I’m using a Vero 4k to play some MKVs that contain HLG HDR streams from the BBC. When I play them back with my CXUHD (an Oppo 203 clone), colors are rendered correctly, but it skips frames heavily. When playing back with the Vero, color saturation and contrast are extremely exaggerated. Neither triggers HDR mode in my projector (JVC DLA X5000). mplayer and VLC also display the videos correctly (only tested on a linux desktop with a “normal” SDR monitor).
Photos of the same scene:
mediainfo of one of the files:
General
Unique ID : 99347494048453647180414086559366152888 (0x4ABDA1A1625028BF1E76769E62F882B8)
Complete name : video.mkv
Format : Matroska
Format version : Version 4
File size : 7.55 GiB
Duration : 57 min 9 s
Overall bit rate : 18.9 Mb/s
Writing application : mkvmerge v68.0.0 (‘The Curtain’) 64-bit
Writing library : libebml v1.4.2 + libmatroska v1.6.4 / Lavf59.16.100
Video
Format : HEVC
Format profile : Main 10@L5.1@Main
Codec ID : V_MPEGH/ISO/HEVC
Duration : 57 min 2 s
Bit rate : 18.3 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.088
Stream size : 7.30 GiB (97%)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : HLG
transfer_characteristics_Original : HLG / BT.2020 (10-bit)
Matrix coefficients : BT.2020 non-constant
My Vero 4k is up to date (it’s running the November 2022 release, if I’m not mistaken) Any suggestions what I can try to get my Vero to play back these files correctly? Any additional information I need to provide?
