Hi, I just transferred from OpenELEC to OSMC, and I really enjoy it. I just want to get the apple tv remote (silver) to work with the raspberry pi?
I have a IR GPIO Adapter, and I can ssh into the raspberry pi, but other then that, I don’t really know where to go from here?
I enabled the IR GPIO in the MyOSMC Settings, and that was it.
Any help would be greatly appreciated!
Thanks,
You need to go to MyOSMC>remotes(remote icon) and select your remote from there. If you don’t have a remote icon then go to updates and update
Do the update through MyOSMC? Or update through the main system?
Didn’t we have this same convo less than 24hrs ago?
[14:25] <>>> Appl3Kork<<<>ActionA the update inside the MyOSMC addon? or
update somewhere else?
[14:25] <@ActionA>inside
[14:25] < Appl3Kork>i'll try that
[14:25] <@ActionA>or by traditional linux methods
[14:25] <@ActionA>same either way
Yes ActionA we had the same convo. I couldn’t get it working, so I figured I’d try the forums… I do the update inside of MyOSMC and when i reboot no remote icon is in there?
Try
sudo apt-get update sudo apt-get dist-upgrade
Ok the Remote Icon is there now, I selected the remote, and enabled IR in the rpi config, rebooted. Still not getting anything from the remote? Is there something else I was suppose to do?
Yes, learn the remote and submit a copy of your learned conf . The Apple remotes are strange in that different remotes will put out different signals, I assume this is so that more than one ATV can survive in a room without conflicts. Our conf file supplied with OSMC has several but not all possible remote configurations so if it doesn’t work then remote learning will be needed. This is not hard as there are only 7 or so buttons. Assuming there are a finite number of remote possibilities as more conf files are submitted by users and then added to our existing conf file we will eventually have them all covered.
How do I go about making the remote learn the keys, and submitting it to where?
I should really redo this for OSMC but haven’t.
OSMC Forums scroll down to Step 3 of the post. Any path name that contains pi will need to be changed to osmc
If you post the completed conf file to dropbox or http://paste.osmc.io/ with a link here I will see to it that it makes it to the right place and thanks in advance for your contribution
OK so that got it working! can’t thank you enough! Just one problem… The ENTER Key or SELECT Key, I marked them as KEY_SELECT but that didn’t work, then tried KEY_ENTER, and that wouldn’t work either? Is there a certain command I can make that key so that it selects the tab that i highlight in OSMC?
Try KEY_OK not at home to check but that may be the one
Pete
Thanks Pete, but that one doesn’t work either
KEY_OK is the enter/select key, the other tricky one is KEY_TITLE which is ContextMenu (right click)
Post a link to the completed conf if you would.
You’ll need a reboot after any changes to make them work, KEY_OK is right
Here’s the code of the lircd.conf:
# Please make this file available to others
# by sending it to <lirc@bartelmus.de>
# this config file was automatically generated
# using lirc-0.9.0-pre1(default) on Tue Dec 11 23:40:38 2012
# contributed by
# brand: apple
# model no. of remote control: A1294
# devices being controlled by this remote:
begin remote
name apple_a1294_1
bits 8
flags SPACE_ENC|CONST_LENGTH
eps 30
aeps 100
header 9074 4475
one 572 1660
zero 572 554
ptrail 571
repeat 9074 2235
pre_data_bits 16
pre_data 0x77E1
post_data_bits 8
post_data 0x37
gap 108392
toggle_bit_mask 0x0
begin codes
KEY_UP 0x50
KEY_DOWN 0x30
KEY_LEFT 0x90
KEY_RIGHT 0x60
KEY_OK 0x3A 0xA0
KEY_MENU 0xC0
KEY_PLAY 0xFA 0xA0
end codes
end remote
begin remote
name apple_a1294_2
bits 8
eps 30
aeps 100
header 9070 4445
one 588 1638
zero 588 534
ptrail 589
repeat 9077 2212
pre_data_bits 16
pre_data 0x77E1
post_data_bits 8
post_data 0xD1
gap 108062
toggle_bit_mask 0x0
begin codes
KEY_UP 0xD0
KEY_DOWN 0xB0
KEY_LEFT 0x10
KEY_RIGHT 0xE0
KEY_OK 0xBA 0x20
KEY_MENU 0x40
KEY_PLAY 0x7A 0x20
end codes
end remote
begin remote
name apple_a1294_3
bits 8
eps 30
aeps 100
header 9107 4428
one 607 1619
zero 607 519
ptrail 608
repeat 9108 2196
pre_data_bits 16
pre_data 0x77E1
post_data_bits 8
post_data 0x10
gap 108212
toggle_bit_mask 0x0
begin codes
KEY_UP 0x50
KEY_DOWN 0x30
KEY_LEFT 0x90
KEY_RIGHT 0x60
KEY_OK 0x3A 0xA0
KEY_MENU 0xC0
KEY_PLAY 0xFA 0xA0
end codes
end remote
begin remote
name apple_a1294_4
bits 8
eps 30
aeps 100
header 9054 4472
one 561 1663
zero 561 567
ptrail 565
repeat 9055 2236
pre_data_bits 16
pre_data 0x77E1
post_data_bits 8
post_data 0xF1
gap 108151
toggle_bit_mask 0x0
begin codes
KEY_UP 0x50
KEY_DOWN 0x30
KEY_LEFT 0x90
KEY_RIGHT 0x60
KEY_PLAY 0xFA 0xA0
KEY_MENU 0xC0
KEY_OK 0x3A 0xA0
end codes
end remote
@Appl3Kork That file looks like the bundled one, I don’t see your learns in it
Hmm, I followed step 3 and on, and everything seemed to be working. I’ll give it another go.
It was saving it as lircd.conf.conf that’s why I didn’t see it:
# using lirc-0.9.0(default) on Sun Apr 5 17:35:30 2015
# contributed by
# brand: /home/osmc/lircd.conf.conf
begin remote
name /home/osmc/lircd.conf.conf
flags RAW_CODES|CONST_LENGTH
eps 30
aeps 100
gap 107756
begin raw_codes
name KEY_UP
9038 4444 541 584 533 1685
530 1687 540 1678 540 582
532 1714 535 1655 561 1663
537 1687 529 1707 505 1685
538 580 541 581 535 586
533 585 532 1714 533 1650
546 1708 506 586 534 1685
541 579 539 580 536 585
537 583 533 586 532 588
546 1675 566 554 532 1687
532 588 539 1680 536 1704
579
name KEY_RIGHT
9003 4486 540 580 558 1659
588 1605 620 1598 568 578
539 1690 527 1682 533 1683
544 1717 501 1692 530 1675
566 553 531 588 539 581
558 562 536 1684 562 1656
583 1637 536 1681 535 586
533 585 562 557 542 605
555 539 535 609 508 586
532 1686 540 578 542 1679
535 584 580 1641 531 1703
561
name KEY_DOWN
9016 4488 534 555 562 1680
536 1685 550 1669 537 609
509 1721 497 1712 514 1678
552 1666 534 1687 560 1656
539 610 538 553 535 611
519 577 537 1681 538 1680
535 585 534 1690 577 1645
535 581 537 583 566 583
517 569 540 579 540 604
513 1683 552 568 532 1688
558 591 506 1680 569 1666
534
name KEY_LEFT
9033 4552 465 591 535 1693
535 1704 534 1627 587 584
504 1687 562 1657 535 1684
563 1655 531 1699 526 1680
538 582 564 555 533 560
558 591 538 1679 568 563
524 585 534 586 531 1687
590 531 537 581 537 582
536 587 565 553 585 541
535 1695 553 559 555 1656
562 583 513 1697 519 1698
537
name KEY_OK
9010 4481 566 556 541 1704
512 1706 510 1709 550 571
502 1689 538 1707 539 1678
509 1688 558 1670 529 1771
472 555 532 587 530 590
538 582 567 1653 535 1681
563 559 559 1660 566 1658
531 1681 563 558 539 1653
593 553 536 585 532 587
562 1656 559 562 567 1653
532 588 530 1688 539 1696
540
name KEY_MENU
9029 4462 567 556 532 1687
626 1602 535 1674 535 583
534 1712 514 1677 539 1705
481 1740 505 1714 513 1678
560 561 536 619 498 587
540 606 531 1687 509 585
533 1686 540 579 539 591
528 560 558 612 536 558
560 584 515 605 512 582
536 1721 500 614 504 1729
494 605 511 1682 534 1701
586
name KEY_PLAYPAUSE
9038 4446 560 533 565 1664
553 1685 547 1671 538 577
539 1684 563 1652 564 1649
547 1680 566 1652 564 1653
593 529 558 563 534 596
523 585 532 1687 540 580
540 1681 534 1684 531 1699
531 1680 562 554 537 1682
539 586 558 561 538 582
565 1634 580 552 565 1630
586 561 541 1651 612 1622
564
end raw_codes
end remote
But hey, it’s working now! Thanks for your help!
