I have my movies on NAS server shared over multiple devices with the common library on mysql. I use my PC to manage whole library and all other devices use this library automatically. From some time OSMC on raspbery pi 3 stopped refreshing library and i have to update it manually every each time it’s most likely because my PC and other devices use kodi 16 and osmc use 17.
On my PC i’m using linux, kodi 17 is marked as unstable i don’t want to mix stable and unstable packages because it will mess with my dependencies so solution i see is to downgrade osmc.
How to downgrade osmc ?
This solution don’t work for me …
Hi there,
is it possible to Downgrade my Pi 2 from Krypton Beta to official Jarvis Release? The Pi doesn’t works fine after switching to Beta Release … i know, thata why its Beta
But my girlfriend likes to watch Amazon Prime Videos …
I would like to avoid reinstalling whole system, i will do it if there would be no other solution, but even then which version of osmc contain kodi 16 ?
Hi Marcin_Kamienski,
You would be better of updating to kodi 17 on Linux PC, I know it marked as unstable in the linux dist repository, but in kodi terms its considered stable. Also if you use any addons, the latest updates for these will have been geared towards 17.
When using mysql, each kodi update requires a new database; so now you have one database for 16 and another for 17.
If you still think downgrading is the way forward, you will need to re-image. I think this is the one you will want:
(Sorry that was the pi1/zero link by mistake, I’ll try again)
http://download.osmc.tv/installers/diskimages/OSMC_TGT_rbp2_20170129.img.gz
Thanks Tom.
> sudo apt-get -t unstable install kodi
> Reading package lists... Done
> Building dependency tree
> Reading state information... Done
> The following packages were automatically installed and are no longer required:
> akonadi-backend-mysql breeze-cursor-theme breeze-icon-theme cmake cmake-data coinor-libcoinmp1v5 debugedit default-mysql-client-core fonts-roboto g++-4.9 gcc-6-base:i386 git-man
> hplip-data ieee-data k3b-data kde-baseapps-data kde-cli-tools-data kdeplasma-addons-data kpackagetool5 ksysguard-data ksysguardd ktexteditor-data ktorrent-data kwin-data lib32z1 libaio1
> libapr1 libaprutil1 libastro1 libbasicusageenvironment1 libboost-date-time1.62.0 libboost-filesystem1.62.0 libboost-iostreams1.62.0 libboost-system1.62.0 libbotan-1.10-0 libbotan-1.10-1
> libc6:i386 libc6-i386 libclang1-3.9 libcmis-0.5-5v5 libdouble-conversion1 libdvbpsi10 libenca0 libexiv2-14 libgcc1:i386 libglew2.0 libgltf-0.0-0v5 libgps22 libgroupsock8 libhunspell-1.4-0
> libical2 libinput-bin libinput10 libjbig-dev libjs-underscore libkf5akonadiprivate5 libkf5archive5 libkf5codecs-data libkf5codecs5 libkf5completion-data libkf5config-data
> libkf5configcore5 libkf5coreaddons-data libkf5coreaddons5 libkf5dbusaddons-data libkf5declarative-data libkf5i18n-data libkf5i18n5 libkf5iconthemes-data libkf5notifications-data
> libkf5package-data libkf5package5 libkf5service-data libkf5widgetsaddons-data libkf5windowsystem-data liblivemedia57 libllvm3.9 liblzma-dev libmicrohttpd10 libmpg123-0 libopenmpt-modplug1
> libopenmpt0 liborcus-0.11-0 libpgm-5.1-0 libpython3.5 libqapt3 libqt5clucene5 libqt5concurrent5 libqt5core5a libqt5dbus5 libqt5script5 libqt5sql5 libqt5sql5-mysql libqt5sql5-sqlite
> libqt5test5 libqt5xml5 libreadline5 librpm3 librpmbuild3 librpmio3 librpmsign3 libsdl2-2.0-0 libserf-1-1 libsndio6.1 libsodium13 libssh-4 libssl1.0.2 libstdc++-4.9-dev libsvn1
> libtiff5-dev libtiffxx5 libusageenvironment3 libwacom-common libwacom2 libwps-0.4-4 libx264-148 libx265-95 libxapian30 libzmq3 lsb-security mariadb-client-core-10.1 mariadb-common
> mysql-server-core-5.5 pax perl-openssl-defaults qt4-linguist-tools qt5-doc qtbase5-doc qtcreator-data qtcreator-doc qtdeclarative5-doc qtenginio5-doc qtgraphicaleffects5-doc
> qtmultimedia5-doc qtpositioning5-doc qtquickcontrols5-doc qtscript5-doc qtsensors5-doc qtserialport5-doc qtsvg5-doc qttools5-doc qttranslations5-l10n qtwebkit5-doc qtwebkit5-examples-doc
> qtwebsockets5-doc qtx11extras5-doc qtxmlpatterns5-doc rpm-common rpm2cpio rsync subversion tex-common
> Use 'apt-get autoremove' to remove them.
> The following extra packages will be installed:
> akonadi-backend-mysql apper-data apt apt-utils binutils coinor-libcoinmp1v5 cpp cpp-6 cups cups-bsd cups-client cups-common cups-core-drivers cups-daemon cups-server-common dbus
> default-mysql-client-core fonts-noto-hinted fonts-noto-mono fonts-roboto-hinted g++ g++-6 gcc gcc-6 gcc-6-base gcc-6-base:i386 gstreamer1.0-plugins-base gstreamer1.0-plugins-good
> hplip-data ieee-data k3b-data kde-baseapps-data kdeplasma-addons-data kodi-bin kodi-data kpackagetool5 ksysguard-data ksysguardd ktorrent-data libapt-inst2.0 libapt-pkg5.0 libasan3
> libass5 libastro1 libatomic1 libavfilter6 libboost-date-time1.62.0 libboost-filesystem1.62.0 libboost-iostreams1.62.0 libboost-system1.62.0 libbotan-1.10-1 libc-bin libc-dev-bin libc-l10n
> libc6 libc6:i386 libc6-dbg libc6-dev libc6-i386 libcc1-0 libcec4 libcilkrts5 libclang1-3.9 libcmis-0.5-5v5 libcrossguid0 libcups2 libcupscgi1 libcupsimage2 libcupsmime1 libcupsppdc1
> libdbus-1-3 libdbus-1-dev libdouble-conversion1 libdvdnav4 libdvdread4 libebur128-1 libexiv2-14 libgcc-6-dev libgcc1 libgcc1:i386 libgif7 libgirepository-1.0-1 libglew2.0 libglib2.0-0
> libglib2.0-bin libglib2.0-dev libgltf-0.0-0v5 libgnutls30 libgomp1 libgps22 libgssapi-krb5-2 libgstreamer-plugins-base1.0-0 libgstreamer1.0-0 libhogweed4 libhunspell-1.4-0 libical2
> libicu57 libinput-bin libinput10 libio-socket-ip-perl libisl15 libitm1 libjack-jackd2-0 libk5crypto3 libkdcraw-data libkexiv2-data libkf5akonadiprivate5 libkf5archive5 libkf5codecs-data
> libkf5codecs5 libkf5config-data libkf5configcore5 libkf5coreaddons-data libkf5coreaddons5 libkf5i18n-data libkf5i18n5 libkf5package-data libkf5package5 libkipi-data libkrb5-3
> libkrb5support0 liblirc-client0 liblircclient0 libllvm3.9 liblocale-gettext-perl liblsan0 liblz4-1 libmariadbclient18 libmicrohttpd12 libmodplug1 libmpdec2 libmpfr4 libmpg123-0 libmpx2
> libncurses5 libncurses5-dev libncursesw5 libnettle6 libnfs8 libnm0 libnuma1 libopencv-core2.4v5 libopencv-imgproc2.4v5 libopenmpt0 liborc-0.4-0 liborcus-0.11-0 libp11-kit0 libp8-platform2
> libpci-dev libpci3 libpcre16-3 libpcre3 libpcre3-dev libpcre32-3 libpcrecpp0v5 libpgm-5.2-0 libplist3 libpng16-16 libpython3-stdlib libpython3.5 libpython3.5-minimal libpython3.5-stdlib
> libqapt3 libqt4-opengl libqt4-sql libqt4-sql-mysql libqt4-sql-sqlite libqt4-svg libqt4-test libqt4-xml libqt5clucene5 libqt5concurrent5 libqt5core5a libqt5dbus5 libqt5script5 libqt5sql5
> libqt5sql5-mysql libqt5sql5-sqlite libqt5test5 libqt5xml5 libqtcore4 libqtgui4 libquadmath0 libreadline5 libreadline7 libsndio6.1 libsodium18 libssl1.0.2 libssl1.1 libstdc++-6-dev
> libstdc++6 libtag1v5 libtag1v5-vanilla libtasn1-6 libtext-charwidth-perl libtext-iconv-perl libthreadweaver4 libtinfo-dev libtinfo5 libtinyxml2.6.2v5 libtsan0 libubsan0 libvpx4
> libwacom-common libwacom2 libwayland-bin libwayland-client0 libwayland-cursor0 libwayland-dev libwayland-server0 libwebp6 libwebpdemux2 libwebpmux2 libwps-0.4-4 libx264-148 libx265-95
> libxapian30 libxkbcommon-dev libxkbcommon-x11-0 libxkbcommon-x11-dev libxkbcommon0 libzmq5 linux-libc-dev locales marble-data mariadb-client-core-10.1 mariadb-common mysql-common
> ncurses-bin network-manager network-manager-pptp pciutils perl-base perl-openssl-defaults policykit-1-gnome ppp printer-driver-brlaser python3 python3-apt python3-dbus python3-gi
> python3-minimal python3-pil python3-reportlab-accel python3-sip python3.5 python3.5-minimal qt4-linguist-tools qt5-qmake qtchooser qtcreator-data sgml-base task-desktop task-english
> task-print-server tasksel tasksel-data tex-common
> Suggested packages:
> apt-doc powermgmt-base binutils-doc cpp-doc gcc-6-locales cups-pdf smbclient xpp g++-multilib g++-6-multilib gcc-6-doc libstdc++6-6-dbg gcc-multilib gcc-doc gcc-6-multilib libgcc1-dbg
> libgomp1-dbg libitm1-dbg libatomic1-dbg libasan3-dbg liblsan0-dbg libtsan0-dbg libubsan0-dbg libcilkrts5-dbg libmpx2-dbg libquadmath0-dbg gvfs glibc-doc glibc-doc:i386 libc-l10n:i386
> locales:i386 libdvdcss2 exiv2 glew-utils libglib2.0-doc gnutls-bin gpsd krb5-doc krb5-user gstreamer1.0-tools jackd2 lirc ncurses-doc qt4-qtconfig sndiod libstdc++-6-doc xapian-tools
> libteam-utils python3-doc python3-tk python3-venv python3-apt-dbg python-apt-doc python-dbus-doc python3-dbus-dbg python-pil-doc python3-pil-dbg python3.5-venv python3.5-doc sgml-base-doc
> Recommended packages:
> libkf5config-bin libqapt3-runtime qt-at-spi libwacom-bin
> The following packages will be REMOVED:
> akonadi-server akregator alien apper ark autoconf automake automoc build-essential coinor-libcoinmp1 debhelper dh-autoreconf dh-strip-nondeterminism docbook-xml dolphin dpkg-dev
> dragonplayer foomatic-db-engine freespacenotifier git google-earth-stable gwenview hplip htdig intltool-debian java-package jovie juk k3b k3b-i18n kaccessible kaddressbook kamera kate
> katepart kcalc kde-baseapps kde-baseapps-bin kde-plasma-desktop kde-runtime kde-runtime-data kde-standard kde-style-oxygen kde-window-manager kde-workspace kde-workspace-bin
> kde-workspace-dev kde-workspace-kgreet-plugins kdeaccessibility kdebase-workspace-dev kdelibs-bin kdelibs5-data kdelibs5-dev kdelibs5-plugins kdepasswd kdepim-kresources kdepim-runtime
> kdepimlibs-kio-plugins kdeplasma-addons kdesudo kdm kdoctools kfind khelpcenter4 kinfocenter klipper kmag kmail kmenuedit kmix kmousetool kmouth knotes konq-plugins konqueror
> konqueror-nsplugins konsole kopete korganizer kpart-webkit kscreen kscreensaver ksnapshot ksysguard ktorrent kwalletmanager kwrite libakonadi-calendar4 libakonadi-contact4
> libakonadi-kcal4 libakonadi-kde4 libakonadi-kmime4 libakonadi-notes4 libakonadiprotocolinternals1 libalgorithm-c3-perl libalgorithm-diff-perl libalgorithm-diff-xs-perl
> libalgorithm-merge-perl libarchive-extract-perl libarchive-zip-perl libattica0.4 libauthen-sasl-perl libbaloocore4 libbaloofiles4 libbaloopim4 libbalooqueryparser4 libbaloowidgets4
> libbalooxapian4 libboost-date-time1.55.0 libcalendarsupport4 libcec3v4 libcgi-fast-perl libcgi-pm-perl libclass-accessor-perl libclass-c3-perl libclass-c3-xs-perl libcpan-meta-perl
> libcrossguid0v4 libcups2-dev libcupsimage2-dev libdata-optlist-perl libdata-section-perl libdbusmenu-qt2 libdebconf-kde0 libdpkg-perl libencode-locale-perl liberror-perl libeventviews4
> libfcgi-perl libfile-basedir-perl libfile-copy-recursive-perl libfile-desktopentry-perl libfile-fcntllock-perl libfile-listing-perl libfile-mimeinfo-perl libfile-stripnondeterminism-perl
> libfollowupreminder4 libfont-afm-perl libgrantlee-core0 libhpmud0 libhtml-form-perl libhtml-format-perl libhtml-parser-perl libhtml-tagset-perl libhtml-tree-perl libhttp-cookies-perl
> libhttp-daemon-perl libhttp-date-perl libhttp-message-perl libhttp-negotiate-perl libincidenceeditorsng4 libintl-perl libio-html-perl libio-socket-ssl-perl libio-string-perl libk3b6
> libk3b6-extracodecs libkabc4 libkactivities-bin libkactivities-models1 libkactivities6 libkalarmcal2 libkateinterfaces4 libkatepartinterfaces4 libkblog4 libkcal4 libkcalcore4
> libkcalutils4 libkcddb4 libkcmutils4 libkcompactdisc4 libkdcraw23 libkde3support4 libkdeclarative5 libkdecorations4abi2 libkdecore5 libkdepim4 libkdepimdbusinterfaces4 libkdesu5 libkdeui5
> libkdewebkit5 libkdnssd4 libkemoticons4 libkexiv2-11 libkfile4 libkfilemetadata4 libkgapi2-2 libkholidays4 libkhtml5 libkidletime4 libkimap4 libkimproxy4 libkio5 libkipi11 libkjsapi4
> libkjsembed4 libkldap4 libkleo4 libkmanagesieve4 libkmbox4 libkmediaplayer4 libkmime4 libknewstuff2-4 libknewstuff3-4 libknotifyconfig4 libkntlm4 libkolab0 libkolabxml1 libkonq-common
> libkonq5abi1 libkonqsidebarplugin4a libkontactinterface4a libkopete4 libkparts4 libkpgp4 libkpimidentities4 libkpimtextedit4 libkpimutils4 libkprintutils4 libkpty4 libkresources4
> libkrosscore4 libkrossui4 libkscreen1 libkscreensaver5 libksgrd4 libksieve4 libksieveui4 libksignalplotter4 libktexteditor4 libktnef4 libktorrent-l10n libktorrent5 libkunitconversion4
> libkutils4 libkwineffects1abi5 libkwinglesutils1 libkwinglutils1abi2 libkworkspace4abi2 libkxmlrpcclient4 liblog-message-perl liblog-message-simple-perl liblsofui4 liblwp-mediatypes-perl
> liblwp-protocol-https-perl libmailcommon4 libmailimporter4 libmailtools-perl libmailtransport4 libmarblewidget19 libmessagecomposer4 libmessagecore4 libmessagelist4 libmessageviewer4
> libmicroblog4 libmodemmanagerqt1 libmodule-build-perl libmodule-pluggable-perl libmodule-signature-perl libmro-compat-perl libnepomuk4 libnepomukcore4 libnepomukquery4a libnepomukutils4
> libnet-dbus-perl libnet-http-perl libnet-smtp-ssl-perl libnet-ssleay-perl libnetworkmanagerqt1 libnfs4 libnoteshared4 libokularcore5 libopencv-core2.4 libopencv-imgproc2.4
> libp8-platform2v4 libpackage-constants-perl libpackagekitqt4-0 libparams-util-perl libparse-debianchangelog-perl libpcrecpp0 libperl4-corelibs-perl libperl5.20 libphonon-dev libphonon4
> libpimcommon4 libplasma3 libplasmaclock4abi4 libplasmagenericshell4 libpod-latex-perl libpod-readme-perl libpolkit-qt-1-1 libprocesscore4abi1 libprocessui4a libqapt-runtime libqapt1
> libqoauth1 libqt4-dbus libqt4-declarative libqt4-designer libqt4-dev libqt4-dev-bin libqt4-help libqt4-network libqt4-opengl-dev libqt4-qt3support libqt4-script libqt4-scripttools
> libqt4-xmlpatterns libqt5declarative5 libqt5designer5 libqt5designercomponents5 libqt5gui5 libqt5help5 libqt5network5 libqt5opengl5 libqt5opengl5-dev libqt5printsupport5 libqt5qml5
> libqt5quick5 libqt5quickparticles5 libqt5quicktest5 libqt5quickwidgets5 libqt5svg5 libqt5svg5-dev libqt5svg5-private-dev libqt5webkit5 libqt5widgets5 libqt5x11extras5 libqt5x11extras5-dev
> libqt5xmlpatterns5 libqtassistantclient4 libqtcore4-perl libqtdbus4 libqtgui4-perl libqtlocation1 libqtruby4shared2 libqtwebkit-dev libqtwebkit4 libregexp-common-perl libreoffice
> libreoffice-avmedia-backend-gstreamer libreoffice-base libreoffice-base-core libreoffice-base-drivers libreoffice-calc libreoffice-core libreoffice-draw libreoffice-help-en-us
> libreoffice-impress libreoffice-kde libreoffice-math libreoffice-report-builder-bin libreoffice-sdbc-hsqldb libreoffice-writer libsane-hpaio libsendlater4 libsmokekdecore4-3
> libsmokekdeui4-3 libsmokekfile3 libsmokekhtml3 libsmokekio3 libsmokeknewstuff2-3 libsmokeknewstuff3-3 libsmokekparts3 libsmokektexteditor3 libsmokekutils3 libsmokeplasma3
> libsmokeqtdbus4-3 libsmokeqtnetwork4-3 libsmokeqtwebkit4-3 libsmokesolid3 libsnmp30 libsoftware-license-perl libsolid4 libsoprano-dev libsoprano4 libsub-exporter-perl libsub-install-perl
> libsub-name-perl libswitch-perl libsyndication4 libtag1-vanilla libtag1c2a libtaskmanager4abi4 libtemplateparser4 libterm-ui-perl libtext-soundex-perl libtext-template-perl
> libtext-unidecode-perl libtie-ixhash-perl libtimedate-perl libtinyxml2.6.2 liburi-perl libvlc5 libvlccore8 libweather-ion6 libwww-perl libwww-robotrules-perl libx11-protocol-perl
> libxml-libxml-perl libxml-namespacesupport-perl libxml-parser-perl libxml-sax-base-perl libxml-sax-expat-perl libxml-sax-perl libxml-twig-perl libxml-xpathengine-perl lsb-core lsof
> marble-plugins mythes-en-us network-manager-vpnc okular perl perl-modules phonon phonon-backend-vlc pkg-kde-tools plasma-containments-addons plasma-dataengines-addons
> plasma-dataengines-workspace plasma-desktop plasma-nm plasma-runners-addons plasma-scriptengine-javascript plasma-scriptengine-python plasma-scriptengine-ruby
> plasma-scriptengine-superkaramba plasma-scriptengine-webkit plasma-scriptengines plasma-wallpapers-addons plasma-widget-cwp plasma-widget-folderview plasma-widget-lancelot
> plasma-widget-networkmanagement plasma-widgets-addons plasma-widgets-workspace po-debconf polkit-kde-1 printer-driver-hpcups printer-driver-hpijs printer-driver-postscript-hp python-kde4
> python-qt4 python3-pykde4 python3-pyqt4 python3-uno qapt-batch qdbus qml-module-qtquick-controls qml-module-qtquick-layouts qml-module-qtquick-window2 qml-module-qtquick2 qt-sdk
> qt4-designer qt4-dev-tools qtbase5-dev qtbase5-dev-tools qtcreator qtdeclarative4-kqtquickcharts-1 qtdeclarative5-dev qtdeclarative5-dev-tools qtquick1-5-dev-tools qttools5-dev-tools
> qtxmlpatterns5-dev-tools rename rpm ruby-kde4 ruby-plasma ruby-qt4 ruby-qt4-webkit sane-utils sgml-data software-properties-kde soprano-daemon sweeper systemsettings task-kde-desktop
> texinfo update-inetd vlc vlc-nox vlc-plugin-notify vlc-plugin-pulse vlc-plugin-samba vpnc yakuake
> The following NEW packages will be installed:
> coinor-libcoinmp1v5 cpp-6 default-mysql-client-core fonts-noto-hinted fonts-noto-mono fonts-roboto-hinted g++-6 gcc-6 gcc-6-base gcc-6-base:i386 ieee-data kdeplasma-addons-data
> kpackagetool5 ksysguard-data libapt-inst2.0 libapt-pkg5.0 libasan3 libboost-date-time1.62.0 libboost-filesystem1.62.0 libboost-iostreams1.62.0 libboost-system1.62.0 libbotan-1.10-1
> libc-l10n libc6:i386 libcc1-0 libcec4 libclang1-3.9 libcmis-0.5-5v5 libcrossguid0 libdouble-conversion1 libebur128-1 libexiv2-14 libgcc-6-dev libgcc1:i386 libgif7 libglew2.0
> libgltf-0.0-0v5 libgnutls30 libgps22 libhogweed4 libhunspell-1.4-0 libical2 libicu57 libinput-bin libinput10 libisl15 libkf5akonadiprivate5 libkf5archive5 libkf5codecs-data libkf5codecs5
> libkf5config-data libkf5configcore5 libkf5coreaddons-data libkf5coreaddons5 libkf5i18n-data libkf5i18n5 libkf5package-data libkf5package5 liblirc-client0 libllvm3.9 libmariadbclient18
> libmicrohttpd12 libmpg123-0 libmpx2 libnettle6 libnfs8 libnm0 libopencv-core2.4v5 libopencv-imgproc2.4v5 libopenmpt0 liborcus-0.11-0 libp8-platform2 libpcre16-3 libpcre32-3 libpcrecpp0v5
> libpgm-5.2-0 libplist3 libpng16-16 libpython3.5 libpython3.5-minimal libpython3.5-stdlib libqapt3 libqt5sql5-mysql libreadline5 libreadline7 libsndio6.1 libsodium18 libssl1.0.2 libssl1.1
> libstdc++-6-dev libtag1v5 libtag1v5-vanilla libtinyxml2.6.2v5 libvpx4 libwacom-common libwacom2 libwayland-bin libwebp6 libwebpdemux2 libwebpmux2 libwps-0.4-4 libx264-148 libx265-95
> libxapian30 libzmq5 mariadb-client-core-10.1 mariadb-common perl-openssl-defaults policykit-1-gnome python3.5 python3.5-minimal tex-common
> The following packages will be upgraded:
> akonadi-backend-mysql apper-data apt apt-utils binutils cpp cups cups-bsd cups-client cups-common cups-core-drivers cups-daemon cups-server-common dbus g++ gcc gstreamer1.0-plugins-base
> gstreamer1.0-plugins-good hplip-data k3b-data kde-baseapps-data kodi kodi-bin kodi-data ksysguardd ktorrent-data libass5 libastro1 libatomic1 libavfilter6 libc-bin libc-dev-bin libc6
> libc6-dbg libc6-dev libc6-i386 libcilkrts5 libcups2 libcupscgi1 libcupsimage2 libcupsmime1 libcupsppdc1 libdbus-1-3 libdbus-1-dev libdvdnav4 libdvdread4 libgcc1 libgirepository-1.0-1
> libglib2.0-0 libglib2.0-bin libglib2.0-dev libgomp1 libgssapi-krb5-2 libgstreamer-plugins-base1.0-0 libgstreamer1.0-0 libio-socket-ip-perl libitm1 libjack-jackd2-0 libk5crypto3
> libkdcraw-data libkexiv2-data libkipi-data libkrb5-3 libkrb5support0 liblircclient0 liblocale-gettext-perl liblsan0 liblz4-1 libmodplug1 libmpdec2 libmpfr4 libncurses5 libncurses5-dev
> libncursesw5 libnuma1 liborc-0.4-0 libp11-kit0 libpci-dev libpci3 libpcre3 libpcre3-dev libpython3-stdlib libqt4-opengl libqt4-sql libqt4-sql-mysql libqt4-sql-sqlite libqt4-svg
> libqt4-test libqt4-xml libqt5clucene5 libqt5concurrent5 libqt5core5a libqt5dbus5 libqt5script5 libqt5sql5 libqt5sql5-sqlite libqt5test5 libqt5xml5 libqtcore4 libqtgui4 libquadmath0
> libstdc++6 libtasn1-6 libtext-charwidth-perl libtext-iconv-perl libthreadweaver4 libtinfo-dev libtinfo5 libtsan0 libubsan0 libwayland-client0 libwayland-cursor0 libwayland-dev
> libwayland-server0 libxkbcommon-dev libxkbcommon-x11-0 libxkbcommon-x11-dev libxkbcommon0 linux-libc-dev locales marble-data mysql-common ncurses-bin network-manager network-manager-pptp
> pciutils perl-base ppp printer-driver-brlaser python3 python3-apt python3-dbus python3-gi python3-minimal python3-pil python3-reportlab-accel python3-sip qt4-linguist-tools qt5-qmake
> qtchooser qtcreator-data sgml-base task-desktop task-english task-print-server tasksel tasksel-data
> 147 upgraded, 112 newly installed, 487 to remove and 1170 not upgraded.
> Need to get 223 MB of archives.
> After this operation, 924 MB disk space will be freed.
> Do you want to continue? [Y/n]
That’s why i want to avoid installing unstable version it would reconfigure half of my system. I will install old version of osmc
It looks like you’re on Debian. The version in backports is 16.1 and 17.1 is sitting in unstable, as you say. That’s not to say that Kodi 17.1 is unstable; after all, it’s not a release candidate and is being used elsewhere, including on OSMC and Ubuntu. It’s also not v17.0 , so will have had some initial bugs ironed out by now. This is much more likely to be a reflection of the conservative (some might say glacial) Debian approach to upgrading. As I’m sure you know, the Debian Jessie kernel is still on 3.16.39-1+deb8u2 (2017-03-07) when most other distributions are well into v4.
