I’ve install Xperience1080 skin and my Osmc won’t start, how to delete it from file manager on my laptop ?
Edit guisettings.xml. you can find it at /home/osmc/.kodi/userdata/.
Quick fix would be to rename your .kodi directory and restart.
You would loose your settings this way though.
You mean delete /home/osmc/.kodi/ folder ?
Delete or rename, yes, that it what he means
