Hi!
I would like to get a simple dummy manual that help me to on a easy way migrate my Raspbmc Kodi installation over to a OSMC Kodi installation.
I have a PI B2 and is able to use a USB disk as a media to transfer all necessary data behind the different versions. I want to use my original SDHC card as boot devise in the both case (the same one).
I want all my plugin and the database to be moved over to the new OSMC installation so I don’t miss al the mark on movies I already have seen. I’m hoping to be able to use all the already installed plugins thrue the move without a need to reinstall them.
I´m using Kodi 14.1 feb 2 2015.
Please make this a simple dummy walk thru step by step. Because I´m not so good to use a command line interface.
I have try this and export the files as it is described at tha wiki.
Now I can’t find wat location the export have been made to.
I did not get prompted to select any localtion so now I don’t now ware the export is done to.
