I’ve used alsa-utils (specifically alsamixer) with LibreELEC with some success, and would like to try it with OSMC / Kodi v19 test builds on my Vero 4K+, for L / R balance adjustments (my 2 channel amp lacks a balance adjustment). It’s available thru the Kodi repo on LE, but I think I’ll need some command-line sorcery with OSMC.
What commands do I need to install it?
To run it? - (probably alsamixer, ?)
To make any adjustments stick thru a re-boot / re-start?
Thank you very much in advance
