As title says,
Im on Krypton, so it should be straight forward right?
But how does one connect PS3 controller?
Regards
As title says,
Regards
For gaming ?
Well i have retropie (retrosmc) installed in my osmc system
But its both for Kodi and retropie
No one?
how exactly did you install this? did you start with osmc and then add retropie, or did you start with retropie the install kodi?
Start with osmc and then added retropie, i used the guide on this forum
Guys forget the retropie, i wanna have my PS3 remote to connect to osmc
Pair it via the command line or in My OSMC -> Bluetooth.
I’m not sure if anything further is needed for it to work.
Thanks Sam, but it does not see my PS3 controller in there, it only sees my soundbar (which has bluetooth)
I Tried connecting it with a USB cable, then my PS3 controller shakes like crazy but it will not Work
Edit: any easy guide to connect it throu command line?
I never got it to work on Pi-3 using the built in Bluetooth for Kodi but it works for Retropie on OSMC
I have been told you need a approved Bluetooth adapter to use it on KODI
I refuse to accept that it cannot connect t pi 3 running Kodi,
Sam do you and/or your team have a Solution?
[EDITED ANSWER]
(there already several solutions)
You can use your ps3 controller to use with both kodi ans retrosmc.
Look into this link:
[url][HowTo] RetroPie and OSMC: Retrosmc - Retrogaming on OSMC - #968 by nvdias
Good luck.
(and post back your results)
yes but i cannot see my controller in>Addons>My OSMC>Network>bluetooth
i can only see my phone and soundbar (wich has bluetooth) ???
so i still help with connecting my PS3 controller with OSMC?!?
PS3 controller does not appear in Bluetooth menu.
Use the peripherals menu as described above.
Tryed, still can’t get it to work
Sudo sixpair
Command not found…
have you installed it ?
sudo apt-get install sixad
[edit]
please read my previous post and the link I’ve shared:
Support for dualshock controller is direct in OSMC (Kodi 17).
sixad is needed for support in retropie
I did everything you said above…
Still no work…
May it be because I’m using a cheap Chinese PS3 controller?
Edit: it does pop up under peripherals
http://m.imgur.com/UZ59H0x
As of today, I can confirm the procedure shared by @Rickt1962 works well. I’m using a genuine PS3 controller.
