It would help having that module…
Thanks. @nazarko needs to add CONFIG_I2C_BCM2835 to the default configurations.
Doesn’t work here either…
It looks like this stopped working when we moved from 4.4. Some CONFIG_ options change as parts of the Raspberry Pi kernel have become more unified and due to upstreaming efforts.
I’m building a new kernel now with this option enabled which will hopefully resolve this. I’ll ping you when it’s ready.
On 4.4 we used i2c_bcm2708, which is enabled, so you wouldn’t have noticed i2c_bcm2835 being absent.
And it would be nice if you could remove the “-overlay” from the overlay names…
They are on their way out. This is however a relic of how we handle overlay support in My OSMC.
It would be great if we could test this kernel now.
wget "https://www.dropbox.com/s/pvepk50no24t17x/rbp2-kernel-mk2.deb?dl=1" -O kernel.deb
sudo dpkg -i kernel.deb
sudo reboot
It works! Thanks.
osmc@osmc:~$ aplay -l **** List of PLAYBACK Hardware Devices **** card 0: sndrpihifiberry [snd_rpi_hifiberry_digi], device 0: HifiBerry Digi HiFi wm8804-spdif-0 [] Subdevices: 0/1 Subdevice #0: subdevice #0
Excellent. Thanks for testing quickly.
We owe Dom and Phil a thanks for the pointers
I have a doubt. I am also suffering from crashed/freezings while trying to play HEVC files.
I did noticed that this is also marked as solved already, with an update I applied this updates and unfortunatelly I have lost my HifiBerry Digi+ again.
Can I reinstall the latest updated kernel that solved this issue?
Yes – when we have a bit more feedback (waiting for confirmation that 8192EU works), I’ll push the kernel.
Thanks a bunch sam, it’s working again on my rpi2 with hifiberry digi+!
Thanks guys, my HiFiBerry DAC+ is working again
Working here too!
Thank you sam_nazarko for your efforts, and thanks to Dom and Phil.
much appreciated.
My HifiBerry Digi+ is also working again:
osmc@carl:~$ aplay -l
Subdevices: 1/1
And this kernel also fixed an other problem I had after the update. My i2c-bus wasn’t working after the update (I need this for my character LCD), but it’s now working again ![]()
Great work Sam!
Wow. That’s efficiency. Great work & thanks.
Same problem with Justboom Digi. Fixed with this kernel. Thanks!
Is there an official update/hotfix for this ?
Nothing when going into manual update check. Have two rasp with kodi, not fan of going command line on both to get DAC+ working again.
