I have recently purchased a Vero and I have added the Trakt Add-on.
It requires a pin which you need to enter on a pop-up screen - does anyone know how you enter a pin into the box using the remote supplied with the Vero?
nope but my guess is that you can add a usb keyboard into your machine and go from there or use yatse
Yes tks that was the only way to do it - I used the official Kodi app which has a keyboard option on it.
