All ,
I bought the latest Vero V and and I have an Odroid N2 running Corelec before,
How I get the visualizations running on the latest OSMC?
this is what happens if I try to install it:
apt install kodi-visualization-spectrum
Reading package lists⦠Done
Building dependency tree⦠Done
Reading state information⦠Done
vero5-mediacenter-osmc : Conflicts: kodi
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
And if I try to remove vero5-mediacenter-osmc I get:
apt-get purge vero5-mediacenter-osmc
The following packages were automatically installed and are no longer required:
armv7-libbluray-osmc armv7-librtmp-osmc armv7-libshairplay-osmc armv7-libsqlite-osmc fontconfig-config fonts-dejavu-core libaacs0 libasound2 libasound2-data libass9 libatomic1 libavahi-client3 libavahi-compat-libdnssd1 libcdio19
libcrossguid0 libcups2 libdeflate0 libdisplay-info1 libevdev2 libfmt7 libfontconfig1 libfreetype6 libfribidi0 libfstrcmp0 libgif7 libgraphite2-3 libharfbuzz0b libimagequant0 libinput-bin libinput10 libiso9660-11 libjansson4 libjbig0
libjpeg62-turbo liblcms2-2 libldb2 libmad0 libmariadb3 libmicrohttpd12 libmtdev1 libnfs13 libnspr4 libnss3 libogg0 libp8-platform2 libpcrecpp0v5 libplist3 libpopt0 libpython3.9 libsamplerate0 libsmbclient libspdlog1 libssh-4
libtag1v5-vanilla libtdb1 libtiff5 libtinyxml2-8 libtinyxml2.6.2v5 libudfread0 libvorbis0a libvorbisenc2 libwacom-common libwacom2 libwebp6 libwebpdemux2 libwebpmux3 libxau6 libxcb1 libxdmcp6 libxkbcommon0 libxslt1.1 libyajl2
mariadb-common mediacenter-addon-osmc mediacenter-eventclients-common-osmc mediacenter-send-osmc mediacenter-skin-osmc mysql-common python-apt-common python-is-python3 python3-apt python3-certifi python3-chardet python3-dbussy
python3-idna python3-ldb python3-pexpect python3-pil python3-pkg-resources python3-ptyprocess python3-requests python3-samba python3-six python3-talloc python3-tdb python3-unidecode python3-urllib3 samba-common samba-common-bin
samba-libs vero5-libcec-osmc xkb-data
Use āapt autoremoveā to remove them.
The following packages will be REMOVED:
vero5-device-osmc* vero5-mediacenter-osmc*
0 upgraded, 0 newly installed, 2 to remove and 0 not upgraded.
After this operation, 302 MB disk space will be freed.
(Reading database ⦠38996 files and directories currently installed.)
Removing vero5-device-osmc (1.0.3) ā¦
WARNING: You have tried to remove a package that is essential to OSMCās operation.
To undo these changes, run āsudo apt-get -f installā.
dpkg: error processing package vero5-device-osmc (āremove):
installed vero5-device-osmc package pre-removal script subprocess returned error exit status 1
dpkg: too many errors, stopping
vero5-device-osmc
Processing was halted because there were too many errors.
Have you checked it isnāt already installed? Several addons are installed by default and just need to be enabled.
This isnāt a good idea, thatās a core package of osmc. It would probably be good to post some logs, so can cake the system state.
Regards Tom.
You donāt need to install binary add-ons on OSMC
They are already available under Add-ons.
This is a bit different to Libre/CoreELEC where they have to be installed manually.
We choose this approach to benefit users that may not necessarily have an internet connection.
where are they?
I looked for them and I do not see them
How you enable them?
It failed anyhowā¦
I feel like it would be better to put corelec on the box - there are things they do not work if I do that.
All looks good with the Linux system else I would get errors
apt-get update
Hit:1 Index of /debian bullseye InRelease
Hit:2 Index of /debian bullseye-updates InRelease
Hit:3 https://security.debian.org bullseye-security InRelease
Hit:4 Index of /osmc/osmc/apt bullseye InRelease
root@kodi-office:/home/osmc# apt-get dist-upgrade
Calculating upgrade⦠Done
Settings -> Add-on Browser -> My add-ons -> Look and feel -> Visualisation
Regards Tom.
Thanks!!!
This may impact your ability to update in the future and you may need to reinstall OSMC. These packages are not meant to be removed.
