i use kodi on my osmc but i need more space
i know thats for graphic but i have 32gbits i don’t need so much graphic
how i can get 5gbits more ?
thanksfull for some answer
I don’t think you understand what you are talking about here. OSMC does not use “32gbits for graphic”. What do you think you need more space for?
i need more space for kodi
i only have 700mb…
I think OP means fanart is taking his space.
What is the output of df -h
/home/osmc/.kodi$ df -h
Filesystem Size Used Avail Use% Mounted on
devtmpfs 362M 0 362M 0% /dev
tmpfs 367M 5.1M 362M 2% /run
/dev/mmcblk0p7 2.0G 771M 1.1G 42% /
tmpfs 367M 0 367M 0% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 367M 0 367M 0% /sys/fs/cgroup
/dev/mmcblk0p6 79M 30M 50M 38% /boot
/dev/mmcblk0p1 422M 330M 93M 79% /media/RECOVERY
/dev/mmcblk0p10 25G 44M 24G 1% /media/share0
/dev/mmcblk0p5 30M 443K 28M 2% /media/SETTINGS
/dev/mmcblk0p8 60M 6.7M 53M 12% /media/boot
/dev/mmcblk0p9 1.9G 726M 1.1G 40% /media/root0
tmpfs 74M 0 74M 0% /run/user/1000
thanks for help
You have 25 gig free at /media/share0 (/dev/mmcblk0p10 25G 44M 24G 1% /media/share0) if you’re looking to add files you can add them there. If you’re not using NOOBS for dual boot it would be best to backup and do a fresh install using the OSMC installer, it is a much cleaner install
You appear to be running a noobs installation in which other OS’s are taking up space. If you only use OSMC, you should backup your settings and re-install exclusively with OSMC and not use noobs. If you want to change the amount of space noobs allots to OSMC, you should seek support from noobs as we have no idea how to do so in such a setup.
gparted livecd works for this
thank you
yes i have parallel recalbox ^^
i look there very thanksfull
it’s on my raspberrypi
