I’ve recently switched back to the OSMC skin and noticed after changing the TV Shows widget to “In Progress TV Shows” its sorted alphabetically on the home screen, rather than by Last Played. If I navigate to this view manually its sorted correctly, and this widget on Estuary also sorts by Last Played.
Is there a way to change the widget sort behaviour on the OSMC skin?
