I can’t get any sound out of the Pi 2 any longer. Don’t know how the volume got muted to begin with but I can not find how to undo it. I see on the top right hand screen a speaker with a red circle and a slash through it signaling no sound. In the OSMC screen the top middle states “Volume muted”
Where do i unmute?.
Yatse has an unmute feature. Most remotes do. Alternatively try + or F10 on a keyboard
You can try this as well:
F8 to unmute from a keyboard and + to increase the volume to maximum.
Another good way to do it if you don’t have a keyboard is the web interface. Go to
Where ipaddress is the ipaddress of your Pi then click on remote. On some networks the following will work without looking up the ip address:
Incredible, the fastest response to an inquiry. The best community on the web. Thanks guys.
Sam, you’re special!!!
I created an account just so I could thank you for the advice! hitting the + sign worked for me. I was so lost! thanks!
Agree with Mistameana! I was at my wits end trying to figure this out and when I googled, this was the first result listed. Y’all are absolutely incredible. Thank you!
My Pi was set to 33% volume after the upgrade, but this topic allowed me to fix that.
Thanks!!
