I have been using OSMC for years (now the latest debian stretch version) on my Raspberry PI 2 and I’m loving it. Now I want to take it a step further by also running Homebridge on my OSMC Pi. In particular, I want to power AND control a simple chain of IKEA Särdal LED lights (12 LEDs; originally powered by 2xAA batteries, but I will solder jumpers cables to Pi instead; total power requirements: 3v / 0.36w). For that I plan to use the GPIO pins of Pi - pin 18 as 3.3v power source/control (on/off) and pin GND as ground.
Outdated: it seems that the homebridge-gpio-wpi2 should do the job. As the plugin relies on WiringPi as backend I need to install it, however I am failing to do so - when I run sudo apt-get install wiringpi on my osmc, then it starts reading the package list, etc., but fails with E: Unable to locate package wiringpi.
I would truly appreciate if anyone could please help me.
Oh ok - I thought that I could install wiringpi as a package. Nevertheless, I successfully compiled and installed wiring pi using the instructions from Raspberry Pi | Wiring | Download & Install | Wiring Pi. I can now access wiringpi’s command line utility called “gpio” and can manually toggle the GPIO pin on/off - I can confirm that the IKEA LED chain powers/lights on and off properly.
But I would still like toggle the LED chain on/off via homebridge and its plugin homebridge-gpio-wpi2. When I attempt to install homebridge-gpio-wpi2 by running sudo npm install -g --unsafe-perm homebridge-gpio-wpi2 then it fails and spits out the following. I guess it wants to see the wiringpi package - I am a but confused now as I already manually compiled and installed wiringpi. I would truly appreciate some help! Thanks.
osmc@osmc:~$ sudo npm install -g --unsafe-perm homebridge-gpio-wpi2
> epoll@0.1.22 install /usr/lib/node_modules/homebridge-gpio-wpi2/node_modules/epoll
> node-gyp rebuild
make: Entering directory '/usr/lib/node_modules/homebridge-gpio-wpi2/node_modules/epoll/build'
CXX(target) Release/obj.target/epoll/src/epoll.o
SOLINK_MODULE(target) Release/obj.target/epoll.node
COPY Release/epoll.node
make: Leaving directory '/usr/lib/node_modules/homebridge-gpio-wpi2/node_modules/epoll/build'
> node-wiring-pi@0.0.3 install /usr/lib/node_modules/homebridge-gpio-wpi2/node_modules/node-wiring-pi
> /bin/bash ./install.sh
dpkg-query: package 'wiringpi' is not installed and no information is available
Use dpkg --info (= dpkg-deb --info) to examine archive files,
and dpkg --contents (= dpkg-deb --contents) to list their contents.
dpkg-query: no packages found matching wiringpi
Checking for wiringpi:
Could not find wiringpi package - try 'sudo apt-get install wiringpi'
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! node-wiring-pi@0.0.3 install: `/bin/bash ./install.sh`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the node-wiring-pi@0.0.3 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2018-01-12T12_44_20_322Z-debug.log
osmc@osmc:~$
To sum up - my OSMC is now running Homebridge and is powering/controlling my IKEA LED light chain. I can turn on/off the LED lights via my iPhone and even Siri.
