Thanks - I had spent a while scouring that before and couldn’t find a function that changes the settings. I checked again but still didn’t see one that would change the pan/zoom setting or slide timing.
The ‘Slideshow’ function includes the ability to override the ‘Randomize’ setting, but not the timing or pan/zoom. I saw functions that change the settings level (basic, advanced, etc) or open dialog boxes but as I said, I want this to be non-interactive. There are also a couple for changing skin settings but the slideshow settings are not part of the skin.
If there IS a built in function that would do the trick, could you point me in its direction?
