I have created 3 very similar Docker [HOW-TO] for NZBGet, Sonarr & CouchPotato, so this is the last one which ties the other 3 services in nicely to one web page.
https://discourse.osmc.tv/t/how-to-docker-nzbget/20535/1
https://discourse.osmc.tv/t/how-to-docker-sonarr/20538/1
https://discourse.osmc.tv/t/how-to-docker-couchpotato/20539/1
First make sure Docker is installed.
curl -sSL https://get.docker.com | sh
It’s also useful to add the current user to Docker group to avoid having to use sudo in front of every Docker command.
sudo usermod -aG docker $USER
Then we simply need to create the systemd file, enable, then start it. Using your favourite text editor create a systemd service file;
Check out the config here; https://hub.docker.com/r/lsioarmhf/muximux/
sudo vim /etc/systemd/system/muximux.service
[Unit]
Description=Muximux container
Requires=docker.service
After=docker.service
[Service]
Restart=always
ExecStart=/usr/bin/docker run -p 80:80 --name=muximux -v /opt/muximux:/config -e PUID=1000 -e PGID=1000 -e TZ=UTC lsioarmhf/muximux
ExecStop=/usr/bin/docker stop -t 2 muximux
ExecStopPost=/usr/bin/docker rm -f muximux
[Install]
WantedBy=default.target
Now enable the service;
sudo systemctl enable muximux and then start it with sudo systemctl start muximux
You can check it with sudo systemctl status muximux
This will neatly tie in the other 3 services (NZBGet, Sonarr & CouchPotato) into 1 web page with minimal setup.
Just open a browser on any device in your network, type in the IP address
e.g. 192.168.1.100
