Hardware Vero V
Logs : https://paste.osmc.tv/fakawaleyi
My Error : 2025-01-04 14:03:56.000 T:15057 error : CAddonInfoBuilder::ParseXML: addon.xml from ‘game.libretro.mupen64plus’ for binary type ‘kodi.gameclient’ doesn’t contain library and addon becomes ignored
My attempts have failed and I need some guidance to the process.
2025-01-05 11:22:10.484 T:3126 info : retrOSMCmk2 Launcher: “/home/osmc/.kodi/userdata/addon_data/script.launch.retropie/data.xml” missing or corrupt on this run
2025-01-05 11:22:10.650 T:3126 error : EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<–
- NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Type: <class ‘ValueError’>
Error Contents: invalid literal for int() with base 10: ‘dump’
File “/home/osmc/.kodi/addons/script.launch.retropie/addon.py”, line 391, in
slots_master = int(labels_master.pop(0))
ValueError: invalid literal for int() with base 10: ‘dump’
–>End of Python script error report<–
sam_nazarko, hope all is well. I downloaded OSMC_TGT_vero5_20241104.img.gz and placed it on my micro SDXC card rebooted and did not get the installation process to start. The file is on the top level directory of the micro SDXC. I then tried the same thing with a usb stick. The system just booted regularly.
I could do something like this from the micro SDXC card right?
You need to image the micro SD card properly. If you are not sure how to do this, use the Mac / Windows / Linux installers from Download - OSMC and see Reinstalling OSMC - Vero V - OSMC. Alternatively you can dd the image to the SD card or USB itself.
Good day Sam, thanks for your help so far. I got the OS reinstalled. I had to duplicate the image to the USB stick for the hardware the bootup and detect the boot sector of the USB stick and start the instalation.
The following source is how I am trying to install the emulator.
I followed the instructions and this is where I am stuck currently.
Interesting and thanks for explaining. I am not aware of the boot procedure for this hardware. This is something I would like to learn.
Any insights into the RetroPie installer?
This is after a clean install so not sure how or why the files would be corrupt or missing.
2025-01-10 18:59:52.137 T:5307 info : retrOSMCmk2 Launcher: “/home/osmc/.kodi/userdata/addon_data/script.launch.retropie/data.xml” missing or corrupt on this run
2025-01-10 18:59:52.137 T:5307 info : retrOSMCmk2 Launcher: “/home/osmc/.kodi/userdata/addon_data/script.launch.retropie/settings.xml” missing or corrupt on this run
2025-01-10 18:59:54.175 T:5222 info : Loading skin file: DialogAddonSettings.xml, load type: KEEP_IN_MEMORY
