How to change a single key mapping?
I would like to change the behaviour of the long press Home button on the Home screen. From ‘Send CEC standby’ to ‘System Suspend’.
I read the Long Press Keymap Guide. It explains how to create my own keymap from scratch. But that seems like a lot of work for just changing one key mapping.
Is there a way to copy the existing keymap, and then change this one button?
(This is on Vero 4K+ of december 2020).
The keymaps load in order combining the mappings in them with user keymaps loading after the system keymaps. When it loads each keymap if there is a conflict it overrides the mapping. As such, all that is required is to place your desired modifications to the user thumbnails. In your case this would be…
<keymap>
	<Home>
		<keyboard>
			<escape mod="longpress">suspend</escape>
		</keyboard>
	</Home>
</keymap>
But I’m not sure if this is actually the correct action. The keymap wiki seems to indicate that this is a trigger for sleep states on a PC and the correct action to use would be “shutdown” which would have its actual function dictated by what is set in Kodi’s power saving settings.
Thanks you were spot on. Adding the steps for other noobs like me:
  1. Open a command line through Putty / SSL
  2. nano /home/osmc/.kodi/userdata/keymaps/osmc/osmcremote.xml
  3. Copy & paste: (afterwards Ctrl+X and Y + Enter)
<keymap>
  <Home>
    <keyboard>
      <escape mod="longpress">ShutDown</escape>
    </keyboard>
  </Home>
</keymap>
  1. In Kodi GUI navigate to Settings > System > Power saving > Default shutdown method. Change to ‘Suspend’.
Cheers, but for reasons I outlined in that guide I would actually recommend saving the keymap to…
Thanks, I edited my post.
