Hi @ all,
i thing it is simple if you know how
Currently Im running the last OSMC on my PI with Kodi last stable relase, furthermore I install the Hyperion on the Pi. Then there is a Enigma2 Receiver, this is connected with Boblight and the Hyperion on the Pi. Everything is fine the Ambilight Rocks fine when i use the Receiver, but i not able to run it directly with Kodi on the Pi. I try to use Boblight on the Pi to but it doesn?t work because of missing some libraries? Can this be possible that i need to compile them by myself? dont misunderstand me, if this is need i will do it (I`m not lazy). It is just not really understandable for me.
