How can I use an Hauppage pvr350 remote?
My programmable remote does onlysupport the vero4k and so I was trying to activate the hauppage tvr350 - which is a supported remote.
So I tried selecting this remote in the myOSMC remote settings (it is now highlighted), but it appears not to accept the hauppage remote commands…
What am I missing?
Not too familiar with Hauppauge.
Is there another remote you could copy that might be more popular like the Xbox 360 MCE remote? This is a common remote and can be selected under My OSMC’s Remotes menu
Hi Sam,
I can try. But basically it should be sufficient just to select the remote in the myOSMC menu?
greetings
Andreas
If you can match up your remote to that, yes.
Hi Sam,
thanks a lot! That actually works fine!
Glad this works well for you
