How do I get vero v to see my USB hard drive?
I am new to OSMC and just bought the Vero V and struggling to get started. I want to use it to watch videos on a USB hard drive but I can’t figure out how to get it to see the drive. I have tried both USB ports and rebooted the device several times but it’s not coming up. What do I need to do?
How are you powering the hard drive?
Can you show me a photo of the hard drive specs or let me know the model number?
The USB3 port can provide 0.9A of power output but if it’s a drive that sips a lot of power you’ll need a powered hub or need to use the drive’s external power supply
It turns out it was an issue with the USB cable (I had been using a USB-C one to transfer the files from my laptop so this was the first time I’d used it with the USB-A one). Tried a different cable and now it has picked up the drive :slight_smile:
It’s an SSD so I don’t think should need external power? Crucial X9 4tb
Glad to hear this.
SSDs still use power, albeit lower than their mechanical counterparts.
If it’s working fine now you should be OK but would consider a powered hub if adding a further drive in the future
