How to eject SD Card from Vero 1?
Hi all,
Apologies for the (potentially) silly Q, but…
…does anyone know how you’re supposed to remove the MicroSD card from a Vero 1?
I’ve tried pushing it (in case it’s a “click-in/out” slot), but no.
I’ve tried pulling on it (tho, not a lot to grab, due to narrow gap) and also, no joy
Am I missing something, or just a case of not trying hard enough? :sweat_smile:
Thanks in advance!
Some of the later models had a push-push SD slot, but the earlier ones were not spring loaded.
Assuming it hasn’t been inserted the wrong way, you can use a paperclick on its side to push the SD card up from underneath while pulling it towards you.
Got it! Thanks Sam :blush:
