I just received my Vero 4K+ (note: make that power lead at least twice and long, please!) and after some messing around I finally managed to get it up and running (I think!).
I want to be able to share files between my PC (Windows 10) and the Vero, so I 've installed the Samba server, which is running. I have a wired ethernet connection to the Vero from my PC (via a router).
How do I connect to the Vero from my PC now? I can’t see the Vero when I launch Windows File Explorer. What steps do I need to take to make the connection?
When I go to settings/system, the IP address is showing as 192.168.0.26 When I type the address into Windows Explorer //192.168.0.26/ all I get is the following:
But… this IP address was the one I entered when first installing my Vero to specify networking options and to get the internet connection working, so isn’t this the IP address of my PC?
If I open a command prompt on my PC and type ipconfig, I get the following:
I decided to go back into the Vero Network menu and change to “use DHCP” that changed the IP address and now I can access the Vero through the PC. As far as I can tell that’s going to work! I’ll report back later after some testing.
Thank you so much for your help so far. I really appreciate it.
New problem: I can now connect to the Vero with my PC, but can’t see the USB HDD that I’ve attached to the Vero (using the powered hub that came with my Vero).
EDIT: Although I can see the drive name in the Vero OSD, when I select the drive it doesn’t do anything or show any of the contents. Does the drive have to be formatted for a specific file system? Currently it’s formatted as NTFS and has about 1.5TB of videos on it.
TRISHA is a USB stick I have inserted. I can see the contents of TRISHA via my PC and also on the Vero, but with the USB HDD I can’t see the contents on the Vero or even see it at all on the PC.
In Kodi for example, I go to movies > enter file section and I see the following:
Auto Mounted Drives
TRISHA
+Add videos
So if I move to TRISHA (USB stick) I see the files I have installed there. No problems.
If I move to Auto Mounted Drives, I see the following:
USB DRIVE (my usb hdd)
TRISHA
If I select USB drive and hit OK, nothing happens.
Ok, then I would suggest we check on the Vero via Command Line. Do you know how to use SSH? Can read below. If you are Ok with it I can write you some commands to check.
Also when you put your hand on the disk can you feel it rotating?
As you know, there are two USB sockets on the side of the Vero. As you are looking directly at them, I had the remote control dongle inserted to the right-hand USB socket, and the powered USB hub inserted into the left-hand USB socket. This configuration did not make the USB HDD visible.
I decided to swap the remote control dongle into the left socket and the USB hub into the right socket, and not it works. It would be interesting to find out why that is.
