Did try to install drivers, but without success.
using RPi2
Linux osmc 3.18.13-1-osmc
headers installed
using hg clone ~endriss/media_build_experimental: log
after make got error
File not found: /lib/modules/3.18.13-1-osmc/build/.config at ./scripts/make_kconfig.pl line 34, line 4.
make[1]: *** No rule to make target ‘Kconfig’, needed by ‘.myconfig’. Stop.
make[1]: Leaving directory ‘/home/osmc/media_build_experimental/v4l’
Makefile:28: recipe for target ‘all’ failed
make: *** [all] Error 2
on raspbian installation is ok
thanks for help
