i have created manual for simple installation of JDownloader2 with gui. I hope it helps you if you are interested. Tested on rapsberry pi 2
step install packages:
sudo apt-get update && sudo apt-get install openbox x11vnc Xvfb -y -
create jdownload directory
mkdir ~osmc/jdownloader -
download jdownloader2
cd ~osmc/jdownloader && wget http://installer.jdownloader.org/JDownloader.jar -
download and install Java8
cd ~osmc && wget --no-check-certificate --no-cookies --header "Cookie: oraclelicense=accept-securebackup-cookie" http://download.oracle.com/otn-pub/java/jdk/8u121-b13/e9e7ea248e2c4826b92b3f075a80e441/jdk-8u121-linux-arm32-vfp-hflt.tar.gz -
Now extract java8 to /opt directory
sudo tar zxfv jdk-8u121-linux-x64.tar.gz -C /opt -
install java8 so system can use it
sudo update-alternatives --install "/usr/bin/java" "java" /opt/jdk1.8.0_121/bin/java 1 -
check if java is installed
java -version
output:
osmc@osmc:/etc/systemd/system$ java -version
java version "1.8.0_121"
Java(TM) SE Runtime Environment (build 1.8.0_121-b13)
Java HotSpot(TM) Client VM (build 25.121-b13, mixed mode)
systemd starting unit all file place to
/etc/systemd/systemosmc@osmc:/etc/systemd/system$
cat xvfb.service
[Unit]
Description=Xvfb[Service]
ExecStart=/usr/bin/Xvfb :1 -screen 0 1600x900x24
User=osmc[Install]
WantedBy=multi-user.targetosmc@osmc:/etc/systemd/system$
cat openbox.service
[Unit]
Description=Openbox[Service]
Environment=“DISPLAY=:1”
ExecStart=/usr/bin/openbox-session
User=osmc[Install]
cat vnc.service
[Unit]
Description=x11vnc[Service]
ExecStart=/usr/bin/x11vnc -forever -display :1 -xkb
User=osmc[Install]
cat jdownloader.service
[Unit]
Description=JDownloader
Before=shutdown.target
After=networking.service
Conflicts=shutdown.target[Service]
Type=forking
EnvironmentFile=/etc/JDownloader2.cfg
Environment=DISPLAY=:1
Restart=no
TimeoutSec=5min
IgnoreSIGPIPE=no
KillMode=process
GuessMainPID=no
RemainAfterExit=no
ExecStart=/sbin/start-stop-daemon --start --quiet --background --make-pidfile --pidfile $PIDFILE --chuid $RUN_AS --exec $COMMAND
ExecStop=/sbin/start-stop-daemon --stop --quiet --pidfile $PIDFILE
Config file for jdownloader2 in /etc/
osmc@osmc:/etc/systemd/system$ cat /etc/JDownloader2.cfg
DESC=“JDownloader 2”
NAME=JDownloader2
COMMAND="/usr/bin/java – -jar /home/osmc/jdownloader/JDownloader.jar"
RUN_AS=osmc
PIDFILE=/var/run/jdownloader.pid
Always reload systemd daemon if you are making some changes to your config files
sudo systemctl daemon-reload -
If you want autostart after reboot you have to enable services like bellow
sudo systemctl enable xvfb.service
to check if is enabled use
`sudo systemctl is-enabled xvfb.service`
start all services
sudo systemctl start xvfb.service
sudo systemctl start openbox.service
sudo systemctl start vnc.service
sudo systemctl start jdownloader.service
5 you can always check with status if the service is running
osmc@osmc:/etc/systemd/system$ `sudo systemctl status vnc.service`
* vnc.service - x11vnc
Loaded: loaded (/etc/systemd/system/vnc.service; enabled)
`Active: active (running)` since Mon 2017-04-10 12:51:26 CEST; 6h ago
Main PID: 301 (x11vnc)
CGroup: /system.slice/vnc.service
`-301 /usr/bin/x11vnc -forever -display :1 -xkb -rfbauth /home/osmc/.vnc/passwd
Notes:
If you would like use password protected vnc you have to create password, but please note vnc has not encrypted communication outside your network you can use ssh tunnel
x11vnc -storepasswd and store to /home/osmc/.vnc/passwd
config file have extra parameter -rfbauth /home/osmc/.vnc/passwd
root@osmc:/etc/systemd/system# cat vnc.service
[Unit]
Description=x11vnc
[Service]
ExecStart=/usr/bin/x11vnc -forever -display :1 -xkb -rfbauth /home/osmc/.vnc/passwd
User=osmc
[Install]
now install vncviewer and enjoy!!! vnc should listen on port yourip:5900
