So I found the MythTV frontend in the disabled add ons, but I still need to get the back end up and running on my Rasp Pi 2 with the latest OSMC installed. Unfortunately, I do not know how to do this. Can anyone help me through this process? It would be greatly appreciated.
Here is a template you can just copy, paste, and fill in as needed:
Device: Rasp Pi 2
Ram: 1024
Installation media: SDcard
Connection: Wired
Power Supply Type: Phone Adapter
Power specs:
Peripherals: USB HUB with External HD (ext4)
Audio/Video Output: HDMI
Currently I’m using an RPi2 to stream my movies and TV shows directly to my TV, so I would really like to try and get my Live TV running on this as well (then I have everything in one). Live TV is even included in the main menu and PVR clients are pre-installed. So why would it not be recommended?
This tells me to install Raspbian which I of course do not want to do since I have already installed OSMC on my RPi, would this guide also work for OSMC?
