For remove this error notification I advice you to use next command option
mkdir -p backup
mkdir -p backup
Thanks, that got rid of the the mkdir error but still getting:
Going to back up to /media/Big\ Bertha/osmcbackup/2017-07-10 (unless I can't find it).
mount error: could not resolve address for SERVER: Unknown error
mount: can't find /media/Big Bertha/backup in /etc/fstab
looking for mounted media
media for /media/Big\ Bertha/osmcbackup not mounted in /media or /mnt or not formatted for linux
Itās not quite that simple. You have to do something like
dd if=/dev/zero of=/media/Big\ Bertha/extimagefile bs=1M count=1 seek=50000
mkfs.ext4 -F /media/Big\ Bertha/extimagefile
Thatās what I mean by āmake an ext4 filesystem imageā, before
mkdir /media/backup
mount -o loop /media/Big\ Bertha/extimagefile /media/backup
Run the above commands before you run osmc-backup and make sure you can ls /media/backup Itās better not to cd /media in fact. And yes, -p is a good suggestion. The above will make a 50GB āsparseā image ie one which actually takes up only as much space as its contents need. This may have been the reason for the āpainfully slowā remark. You may do better with count=50000 and no seek parameter.
Itās better donāt use mount a point name with spaces in it.
Yes but once itās loop mounted with a new name, should work.
Cool, all seems to be working.
Should I add the lines to the script?
mkdir /media/backup
No. The first two lines will wipe your last backup!
You could put the mkdir and mount lines in the script, and consider adding umount /media/backup and rmdir /media/backup at the end unless you want to leave it mounted to examine the contents.
Would be interested in how long it takes.
Assuming it worked as expected it was pretty quick!
Error with rsync though?
system is on /dev/mmcblk0p2
Backing up system partition to /media/backup/2017-07-10/system
Backup directory is empty - making first copy
Time to back up system: 00h:05m:42s
boot is on /dev/mmcblk0p1
Backing up boot partition to /media/backup/2017-07-10/boot
Time to back up boot: 00h:00m:03s
cp: cannot stat '/home/osmc/osmc-backup/rsynclog2017-07-10': No such file or directory
2690832 KiB used in this backup
44945468 KiB available on drive
All done!
No. Small bug - only happens on first backup. Thought Iād fixed it but no.
Straight from the debian repo:
rsync version 3.1.1 protocol version 31
Sorry I meant my script. Itās not an rsync problem, just me
Thanks for testing! It should be that quick for only 2.7GB. Thatās one of the advantages over imaging with dd
Script 0.1.6a, cloned this morning
Iām going to exclude my downloads folder (because its usually full of rubbish) so that should keep it small.
Try to add next string
touch $LOGFILE
after the string #73 in your script.
Yeah. No I just didnāt redirect the rsync ouput in 229. Itās fixed in a version I have which uses a remote rsync server but forgot to add it to the master branch.
Would it be worth having a āif thenā check for a mounted folder for an NTFS drive? So that if there isnāt a mounter folder then it creates and mounts, if there is then leave it alone and run as normally.
Could un-hash the check lines and then customise the paths. It makes it moron proof (aimed squarely at me!).
Or is that too dangerous?
You would have to tell it how big to make it. Once youāve created and formatted the image, itās just like any other disc. You could put it in fstab if you are backing up regularly.
We could say if the destination is on ntfs, try and mount some part of the path (iteratively) and check if that is an ext partition, but automatically creating it does sound a bit scary.
Iām still not sure what happens if you try to back up to an ntfs, shared via nfs (which should fail) or ext4, shared via samba. Canāt cater for everyone!
Iām getting this in my backlog:
Backing up boot partition to /media/backup/2017-07-11/boot
There are 1 previous backups
Found latest backup at /media/backup/2017-07-10/boot
Incremental backup: copying new and changed files to /media/backup/2017-07-11/boot
rsync: link_stat "/media/ --exclude=.gvfs" failed: No such file or directory (2)
rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1183) [sender=3.1.1]
Making a copy of the new and changed files in /media/backup/2017-07-11/boot-delta
Cloning unchanged files from previous backup
Deleting files no longer on source
Time to back up boot: 00h:00m:04s
Anything I need to be worried about?
I checked, and you are right in that the boot flag was not set.
The boot partition was also empty.
I copied across the boot partition files form the backup and reset the flag to be bootable, but the backup still doesnāt boot.
What would you like me to post in way of debugging it?
Not sure. If you mount your ext image, does it look like all the files in /media/backup/2017-07-11/boot are there? (ie vs /boot on the SD card). You can get a detailed comparison using diff.
Can you post the whole output for the 2017-07-11 backlog, please?
Itās the LBA flag you need. RPi doesnāt care about the boot flag. Should look something like this
osmc@osmc:~$ sudo fdisk -l /dev/mmcblk0
Disk /dev/mmcblk0: 29.7 GiB, 31914983424 bytes, 62333952 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x7354d8e6
Device Boot Start End Sectors Size Id Type
/dev/mmcblk0p1 8192 507903 499712 244M c W95 FAT32 (LBA)
/dev/mmcblk0p2 507904 62333951 61826048 29.5G 83 Linux
