Such as?
I tried imagewriter, but it only allows to write into USB. I would love to try some others, although I know they are just GUI shells for dd, but maybe they use some better optimized options then I did?
May be, but the power supply was in a bundle, dedicated to that unit, along with a classic cover. Just like the cover, power supply has a raspberry logo, so I assume this is the official stuff. Besides, I’m preparing SD cards on my laptop and then try to use them inside raspberry, and they all don’t work, so something must be off. Initially I thought that was the problem with the SD, but now I believe it may be a mixture of both. The first SD just failed, but the others must be prepared or flashed in some other way to make them work, since they weren’t empty and used by proprietary software. In theory, zeroing should clean them, but maybe the normal options are not enough. I don’t know enough dd to figure out what to set, so I could be sure it’s empty.
Also, when I do zeroing, I get some weird error about lack of space (which is not a typical error), but writing seems to be fine. And oh, another problem is that after zeroing, the SD card has only 3,8GB of space, and it should show 29,99GB or something like that, so zeroing is not working properly. Someone with intricate knowledge of how discs, sectors, tables and partitions work should step in.
Yes and no. There are plenty novice Linux users who don’t. Besides, dd tool has many options and because we know basic ones to write Linux image to USB, doesn’t mean we know how to set it to create an optimized image on SD card. Maybe there are some differences we should pay attention to? Or maybe not? I don’t know and nobody seems to know.
Besides, not all Linux users are technic or IT specialists. Many of us are just semi-technical power users, who don’t understand advanced, technical jargon, but are doing fine on most day-to-day basis. We need some help, tutorials to figure out stuff thou.
Just as the Windows users are very, very different, from power users, IT specialists to casual users who wouldn’t handle a simple issue with the system. In the same way, Linux users differ, but on average, we are more technical and know our way around the systems. However, assuming that we all posses the same kind of esoteric and advanced knowledge is just wrong.
If the downloader was in a deb format, this is indeed an obsolete format. AppImage would be the best one. It would work for everyone, just download and run. Nothing more is needed.
With time, there will be more Linux users who will choose the convenience and simplicity of that solution. It would also ensure, that the process of flashing SD is done by the book. Now, I don’t know what am I doing, because there may be many variations or a simple knowledge piece that can make the whole difference.
