Hi, currently considering of also getting the tvdongle. How does this work i thought at least for TVs to watch livetv you need some sort of coax cable connected to the TV to use some of the tuners T2/C/S which I do not have. Is this Tuner gettings its T2 info via internet?
Also which channels can i receive? Is this somehow country restricted (Germany here)
I assume you are referring to this dongle?
Yes, for this Dongle to work you would need to connect it to either a DVB-T2 Antenna or a cable that provides a DVB-C Signal.
It works for Germany but only for unencrypted channels.
