Got no errors but the AP only appeared once and disappeared while the system is still on. The wireless adapter is still blinking though. Any clues of what went wrong?
i see. well just got it to work but it’s stuck in “obtaining IP” for android devices. Laptop works fine. Anyway thanks, at least it works but it has to be configured using the terminal and not through the GUI. Will try the other links.
I have had similar problems. Originally, this was fixed by:
It worked fine until the most recent update - now I am back to my android phone not being able to connect, or connecting and immediately disconnecting
Should also add that only selected wifi adapters support tethering (and not the most common one). I am not sure about TL-WN725N. I asked about particular models in this post, and was told that you need a chipset that’s supported by the nl80211 driver and supports the AP mode. There are some links in that post that might help you find out about your particular dongle.
Thanks. it helps. been busy these few days so am not able to reply frequently. Well guess i will just have to purchase another wifi dongle for the moment or revert to my old bulky wifi dongle. Strange that both of my older wifi dongles works just fine (Wifi & AP). Which are the TL-WN727N v1 or v2 and a getnet wifi dongle. Will do a little digging on the drivers, if i have the time. By the way, do the original raspberry pi wifi dongles work fine with OSMC?
Read that scripts instructions to learn how to make it a daemon and add it to /etc/rc.local if you want to start it at boot. Or find a better way to start it, I never really looked into it.
hmmm… I think I followed the steps correctly, but seems to be taking a very long time to setup the wireless AP? It’s been stuck on rtl871x_set_key_ops for about two hours, with this line repeating about a dozen times so far. Does that seem right?
edit: well, definitely not right - I’ve let it continue to run overnight, and just more of the same. I can see the AP using my phone, but cannot connect to it.
Hi I following your steps, it seems everything is ok during my settings, but when I tried to connect my phone to Pi, it gave the prompt “the password is wrong”. Could you please give some suggestions?
I am using the latest OSMC version ( Feb.2016)(kernel is 4.4.3)
I don’t think it make sense to ask such a question in this thread which is related to a specific wifi adapter.
Suggest you open a new thread explaining your problem and how you try to access OSMC (ssh or web).
Also first read thru the WIKI that you have checked everything there.
In fact, I used the same usb wifi adapter as @shadow, that’s why I asked him/her for help.
I don’t think opening a new thread is better because it is related topic.
In any case, I need to provide more trace for this problem.
Yes. The password should be correct.
I tried with the latest standard raspbian and it has the same result. so I think it is not related with the OSMC. I will try it on my laptop and check if it can work.
