I see the option to select play next video automatically, but I cannot see how to deselect it. I have searched Kodi website and drawn a blank.
Hi, that’s not enough information to do anything with.
- OSMC on which device model?
- Which skin is used?
- For which action in the GUI do you see this ‘play next’ action? Playing a movie, playing a series, playing content in the YouTube addon?
- Can you show a screenshot of it?
If the problem is not clear even with this minimal information, we need logs:
The best way to get this information is for you to upload logs that demonstrate your problem. You can learn more about how to submit a useful support request here.
reproduce the issue (scroll/jump to the near end of the video until you see the ‘next video message’ and stop the playback)
upload the log set (all configs and logs!) either using the
Log Uploader
method within the My OSMC menu in the GUI or thessh
method invoking commandgrab-logs -A
I thought there might be a simple answer like something I had missed in the GUI/skin.
I am using the standard OSMC (if I remember right) skin on a Vero V and looking at the services/player screen. The set up is bog standard.
Otherwise thanks for the reply and I’ll just live with it.
Maybe it’s coming from an add-on you are using?
Use the select/return/OK button to navigate down to an individual item instead of the play button if you want to play a single item. Am I correct in assuming your hitting play on a in-progress widget or the top level of a series? If so this is new expected behavior and I’m not aware of a method to change it.
