Hello,
I need to activate component registration for CEC (Vero V and Aeon Silvo).
How do I do this?
Thank you in advance for your help.
Thank you.
Voici les logs avec le log ECC
https://paste.osmc.tv/uvavisecuz
- Are you sure you have component based logging on for CEC?
- There is too much logspam from video playback, so I can’t see the cause of the CEC problem in the kernel.
Hello,
I wanted to redo the process to log the ECC, so I restarted Kodi…
When I start up, I no longer get the ECC error message and the continuous update request.
Why is this? Mystery…
In any case, everything is OK.
Thanks for taking the time to help me.
Usually CEC problems can be resolved by powering all devices off at the mains for a few minutes.
