I have no idea where I put the HDMI cable that came with the Vero 4K+
How can I identify it?
I have a box with many hdmi cables and I find it hard to figure out which ones supports HDR.
Unless you bought a 2M one, it will be 0.8M.
Ok, is there something written on the cable that can help me identify it?
I will check tomorrow.
Thanks a lot!
Thanks - that’s exactly what I’m looking for.
Looks like Ainsley beat me to it.
I actually had to replace the cable that came with my Vero with a better quality one in order to get HDR working reliably. I recommend getting something that is independently certified as “premium high-speed” - look for a barcode in the advertising image. (They’re not very expensive).
