Hello everyone,
I have lots searched the net to find a way to install Perguardian / PeerBlock on my Raspberry Pi 2.
I followed several tutorial without success.
Someone will have the procedure to install via the console ?
Thank you in advance!!
Hello everyone,
no need for peerguardian you can easily block stuff via host filesā¦
/etc/hosts.deny
just add the dns to this file
or if your using dnsmasq you can use this to block peers in dnsmasq.conf and add this value
addn-hosts=(path/to/your/blocklist)
Hi Toast!
I did not think that was so simple!
Thanks you verry much for your answer !!
it is peerguardian isnt compatible with osmc since it needs a window manager and since OSMC boots into Kodi that makes it incompatibleā¦
but what a āpeerguardianā does is to block ips so we do it ourselvs at a systemlevel using hosts files
you can use already existing projects such as
there are instructions on that site on how to
or you can hack your own script simply enough by looking at the shell script ![]()
p.s it aint that hard it just takes time and you dont have to be afraid to break shit ![]()
Thank you for all the details Toast !!
Did it! Worked 100% Thx you !!!
i went another route and added it everything too my router
replacing all ads with 1x1 pixel and blocking bad peers, malware and other junk.
