With udev
(Tested on RPi3)
Plug in / Turn on USB DAC --- auto switch audio output to USB DAC
Unplug / Turn off USB DAC --- auto swith audio output to HDMI
Get /device/path…
sudo udevadm monitor --udev
plug in / turn on USB DAC
copy /devices/path.../card1
Get device parameter
sudo udevadm info --path=/devices/path.../card1 --attribute-walk
- copy ‘KERNEL’ and ‘SUBSYSTEM’ for rules
Create hot plug rules
/etc/udev/rules.d/usbsound.rules
ACTION=="add", KERNEL=="controlC1", SUBSYSTEM=="sound", RUN+="/home/osmc/usbsound.sh"
ACTION=="remove", KERNEL=="controlC1", SUBSYSTEM=="sound", RUN+="/home/osmc/hdmisound.sh"
Create json-rpc command files
- change ‘audiooutput’ in ‘guisettings.xml’
#!/bin/bash
# auto switch for single usb sound only
# get http 'port' >>> as may be changed by user
port=$(sed -n 's:.*>\(.*\)</webserverport>.*:\1:p' /home/osmc/.kodi/userdata/guisettings.xml)
# get usb 'id' >>> /dev/snd/controlC1 == /sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.[1 to 4]/...
# (get usb path | sed path to '...card1/id' | prepend '/sys' dir to path) >>> get file content
path=$(udevadm info -n /dev/snd/controlC1 -q path | sed 's/controlC1/id/' | sed 's/^/\/sys/')
id=$(< $path)
# [{set audio output to usb 'id'}, {notify}] http 'port'
curl -H "Content-type: application/json" -X POST -d '[
{"jsonrpc":"2.0","method":"Settings.SetSettingValue", "params":{"setting":"audiooutput.audiodevice","value":"ALSA:@:CARD='$id',DEV=0"},"id":1},
{"jsonrpc":"2.0","method":"GUI.ShowNotification", "params":{"title":"AUDIO OUTPUT", "message":"Switched to USB Sound"}, "id":1}
]' http://localhost:$port/jsonrpc
Create unplug notification
#!/bin/bash
# auto swith back to hdmi by system default, notify only
# get http 'port'
# notify with http 'port'
curl -H "Content-type: application/json" -X POST -d '{"jsonrpc":"2.0","method":"GUI.ShowNotification", "params":{"title":"AUDIO OUTPUT", "message":"Switched to HDMI"}, "id":1}' http://localhost:$port/jsonrpc
Set files permission
sudo chmod +x /home/osmc/hdmisound.sh usbsound.sh
