System Info:
$ cat /etc/os-release
PRETTY_NAME=“Open Source Media Center”
NAME=“OSMC”
VERSION=“January 2023”
VERSION_ID=“2023.01-1”
ID=osmc
ID_LIKE=debianANSI_COLOR=“1;31”
HOME_URL=“https://osmc.tv”
SUPPORT_URL=“https://osmc.tv”
BUG_REPORT_URL="https://osmc.tv
I have set up osmc on a Vero 4k+ from which I mount an exported directory from my mediavault NAS. However I have been unable to to get this mount to work at boot and was wondering if anyone knew how best to do this.
I can mount the drive manually by using the following command:
$ sudo mount -v -t cifs -o vers=3.0,user=username //ipaddress/transcendroot /mnt/transcend
And if I put the following in /etc/fstab:
//ipaddress/transcendroot /mnt/transcend cifs vers=3.0,user=username,pass=password,_netdev 0 0
I can mount using:
$ mount -a
However the mount does not happen when I reboot. My searches indicate that this is because the attempt to mount happens before the network is fully up and indeed I fixed the problem on my Rpi with standard raspian by running
$ sudo raspi-config
and selecting
System Options → Network at Boot → Select wait for network connection on boot
Does anyone know how I can do this on osmc ? It does not seem to have raspi-config.
