I am trying to disable the power LED on my Pi2. In openelec I was able to create a autostart.sh in the .config folder containing:
echo none > /sys/class/leds/led1/trigger
What would be the equivalent to disable the power LED in OSMC? Any help would be appreciated, thanks.
Did you try, if your solution works on osmc, too?
What folder would I put it in?
Ah. Just checked and there is /sys/class/led0/power/
There are some files but @sam_nazarko can answer which exact file you have to change I think.
you can disable the LEDs using this in config.txt :
Disable the ACT LED.
dtparam=act_led_trigger=none
dtparam=act_led_activelow=off
Disable the PWR LED.
dtparam=pwr_led_trigger=none
dtparam=pwr_led_activelow=off
http://www.jeffgeerling.com/blogs/jeff-geerling/controlling-pwr-act-leds-raspberry-pi
Would be great if this was an option in the Vero 2.
I guess @sam_nazarko is working on it based on this github entry
This solution only works for sd activity led (green one) on the Pi3.
The power led (red) remains always on…dosn’t work on the Pi3…
Any ideas?
