Hi,I am a long time user of OSMC and had recently installed Berryboot instead of OSMC but then today I decided to switch back to OSMC the install went fine but when I plugged the SD Card into my windows 10 laptop,the normal /home/OSMC/etc. ,directory is not there,instead I just see log files,kernel images and other things ; here is an image:
Well I assume with “normal” you refer to the view from within OSMC and/or other linux PC’s as Windows will not be able to read the root partition without external tools.
You have two options:
Plug the card back and boot OSMC. Then follow the advise from SAM to either use SSH (SCP) or to install FTP or Samba Server and use that to transfer.
