Hi guys.
I have a question about being able to “hot-switch” the HDMI EDID, for lack of a better description. It requires some explanation of my setup. I run all of my devices inside a closet connected to an 8x8 Matrix HDMI Switcher KD8x8CSK. There are 4 TVs in the house that have long HDMI cables running to the closet and plug into the switcher.
Some of the TVs are 4K and some only 1080p. So, I have the switcher change the input EDID based on which TV or TVs are watching. For example, I have an Nvidia Shield that will automatically change adjust when the switcher applies a 4K or 1080p EDID.
However, when I try with the Vero it does not take. If I have the EDID set to 4K and start the Vero, the 4K TV will show they output fine. If I then set the EDID to 1080p that same TV will show the UI which is set to 1080p always but when I play a 4K movie the TV shows nothing. If I reboot the Vero it will then output the movie properly at 1080p since that is what the EDID is set for.
Is this something the Vero is simply not able to handle?
Ernie
