 32|44|48 kHz, sample size: 16 bits
001183.643: HDMI:EDID found HDMI VSDB length 8
001183.670: HDMI:EDID HDMI VSDB has physical address 1.0.0.0
001183.692: HDMI:EDID HDMI VSDB supports AI:yes, dual link DVI:no
001183.723: HDMI:EDID HDMI VSDB deep colour support - 48-bit:no 36-bit:yes 30-bit:yes DC_yuv444:yes
001183.741: HDMI:EDID HDMI VSDB max TMDS clock 190 MHz
001183.759: HDMI:EDID HDMI VSDB does not support content type
001183.792: HDMI:EDID extended data block tag 0x05 length 3 not supported
001183.831: HDMI:EDID filtering formats with pixel clock > 162 MHz or h. blanking > 1023
001183.973: HDMI:EDID preferred mode remained as CEA (19) 1280x720p @ 50 Hz with pixel clock 74 MHz
001195.418: HDMI:Setting property pixel encoding to Default
001195.439: HDMI:Setting property pixel clock type to PAL
001195.458: HDMI:Setting property content type flag to No data
001195.478: HDMI:Setting property fuzzy format match to enabled
001392.575: hdmi: HDMI:>>>>>>>>>>>>>Rx sensed, reading EDID<<<<<<<<<<<<<
001404.707: hdmi: HDMI:EDID version 1.3, 1 extensions, unknown aspect ratio
001404.777: hdmi: HDMI:EDID features - videodef 0x80 !standby !suspend !active off; colour encoding:RGB444|YCbCr422; sRGB is not default colourspace; preferred format is native; does not support GTF
001404.841: hdmi: HDMI:EDID found preferred CEA detail timing format: 1280x720p @ 50 Hz (19)
001404.885: hdmi: HDMI:EDID found CEA detail timing format: 1280x720p @ 60 Hz (4)
001404.985: hdmi: HDMI:EDID standard timings block x 8: 0x0101 0101 0101 0101 0101 0101 0101 0101
001418.002: hdmi: HDMI:EDID parsing v3 CEA extension 0
001418.045: hdmi: HDMI:EDID monitor support - underscan IT formats:no, basic audio:yes, yuv444:yes, yuv422:yes, #native DTD:2
001418.099: hdmi: HDMI:EDID found CEA detail timing format: 1920x1080p @ 50 Hz (31)
001418.146: hdmi: HDMI:EDID found CEA detail timing format: 1920x1080p @ 60 Hz (16)
001418.195: hdmi: HDMI:EDID found CEA detail timing format: 1920x1080i @ 50 Hz (20)
001418.240: hdmi: HDMI:EDID found CEA detail timing format: 1920x1080i @ 60 Hz (5)
001418.280: hdmi: HDMI:EDID found CEA format: code 19, 1280x720p @ 50Hz (native)
001418.318: hdmi: HDMI:EDID found CEA format: code 4, 1280x720p @ 60Hz (native)
001418.356: hdmi: HDMI:EDID found CEA format: code 31, 1920x1080p @ 50Hz
001418.391: hdmi: HDMI:EDID found CEA format: code 16, 1920x1080p @ 60Hz
001418.429: hdmi: HDMI:EDID found CEA format: code 20, 1920x1080i @ 50Hz
001418.465: hdmi: HDMI:EDID found CEA format: code 5, 1920x1080i @ 60Hz
001418.503: hdmi: HDMI:EDID found CEA format: code 32, 1920x1080p @ 24Hz
001418.540: hdmi: HDMI:EDID found CEA format: code 18, 720x576p @ 50Hz
001418.574: hdmi: HDMI:EDID found CEA format: code 3, 720x480p @ 60Hz
001418.611: hdmi: HDMI:EDID found CEA format: code 17, 720x576p @ 50Hz
001418.647: hdmi: HDMI:EDID found CEA format: code 2, 720x480p @ 60Hz
001418.682: hdmi: HDMI:EDID found CEA format: code 22, 1440x576i @ 50Hz
001418.718: hdmi: HDMI:EDID found CEA format: code 7, 1440x480i @ 60Hz
001418.754: hdmi: HDMI:EDID found CEA format: code 21, 1440x576i @ 50Hz
001418.791: hdmi: HDMI:EDID found CEA format: code 6, 1440x480i @ 60Hz
001418.827: hdmi: HDMI:EDID found CEA format: code 1, 640x480p @ 60Hz
001418.880: hdmi: HDMI:EDID found audio format 2 channels PCM, sample rate: 32|44|48 kHz, sample size: 16 bits
001418.901: hdmi: HDMI:EDID found HDMI VSDB length 8
001418.929: hdmi: HDMI:EDID HDMI VSDB has physical address 1.0.0.0
001418.952: hdmi: HDMI:EDID HDMI VSDB supports AI:yes, dual link DVI:no
001418.986: hdmi: HDMI:EDID HDMI VSDB deep colour support - 48-bit:no 36-bit:yes 30-bit:yes DC_yuv444:yes
001419.010: hdmi: HDMI:EDID HDMI VSDB max TMDS clock 190 MHz
001419.030: hdmi: HDMI:EDID HDMI VSDB does not support content type
001419.066: hdmi: HDMI:EDID extended data block tag 0x05 length 3 not supported
001419.109: hdmi: HDMI:EDID filtering formats with pixel clock > 162 MHz or h. blanking > 1023
001419.254: hdmi: HDMI:EDID preferred mode remained as CEA (19) 1280x720p @ 50 Hz with pixel clock 74 MHz
001419.277: hdmi: HDMI: hotplug attached with HDMI support
001419.345: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
001421.808: hdmi: HDMI: power_on to CEA mode 720p50
001424.979: hdmi: HDMI: Action callback added to queue to happen at frame 2
001425.003: hdmi: HDMI: Action stop_3d_mode added to queue to happen at frame 2
001425.025: hdmi: HDMI: Action unmute added to queue to happen at frame 3
001504.896: *** Restart logging
001506.662: Read command line from file âcmdline.txtâ
002055.364: Loading âkernel.imgâ to 0x8000 size 0x70d8e0
002059.013: No kernel trailer (run mkknlimg to fix) - assuming DT-capable
002062.106: Loading âbcm2709-rpi-2-b.dtbâ to 0x7158e0 size 0x38e3
002072.397: dtdebug: delete_node(/local_fixups)
002078.234: dtdebug: /aliases:i2c_vc=i2c0
002083.370: dtdebug: /symbols:i2c_vc=i2c0
002087.632: dtdebug: /overrides:i2c_vc=i2c0
002095.752: dtdebug: /overrides:i2c_vc_baudrate=i2c0_baudrate
002098.679: dtdebug: /aliases:i2c=i2c1
002103.982: dtdebug: /symbols:i2c=i2c1
002108.336: dtdebug: /overrides:i2c=i2c1
002111.296: dtdebug: /aliases:i2c_arm=i2c1
002116.624: dtdebug: /symbols:i2c_arm=i2c1
002121.004: dtdebug: /overrides:i2c_arm=i2c1
002129.329: dtdebug: /overrides:i2c_baudrate=i2c1_baudrate
002137.670: dtdebug: /overrides:i2c_arm_baudrate=i2c1_baudrate
002137.690: dtparam: pwr_led_gpio=35
002140.555: dtdebug: Found override pwr_led_gpio
002140.600: dtdebug: override pwr_led_gpio: cell target gpios @ offset 4 (size 4)
002146.618: dtparam: uart0_clkrate=3000000
002149.338: dtdebug: Found override uart0_clkrate
002149.386: dtdebug: override uart0_clkrate: cell target clock-frequency @ offset 0 (size 4)
002163.397: dtdebug: Opened overlay file âoverlays/hifiberry-dac.dtboâ
002173.444: Loaded overlay âhifiberry-dacâ
002173.540: dtparam: audio=off
002173.693: dtdebug: /overrides node not found
002176.569: dtdebug: Found override audio
002176.603: dtdebug: override audio: string target âstatusâ
002183.740: dtdebug: Found fragment 0 (offset 36)
002187.791: dtdebug: merge_fragment(/soc/i2s@7e203000,/fragment@0/overlay)
002187.816: dtdebug: +prop(status)
002189.223: dtdebug: merge_fragment() end
002189.282: dtdebug: Found fragment 1 (offset 112)
002189.419: dtdebug: merge_fragment(/,/fragment@1/overlay)
002197.441: dtdebug: merge_fragment(/pcm5102a-codec,/fragment@1/overlay/pcm5102a-codec)
002197.471: dtdebug: +prop(#sound-dai-cells)
002199.377: dtdebug: +prop(compatible)
002201.161: dtdebug: +prop(status)
002203.069: dtdebug: merge_fragment() end
002203.098: dtdebug: merge_fragment() end
002203.176: dtdebug: Found fragment 2 (offset 252)
002212.796: dtdebug: merge_fragment(/soc/sound,/fragment@2/overlay)
002212.822: dtdebug: +prop(compatible)
002213.663: dtdebug: +prop(i2s-controller)
002214.906: dtdebug: +prop(status)
002215.739: dtdebug: merge_fragment() end
002219.796: dtdebug: /aliases:serial0=uart0
002222.875: dtdebug: /aliases:serial1=uart1
002271.613: dtparam: arm_freq=900000000
002274.485: dtdebug: Found override arm_freq
002274.535: dtdebug: override arm_freq: cell target clock-frequency @ offset 0 (size 4)
002283.946: dtdebug: override arm_freq: cell target clock-frequency @ offset 0 (size 4)
002293.443: dtdebug: override arm_freq: cell target clock-frequency @ offset 0 (size 4)
002303.025: dtdebug: override arm_freq: cell target clock-frequency @ offset 0 (size 4)
002312.709: dtparam: core_freq=250000000
002315.703: dtdebug: Found override core_freq
002315.751: dtdebug: override core_freq: cell target clock-frequency @ offset 0 (size 4)
002323.542: dtparam: cache_line_size=64
002326.405: dtdebug: Found override cache_line_size
002326.454: dtdebug: override cache_line_size: cell target cache-line-size @ offset 0 (size 4)
002333.153: dtdebug: delete_node(/hat)
002340.011: Device tree loaded to 0x2efec100 (size 0x3e14)
002343.190: gpioman: gpioman_get_pin_num: pin SDCARD_CONTROL_POWER not defined
004235.654: vchiq_core: vchiq_init_state: slot_zero = 0xee880000, is_master = 1
004239.768: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
004244.646: TV service:host side not connected, dropping notification 0x00000002, 0x00000001, 0x00000013
016217.562: hdmi: HDMI:Setting property pixel clock type to PAL
016217.679: hdmi: HDMI: power_on to CEA mode 720p50
016217.728: hdmi: HDMI: Action detach added to queue to happen at frame 733
016217.750: hdmi: HDMI: Action change_mode added to queue to happen at frame 733
016217.773: hdmi: HDMI: Action attach added to queue to happen at frame 733
016217.797: hdmi: HDMI: Action start_mode added to queue to happen at frame 733
016217.820: hdmi: HDMI: Action callback added to queue to happen at frame 735
016217.845: hdmi: HDMI: Action stop_3d_mode added to queue to happen at frame 735
016217.867: hdmi: HDMI: Action unmute added to queue to happen at frame 736
Thanks, I see the issue. A fix is on the way:
Thank you @sam_nazarko !
Just give me a hint when itâs ready and what I have to do. I will try it and give you the feedback you need.
Can confirm removing -overlay fixes the problem. For me both optical and coax. digital is fine and stable.
If you check for updates via My OSMC -> Updates -> Manual Controls -> Check for Updates now, you should receive another update and the HifiBerry sound card should work without modifying config.txt.
Thanks for the quick update! Ill test this tonight when I get home
@sam_nazarko I tried to install the update, but it didnât work well. I got en error during/after installation.
I started debug logging and tried to run the osmc-updater again, but it did not show me an update anymore. I tried to do the update with ssh and apt-get dist-upgrade, but it doesnât work. I attached the debug-log: http://paste.osmc.io/igaqikuvuz
The fix for this has been pushed, so HifiBerry will work out of the box. If you are having problems updating your kernel, see Rpi3 apt-get dist-upgrade fails (temporary error, fixed with new kernel)
